    Soft reset procedure?
    • peirofundefined
      peirof
      After issues commented in another post... I dlike to do a soft reset of Duet....
      I can't find the procedure for do a soft reset...
      What are the steps? Exists a hard reset procedure?
      • Vetiundefined
        Veti
        the soft reset is the command M999
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M999_Restart
        • peirofundefined
          peirof
          I have try soft reset.... Erase macros and gcode files.. But no, config.g....
          And the same problem with fans...
          I am searching a procedure for factory default
          deckingmanundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
          • deckingmanundefined
            deckingman @peirof
            @peirof I'm not exactly sure what you are looking for. As @veti has said, M999 will restart the firmware. If you want to re-run config.g you can send M98 P"config.g". Does that help?
            • T3P3Tonyundefined
              T3P3Tony administrators @peirof
              @peirof the closed you get to a "factory default" config would be
              https://github.com/T3P3/Duet/tree/master/Duet2/SD Card Contents
              but those are just for testing.
              I would either continue to work with your existing config, or generate a new one with the https://configtool.reprapfirmware.org
              www.duet3d.com
              • peirofundefined
                peirof
                My intention was to test if the two of the fans did NOT work, and gave a voltage lower than 24v, was due to a configuration failure ... but it does not seem likely ...
                What other options do I have?
                Try a downgrade?
                • Vetiundefined
                  Veti
                  The duet fan voltage is either vin or 5v depending on how the jumper is set.
                  the duet uses a pwm signal on the negative to slow down the fans.
                  at 100% no pulsing is taking place
                  post your
                  M106
                  from your config.
