    My end stops are not responding on the Duex5
    359
    • georgepaulundefined
      georgepaul
      I have built a printer with IDEX using a Duet Wifi and a Duex5. the X,Y and Z axis homes perfectly but then the homing switch that is connected to the Duex is not responding. i have connected the pins perfectly and the LED is glowing on the Duex and the limitswitch.
      When i send a m119 code, the printer responds saying "Endstops - X: at min stop, Y: at min stop, Z: at min stop, U: not stopped" though the LED is lit.
      am i missing some Mcode that configures the endstops???
        georgepaul
        I just tried connecting U axis to the duet and the extruder to duex and they work... Now really curious what I am doing wrong... am I missing a jumper(i have just one jumper on the endstop voltage connected on the duex)??
        or is it still the firmware???
        • deckingmanundefined
          deckingman @georgepaul
          @georgepaul It might be best if you post your config.g file so that we can see. In particular do you have your M574 command after the M584 that creates the U axis?
            georgepaul
            @deckingman said in My end stops are not responding on the Duex5:
            M574
            ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
            ; generated by RepRapFirmware Configuration Tool v2 on Sun Jun 02 2019 18:49:36 GMT+0530 (India Standard Time)
            M550 P"Duet_Test" ; Set machine name
            M552 S1 ; Enable network
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M584 X0 Y1 Z2 U3 V4 E8:9:5:6:7 ; create the U axis and assign stepper driver 3 to it
            M569 P0 S1 ; Physical drive 0 goes forwards
            M569 P1 S1 ; Physical drive 1 goes forwards
            M569 P2 S0 ; Physical drive 2 goes backwards
            M569 P3 S1 ; Physical drive 3 goes forwards
            M569 P8 S0 ; Physical drive 2 goes backwards
            M569 P9 S1 ; Physical drive 3 goes forwards
            M350 X128 Y128 U128 V128 Z128 E128 I0 ; Configure microstepping without interpolation
            M92 X640.00 Y640.00 U640.00 V640.00 Z3200.00 E2000:2000:2000:2000:2000 ; Set steps per mm
            M566 X900.00 Y900.00 U900.00 V900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
            M203 X12000.00 Y12000.00 U12000.00 V12000.00 Z500.00 E3000.00 ; Set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 U1000.00 V1000.00 Z100.00 E5000.00 ; Set accelerations (mm/s^2)
            M906 X855.00 Y855.00 U855.00 V855.00 Z855.00 E855.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X0 Y0 U0 V0 Z0 S1 ; Set axis minima
            M208 X150 Y150 U150 V150 Z150 S0 ; Set axis maxima
            M574 X1 Y1 U1 V1 Z1 S0 ; Set active low and disabled endstops
            M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
            M557 X25:0 Y25:0 S20 ; Define mesh grid
            M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
            M305 P0 T100000 B3988 R4700 ; Set thermistor + ADC parameters for heater 0
            M305 P1 T100000 B3988 R4700 ; Set thermistor + ADC parameters for heater 1
            M563 P0 D0:1:2:3:4 H1 ; Define tool 0
            T0 ; Select first tool
              georgepaul
              this is the actual m584...the other one was a test i tried yesterday
              M584 X0 Y1 Z2 U8 V9 E3:4:5:6:7 ; create the U axis and assign stepper driver 3 to it
                You have 5 axes XYZUV and they will use the endstop inputs labeled X Y Z E0 E1 respectively. Remapping motors to outputs on the DueX does not remap endstop inputs.
                georgepaulundefined 1 Reply Last reply Reply Quote 0
                  georgepaul @dc42
                  Oh thank you David.. no wonder it was working when i shifted them to the duet...
                  so is there any way to remap the endstops just to make things easier???
                  • T3P3Tonyundefined
                    T3P3Tony administrators @georgepaul
                    @georgepaul remapping endstops is part of the feature set of RRF3 but that is still experimental so I would not switch yet unless you have to have the functionality
                    www.duet3d.com
                      georgepaul @T3P3Tony
                      @T3P3Tony looking forward to that
