    wrong maximums (solved)
    348
    • KAMIKAZE_FREAKundefined
      KAMIKAZE_FREAK
      Tried printing a 200x210mm size print and the printer cut off corners
      have my Tronxy X5s set to 300X x 300Y but when i ask it to go to 300 x 300 it only goes to X205 and Y200.. if i ask it to go further... it wont do it..
      i tried looking in the files for 205 and 200 values but cant find anything.. and can find the max set to 300 x 300 x 400 like it should be...
      anyone have a explanation and a solution?
      Firmware Electronics: Duet Ethernet 1.02 or later
      Firmware Version: 2.03 (2019-06-13b2)
      Web Interface Version: 1.22.6
      E3v6 Clone
      BLTouch smart v2
      • fcwiltundefined
        fcwilt
        M208 is used to set the min and max values for one or more axes.
        Have you searched in your config.g files to verify you have only one M208 and it is correct?
        Do any other files change these settings?
          KAMIKAZE_FREAK
          ; generated by RepRapFirmware Configuration Tool v2 on Wed Aug 14 2019 02:42:33 GMT+0200 (Central European Summer Time)
          M667 S1 ; Select CoreXY mode
          M550 P"Tronxy X5S" ; Set machine name
          secret
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M569 P0 S1 ; Physical drive 0 goes forwards
          M569 P1 S1 ; Physical drive 1 goes forwards
          M569 P2 S0 ; Physical drive 2 goes backwards
          M569 P3 S0 ; Physical drive 3 goes backwards
          M569 P4 S0 ; Physical drive 4 goes backwards
          M92 X80.00 Y80.00 Z400.00 E95 ; Set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z300.00 E1500.00 ; Set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z100.00 E5000.00 ; Set accelerations (mm/s^2)
          M906 X950.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X300 Y300 Z400 S0 ; Set axis maxima
          M574 X1 Y1 S0 ; Set active low and disabled endstops
          M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
          M558 P9 H1 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
          M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
          G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
          M557 X15:300 Y15:300 S30 ; Define mesh grid
          M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
          M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M563 P0 D0 H1 ; Define tool 0
          M584 X0 Y1 Z2:4 ; two Z motors connected to driver outputs Z and E1
          M671 X0:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
          M208 X0:205 Y0:200 ; X carriage moves from 0 to 300, Y bed goes from 0 to 300
          E3v6 Clone
          BLTouch smart v2
          • NitroFreakundefined
            NitroFreak
            Maybe your steps/mm are set wrong.
            KAMIKAZE_FREAKundefined 1 Reply Last reply Reply Quote 0
              KAMIKAZE_FREAK @NitroFreak
              @nitrofreak
              https://photos.app.goo.gl/8rR4fxQQ6CyBrsti6 vid showing the problem
              E3v6 Clone
              BLTouch smart v2
                NitroFreak
                Do you have a M208 in your config-overrride that could affect this?
                  Phaedrux Moderator @KAMIKAZE_FREAK
                  @kamikaze_freak said in wrong maximums:
                  You've got a rogue M208 at the end of your config.g that over taking the ones earlier on.
                  KAMIKAZE_FREAKundefined 1 Reply Last reply Reply Quote 1
                    KAMIKAZE_FREAK @Phaedrux
                    @phaedrux
                    there it is! 😄 thank you!
                    E3v6 Clone
                    BLTouch smart v2
