    Filament sensor?
    • tech
      tech last edited by
      I would like to know if the sensor filament in pause mode works only if I use an SD card or it can work as well if I use a g-code file through the web interface?
      Thanks
      Chris
      • NitroFreak
        NitroFreak last edited by
        Afaik thats the same thing. it downloads the gcode file to the sd card and prints it from that.
        • T3P3Tony
          Yes, printing through the webinterface first loads the file onto the SD card on the Duet, and yes, in order to pause the print it should be an SD print (as opposed to a stream of gcode over USB).
          www.duet3d.com
