    Panel Due Update error (SOLVED)
    PanelDue
    499
    • 3DPMicroundefined
      3DPMicro
      I'm getting "extra arguments found" when trying to update FW through command prompt. Display is connected and showing bossa port 6 in device manager. win10
      Below is the text from command prompt-
      Microsoft Windows [Version 10.0.17134.950]
      (c) 2018 Microsoft Corporation. All rights reserved.
      C:\Users\william>"C:\Program Files (x86)\BOSSA\bossac.exe" --port=COM6 -e -w -v -b M:\PanelDue-5.0i-7.0i (1).bin
      bossac.exe: extra arguments found
      Try 'bossac.exe -h' or 'bossac.exe --help' for more information
      C:\Users\william>
      Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
        Last time I did an update on windows I was able to use Bossa GUI version 1.9. Maybe give that a try instead of the command line.
        • samlogan87undefined
          samlogan87
          I use the GUI version to do both the paneldue and the board when I was having issues and it works flawlessly.
          Kind Regards,
          Sam
          Custom Core-XY
          • A Former User?
            A Former User
            @3DPMicro said in Panel Due Update error:
            you have an extra white space in the firmware filename, this is considered two parameters, so you need to add a qoute; try
            "C:\Program Files (x86)\BOSSA\bossac.exe" --port=COM6 -e -w -v -b "M:\PanelDue-5.0i-7.0i (1).bin"
            • 3DPMicroundefined
              3DPMicro
              Thanks for the input gents but no luck. Possibly the PanelDue itself is the issue. It doesnt appear that the erase button actually erases the FW. Using Bossa I can click info and it shows V1.13 RC2. Bossa will read, verify and write reporting succesful but nothing really happens. I did try bypassing the erase button but that had no effect. I thought I updated the board months ago but judging by the current FW i guess not.
                Are you saying that Bossa reports its own version as 1.13? If so, that's far to old, you need version 1.19.
                TPJensenundefined 3DPMicroundefined 2 Replies Last reply Reply Quote 0
                • TPJensenundefined
                  TPJensen @dc42
                  @3DPMicro
                  I dont know if this is any help I had trouble also.
                  I did rename my file "PanelDue-5.0i-7.0i (1).bin" to PanelDue.bin and mine worked after
                  3DPMicroundefined 1 Reply Last reply Reply Quote 0
                  • 3DPMicroundefined
                    3DPMicro @dc42
                    @dc42 maybe the 1.13 is for the processor perhaps? It shows the year as 2013.
                    I am using the latest bossa 1.9.1
                    Anyway. I think it updated although the touch screen needs to be calibrated. It never put the panel into calibration mode and nowhere can I touch will take me there.
                    • 3DPMicroundefined
                      3DPMicro @TPJensen
                      @TPJensen thanks
                        dc42 administrators @3DPMicro
                        Are you able to get to the Setup page?
                        • 3DPMicroundefined
                          3DPMicro @dc42
                          @dc42 said in Panel Due Update error:
                          I was not. I loaded 1.21.3 and it worked then went back to 1.23.2 and it is working perfectly. All is well.
                          I dont know if its possible but it seemed like updating from the original FW that was on the board (purchased from filastruder in February of 2018) to the latest was the issue. I tried every way under the sun with no luck until loading the earlier FW
