    Bad command & Missing characters in Gcode since firmware upgrade
    43
    2.4k
    • BlueDustundefined
      BlueDust @droftarts
      @droftarts
      I assume the CRC checking is enabled by default. How do you enable/disable them?
      Can you have the Duet2 log the pass CRC codes confirming it is good, and not just the failed ones?
      2019-11-04 21:06:28 Error: Uploaded file CRC is different (65e13ff3 vs. expected bcc41d9a)
      2019-11-04 21:07:27 Error: Uploaded file CRC is different (9401d30a vs. expected bcc41d9a)
      2019-11-04 21:08:17 Error: Uploaded file CRC is different (d7835b84 vs. expected bcc41d9a)
      A month or so ago, I remember having trouble uploading files with a pop up saying that the CRC failed.
      I don't remember what I did to correct it, but just thought it was my slicer having issues. Happy to know this is actually a "thing" and it wasn't just me.
      Fun, that 3 letter word with "u" in the middle.
        dc42 administrators @BlueDust
        @BlueDust said in Bad command & Missing characters in Gcode since firmware upgrade:
        It's at the bottom left of the Settings/Machine Specific page of DWC 2.04.
        If the CRC errors only occur if you upload while printing, then maybe we need to reduce the SPI transfer speed to the Ethernet module if you upload while a print is active, or else adjust the bus priorities.
        norbs12undefined 1 Reply Last reply Reply Quote 0
        • norbs12undefined
          norbs12 @dc42
          @dc42 said in Bad command & Missing characters in Gcode since firmware upgrade:
          Would be possible to somehow make the SPI speed user configurable? I've got two boards, one that I just stopped using because of this and another that only works as long as I'm not printing. Would be awesome to recover the other board and use it for something.
