    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    31.8k
    • Vetiundefined
      Veti
      awesome work.
      • oozeBotundefined
        oozeBot
        Great work! I just installed and am excited to give it a try this weekend. One bit of initial feedback - it would feel much more intuitive if there was an option to flip the camera control around and the center scroll wheel's zoom..
        Sindariusundefined 1 Reply Last reply Reply Quote 0
        • Sindariusundefined
          Sindarius @oozeBot
          @oozeBot Noted. Appreciate the feedback. I'll have to look into making that an option. I think some of it comes from how you play video games. I tend to use inverted mouse when I play games so it has been more natural to me, I can see that being a problem for others.
          I am resolving some alpha blending issues and trying out some different textures.
          I expect to probably have another version out this evening.
          • Thaliosundefined
            Thalios
            This is truly wonderful!
            I love seeing the cancelled object.
            Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
            Heavily modified Ender 3 Pro (Duet 3 6HC)
            Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
            CR-10S Pro V2 (Duet 3 Mini 5+)
            and a bunch of SLA printers..
            • A Former User?
              A Former User
              A genuine question.
              What is considered the real world use for this?
              Vetiundefined 1 Reply Last reply Reply Quote 0
              • Vetiundefined
                Veti @A Former User
                @CaLviNx
                when one print fails over you can still finish the print on the other objects.
                • A Former User?
                  A Former User @Veti
                  @Veti said in 3D GCode Viewer integrated with DWC:
                  @CaLviNx
                  How does it do that then ? if what you are saying is true then how does the printer know one object has failed and stops extruding for that object but continues to extrude for the others?
                  And that still doesn't explain the real world application use of this when you can see 99% of this from the slicer
                  Vetiundefined Sindariusundefined 2 Replies Last reply Reply Quote 0
                  • Vetiundefined
                    Veti @A Former User
                    @CaLviNx said in 3D GCode Viewer integrated with DWC:
                    this has been a feature in octoprint for some time.
                    https://plugins.octoprint.org/plugins/cancelobject/
                    each object layer has a prefix comment. if the object is to be cancelled the pointer jumps to the next prefix object for the g code printing. leaving out the g code of that object.
                    • PCRundefined
                      PCR
                      yep. its super useful if you printing a lot of small parts and it happens that some does not stick!
                      There is a thread somewhere here explaining it!
                      Will post the link later
                        Sindarius @A Former User
                        @CaLviNx if you are talking about the 3D viewer the original purpose of it was because I use a mixing hotend and I wanted a way to preview how a model would look when i changed the filament on each of the extruders. This viewer approximates what the printed model will look like based on configured colors. Another use is being able to see the model before printing without having to go to a slicer to load it up.
                        • A Former User?
                          A Former User
                          @PCR
                          Now that is much closer to the word "simulation" than what is now 🙂 - WOW! I LIKE IT!
                          I can easily see a big benefit (if this is going to be the new simulation), to also check that you have positioned your file correct on the heatplate, especially when working with additional csys beside the master-machine-csys, BECAUSE -> since it can get from the duet-config.g the maxi building size and can fetch the current "working-csys" (G53-G60 is what this is referring to) no more fuss there!!! You could show even "all" moves (travel-moves etc.) that are in the file to make sure everything is within bounds.
                          Can you tell me if that is implemented already and or if you think you would also have a use-case for this and could implement it?
                          Because that is something for big printers/cnc/lasers that almost no slicer can do (if you do not want to spent "real" money for it and not just a few bucks), to have a simulation with G54 in relation to your workingarea where you have positioned your local csys and where exactly it will be printed then!
                          some people might wonder about the use-case but 2 years ago when working in an art-school, we had courses where we had to position diffrent files on one plate and usually you do this with "sub"-csys like G54, G55, etc. and nobody in a semi-professional environment for basic/-beginner courses will have a slicer or laser-software or cam/cnc-software where they can simulate the whole machine with sub-coordinate systems. The safest thing is to do the work 1 time for/on the actual machine, so to avoid to have to put it into each software every year when a new version is implemented...
