Single Setup for Duet 3
@4lathe said in Single Setup for Duet 3:
So I just setup my rpi4 in advance of receiving my duet 3 this week
Ah, as tony says, thats not gonna work. everything depends on DuetControlServer, and it won't start without the Duet3 connected.
@bearer ok so just leave it for now?
yeah, might as well, you won't be able to verify the software anyways.
Although I'm puzzled by the fact that you say you get a HTTP 500 error if the Duet3 isn't connected, which is why I glossed over that bit initially.
@bearer no idea.
@bearer said in Single Setup for Duet 3:
The DuetWebServer will start but it communicates with the DuetControlServer via that /var/run/duet.sock socket which is created by the DuetControlServer and that won't even start if it doesn't get a response from the Duet3 via the SPI bus. So when you access the web server, it responds with a 500 because it can't connect to that socket.
@gtj0 ah, must have changed the behavior at some point then, previously it would terminate right away if started manually without DuetControlServer; and the systemd service won't even start.
Anyways, moot point, gotta wait for the board in any case.
@bearer thx much for the explanation.
