    Backlight control
    PanelDue
    • totalos
      totalos last edited by
      Hi.
      How do I set the panel to turn off the backlight automatically, for example after printing ?
      Is it possible to send some g-code to the backlight settings to the panel? (panel 5" integrated).
        On the Setup page on the PanelDue there is an option for backlight dimming.
        What version of PanelDue firmware are you running?
        • totalos
          Thank you for your response.
          I have 1.23.2 firmware.
          I see DIM option but need set dim to a lower brightness level or preferably completely turn off lighting.
          Is it possible to control it?
          hestiahuang 1 Reply Last reply Reply Quote 0
            I don't think it can currently be turned off completely.
            • hestiahuang
              hestiahuang @totalos last edited by
              @totalos
              Buzzer::SetBacklight(0);
              • totalos
                Thank you. But I can not compile it.
