    Z axis "blocked"
    362
    • carlitototo
      carlitototo last edited by
      My Z axis won't go further than 200mm up, even though my Z axis maxima is set to 585.7... it just stops in the middle ( nothing physically stopping it, it's like the maxima was Z200 ! )
      For example, if I send G1 Z300, it will stop at 200... it's kinda strange behaviour and I can't find were I messed up, it started doing this after I modified the homing files. I tried with the old homing files (before it started to block itself ) but nothing does, it won't get pass 200 !
      Everything else works as intended !
      Help with this would be great 🙂
      Thanks !
      • DocTrucker
        DocTrucker last edited by
        Copy in your config.g please.
        Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
        • DocTrucker
          Does the DWC report a position past 200 or also stop with the motors?
          • A Former User
            A Former User last edited by
            and config-override.g please
            • carlitototo
              Here is the config file
              And the duetwebcontrol shows Z200, I can still use it perfectly !
              Thanks !
              PS : is there a better way to display enormous file like this ?
              ; generated by RepRapFirmware Configuration Tool v2 on Tue Dec 25 2018 10:06:03 GMT+0100 (heure normale d’Europe centrale)
              M581 T2 E1 S1 C0
              M550 P"BIG P" ; Set machine name
              M552 S1 ; Enable network
              M587 S"FREEBOXCDC" P"carlito2002" ; Configure access point. You can delete this line once connected
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M584 X6 Y7 Z5 E3:4
              M569 P6 S0 ; Drive 0 goes forwards
              M569 P5 S1 ; Drive 2 goes forwards
              M569 P4 S1 ; Drive 4 goes forwards
              M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
              M92 X106.67 Y106.67 Z800.00 E420.00:420.00 ; Set steps per mm
              M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
              M203 X18000.00 Y18000.00 Z600.00 E1200.00:1200.00 ; Set maximum speeds (mm/min)
              M201 X2000.00 Y2000.00 Z100.00 E250.00:250.00 ; Set accelerations (mm/s^2)
              M906 X800.00 Y800.00 Z800.00 E1680.00:1680.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X0 Y0 Z585.70 S1 ; Set axis minima
              M208 X580 Y580 Z0 S0 ; Set axis maxima
              M574 X1 Y1 Z1 S0 ; Set active high endstops
              M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
              M558 P9 F100 H5 R0.2 T6000 A5 B1 ; Set Z probe type to bltouch and the dive height + speeds
              G31 P500 X108 Y10 Z2.55 ; Set Z probe trigger value, offset and trigger height
              M557 X15:565 Y15:565 S100 ; Define mesh grid
              M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
              M305 P2 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 2
              M143 H2 S280 ; Set temperature limit for heater 2 to 280C
              M563 P0 S"E0" D0 H1 ; Define tool 0
              G10 P0 X50 Y10 Z0 ; Set tool 0 axis offsets
              M563 P1 S"E1" D1 H2 ; Define tool 1
              G10 P1 X68 Y10 Z0 ; Set tool 1 axis offsets
              G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
              ; Automatic power saving
              M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
              • carlitototo
                And I don't have a config-override.g file... is it a problem ?
                deckingman A Former User 2 Replies Last reply Reply Quote 0
                • deckingman
                  deckingman @carlitototo last edited by
                  @carlitototo I'm surprised it moves at all - you have the Z minimum set to 585.7.
                  Changing that to Z0 will likely fix it.
                  • A Former User
                    A Former User @carlitototo last edited by
                    @carlitototo said in Z axis "blocked":
                    nah, but if you had one, then it would be one of those places a config command that tricks us all is hiding. So no file, no problem.
                      Phaedrux Moderator @carlitototo last edited by
                      Your Z minima and maxima are reversed.
                      That still doesn't explain how it's moving at all, or why it's stopping at 200. Please post your homing files. I think something else is still wrong.
                      • carlitototo
                        Well that's embarrassing... exchange the Z value between Z max and min and it worked... thanks @deckingman and @Phaedrux !
                        Well I guess that's a good thing I don't have this file @bearer
                        here are the homming files :
                        ; homeall.g
                        ; called to home all axes
                        G91 ; relative positioning
                        G1 Z-5 F6000 S2 ; lift Z relative to current position
                        G1 S1 X-585 Y-585 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 X5 Y5 F6000 ; go back a few mm
                        G1 S1 X-585 Y-585 F360 ; move slowly to X and Y axis endstops once more (second pass)
                        G1 S1 Z-585 F1800 ; move Z down stopping at the endstop
                        G90 ; absolute positioning
                        G92 Z0 ; set Z to axis minimum (you may want to adjust this)
                        ;G91 ; relative positioning
                        ;G1 S2 Z5 F100 ; lift Z relative to current position
                        ;G90 ; absolute positioning
                        ; homex.g
                        ; called to home the X axis
                        G1 S1 X-585 F1800 ; move quickly to X axis endstop and stop there (first pass)
                        G1 X5 F6000 ; go back a few mm
                        G1 S1 X-585 F360 ; move slowly to X axis endstop once more (second pass)
                        G1 Z5 F6000 S2 ; lower Z again
                        ; homey.g
                        ; called to home the Y axis
                        G1 S1 Y-585 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                        G1 Y5 F6000 ; go back a few mm
                        G1 S1 Y-585 F360 ; move slowly to Y axis endstop once more (second pass)
                        ; homez.g
                        ; called to home the Z axis
                        G1 Z-5 F600 S2
                        G1 S1 Z-585 F1800 ; move Z down until the endstop is triggered
                        G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                          Are you using a Z probe? It looks like you have a BLTouch configured, but your homing files are setup to use endstops.
                          If you plan on using mesh compensation this can lead to some issues. You will need to either switch homing Z over to using the probe, or at least ensure you do a single G30 probe at the center of the bed before creating the mesh heightmap, and before starting the print/loading the heightmap.
                          https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z
                          https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                          • carlitototo
                            Oh ! Didn't know I could do that... this is a nice feature, going to try and implement it right now !
                            Thansk @Phaedrux
                            • carlitototo
                              Well that must be the most convenient thing that exist in the 3D printing world, works perfectly ! Thanks
                                Welcome to the Duet and RepRapFirmware. You've only scratched the surface.