                            @LB I can’t say that I have implemented anything for it. I would need to see a sample and look into the use case. This viewer does not simulate exactly what the duet would do it processes the gcode and renders it for the commands I have implemented.
                            • A Former User?
                              A Former User @TLAS
                              @TLAS said in 3D GCode Viewer integrated with DWC:
                              @chrishamm
                              I have a fork of the previous visualizer code that incorporates STL viewing, slicing, and a slick slicer settings / model control component (right now based on Slic3r). Let me know if you’re interested in the code. It’s based on AngularJS and relies on a NodeJS component to integrate with the user’s local slic3r settings and execute the slicer.
                              The goal is to eventually move it server side (cloud) for saving settings and slicing. Also possible to slice on the PI 4 - early benchmarks showed it performed at ~50% of a top end desktop, which means it can likely outperform a slice from the cloud with network transfer in most conditions.
                              Great feature!
                              Hope others have the same usecase:
                              Would appreciate to have the option to run it "locally"(no cloud), since we use duet-boards here at my work (because of me 🙂 we converted the anycubic i3 mega when the mainboard died instead of throwing it away and buing a new one) and I do not think that by any means my boss likes the idea of our company-files being sliced/simulated in some sort of cloud somewhere... I think most company-printers with a duet or printers in public spaces (because of local data-protection-laws) would appreciate local viewing/slicing!
                              Great work anyway - unbelievable to see how much is going on 🙂
                              • JoergS5undefined
                                JoergS5
                                I see another use case in printing the object multiple times with different print parameters and while printing cancelling the objects which are not ok. This could be a calibration in three dimensions too, changing the x, y and z parameters and cancelling the objects which are not good.
                                • A Former User?
                                  A Former User @Sindarius
                                  @Sindarius said in 3D GCode Viewer integrated with DWC:
                                  ok that explains its real world use for you
                                    jay_s_uk @A Former User
                                    @CaLviNx no one is forcing you to install or use this plugin. But thanks for your input...
                                    • A Former User?
                                      @Sindarius
                                      O.K. still like it!
                                      If you would be able to position the file relative to the "plate" in your simulation (that I hope fetches its size from the absolute machine-csys within config.g?) by an offset defined within G54-59 that would do the job.
                                      To try that out you just slice an object that is of course smaller then your buildplate and position it as close to the csys (if the csys is in the corner) or in the middle of the csys (if csys is the center) and then when you uploaded the sliced file to your duet you move your printhead e.g. to a certain spot where you want it to be printed and define the "local" csys e.g. for G54. If the "active" csys could be reflected (...as long as it is active...) in the simulation that would be awesome! I think a lot of cnc-people out there would welcome it!
                                      (Another thing I saw in the video: Since you can get the size of the print-volume via config.g you could limit zoom-out to a reasonable value when stuff get´s so small you cannot see anything anymore also I saw that of course you implemented center-the-view and stuff like it 👍 )
                                      • A Former User?
                                        A Former User @Veti
                                        What is the relevance of mentioning octoprint when this software is to be used on the duet.
                                        Relates to the "gcode viewer" ? you seem to be off on some tangent .
                                        Seeing as we are now off on a tangent, what would be really useful is if there was a way to
                                        have a camera integrated into the "cancel object" software/plugin or what ever you want to call, that could monitor when a segment has failed and automatically modify the g-code on the fly to stop the printer from extruding plastic for that segment.
                                        • A Former User?
                                          A Former User @jay_s_uk
                                          @jay_s_uk said in 3D GCode Viewer integrated with DWC:
                                          excuse me ?
                                          Please show me where I said anyone was forcing me to do anything, I was asking a question nothing more nothing less, but if you wish to take the hump about me asking a question and then try to be passive aggressive about it, be very careful.
                                          It was NOT input it was a QUESTION
                                          question, a noun (ASKING)
                                          A sentence or phrase used to find out information
                                          • A Former User?
                                            This post is deleted!
