    Problem with the screw terminal from the hotend connection
    498
    • Patrick_487undefined
      Patrick_487
      Good evening,
      Thank you very much for the reception. I am new here and come from Germany. My Duet Ethernet is built into a Hypercube Evolution.
      I have a problem with my Duet Ethernet board. When changing from the Hotend I did not get the cable out of the terminal at the Hotend connection, I had to cut off the cable.
      I could unsolder the connection without problems, however I do not find in the wiki unfortunately the designation and the grid measure of it not.
      Does anyone happen to have a relationship from the terminal for me?
      • A Former User?
        A Former User
        usually headers are 2.54, 3.81 or 5.08mm (0.1", 0.15" and 0.2") and I'm pretty sure its not 2.54 and 5.08mm
        kicad sources are available here https://github.com/T3P3/Duet/tree/master/Duet2/Duet2v1.04
        edit: i used these on my duet 2 maestro https://uk.farnell.com/phoenix-contact/mc-1-5-2-g-3-81/header-right-angle-3-81mm-2way/dp/3704725?MER=sy-me-pd-mi-acce
          Patrick_487
          Do I see that correctly that you have solved it with a plug connection? I also have something like this on my ethernet.
          • A Former User?
            A Former User
            I replaced the screw terminals with pluggable terminals yeah, but you should be able to fit any 3.81mm terminal.
              Patrick_487
              I find pluggable terminals better are screw terminals. The cable then only once screwed
              • A Former User?
                A Former User
                More convenient yeah, but not always possible to find reasonably priced pluggable connectors with sufficient current rating; but these aren't too pricy and good for 8A.
                  On Duet 3 we have switched to JST VH connectors. We'll probably do that on Duet 2 when we do the next design refresh, if our OEMs are happy to change their wiring looms.
                    Patrick_487
                    Do you have a picture of the new connections you used in Duet 3? And what is the name of those currently installed for the hotends.
                    • A Former User?
                      A Former User
                      They're a bit "oddball" at 3.96mm pitch, so they won't fit the Duet 2. But just google JST VH, plenty of pics.
                      (Edit: Pins are also thicker)
                        Correct, I've just verified that you can't get a JST VH connector into the holes for the hot end terminal block in a Duet 2 PCB, because the pins are too large and the hole separation is wrong.
                        Most 2-way 3.81mm pitch terminal blocks should fit the Duet 2.
                        • oliofundefined
                          oliof
                          Someone recently mentioned wago spring Drogen connectors Here, maybe they're a nice idea for a home conversion ...
