    Anycubic I3 Mega Mod questions
    5.0k
    • pauleddundefined
      pauledd
      Hi there
      I am in the middle of modifying my old Anycubic I3 Mega (Trigorilla Pro 32bit) to the Duet Wifi 2 Board (1.04).
      Is there maybe someone who has a Configtool JSON settings file
      for me so that I can compare it to my settings?
      I ask because it is a bit unclear to me what setting I shall use
      in the Extruders tab under "Steps per mm" ... and also under Z-Axis
      "Steps per mm". Ive seen configs that have
      M92 X80 Y80 Z400 E92.6
      Z400? I assumed that the I3 Mega has M8 lead screws and the configurator calculator presented another value to me:
      I surely will have a few more questions later 🙂
      ----- human being without Windows™ ------
      • grizewaldundefined
        grizewald
        Those steps/mm values are correct for the i3 Mega and assume 16x microstepping. (And no, I don't have a RRF config file for you as I'm still using the original controller board in my Mega.)
        pauleddundefined 1 Reply Last reply Reply Quote 0
        • pauleddundefined
          pauledd @grizewald
          @grizewald said in Anycubic I3 Mega Mod questions:
          Which one? 400mm/s for Z?
          • pauleddundefined
            pauledd
            Ok, seems to be the line is okay:
            Next Question...
            The I3 Mega has two Z-endstops... where to connect the second and how to configure the second? The RRF Config tool only has one z-endstop entry...
              jay_s_uk
              Rather than run both z motors off the z connector, run them independently. So map the other one to E1 (for example). Then connect the second end stop to E1.
              See M584 in the wiki
              • pauleddundefined
                pauledd
                Thanks, I just run both Z motors togehter with just one endstop and homing seems to work so far. Is there a specific advantage running both steppers and both endstops independently ?
                grizewaldundefined 1 Reply Last reply Reply Quote 0
                  grizewald @pauledd
                  @pauledd said in Anycubic I3 Mega Mod questions:
                  If you only have one Z end stop, you can't be sure that both lead screws end up at the same position when you home the Z axis. My i3 Mega has two Z end stops and it took a lot of adjustment to make sure that the adjusters were set properly so that the X axis is perfectly parallel to the bed, but once I'd adjusted it properly, both Z carriages end up at exactly the same height above the chassis after homing.
                  If I remember correctly, the fact that you couldn't get the X axis level properly with just one Z end stop was one of the initial criticisms of the i3 Mega. Mine came with two Z end stops and was a later model. It still drives the two Z motors from one stepper, but doesn't stop driving them down until both switches are closed.
                  • pauleddundefined
                    pauledd @jay_s_uk
                    @jay_s_uk said in Anycubic I3 Mega Mod questions:
                    M584
                    Okay, so I'll try now two seperate drivers for the Z-axis.
                    Z+ stepper (the left one) is plugged into the outer "Z" and I put both
                    jumpers back on the inner one. Z- stepper (the right one) is now in E1.
                    Endstop Z+ is in Z and Endstop Z- is in E1.
                    So I change these commands in my "Drives" section in config.g:
                    ;M584 X0 Y1 Z2 E3 ;old
                    M584 X0 Y1 Z2:4 E3 ;new
                    Now, do I need to change anything else? Or applies "steps per mm , accelerations etc..." automatically to both Z-drivers?
                    And do I have to change something in the "endstop" section? It currently
                    have this code:
                    M574 X1 Y1 Z1 S0
                    • pauleddundefined
                      pauledd
                      Ok, I'll try to follow this guide:
                      https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches/18?lang=en
                      • pauleddundefined
                        pauledd
                        Well, this of cause didnt work...
                        If I press "Home Z" both Z-Steppers start to move down.
                        They both hit the endstop and the right stepper (E1) stops moving
                        but the left stepper (plugged in Z) keeps on moving and makes a great
                        loud rattling noise. So I immediately press the emergency stop button.
                        I checked both enstops (Z & E1), both leds lit on if pressed.
                        Under "Machine Properties" the Z endstops shows correctly "yes"
                        if pressed. The other E1 endstop is not in that list. Instead I have an E0 endstop which is unconnected on my board...
                        My config.g:
                        M208 X0 Y0 Z0 U0 S1                          ; set axis minima
                        M208 X210 Y210 Z205 U205 S0                    ; set axis maxima
                        M584 X0 Y1 Z2:4 U4 E3 P3                          ; set drive mapping
                        M574 X1 Y1 Z1 U1 S0                          ; set active low and disabled endstops
                        G90                                       ; send absolute coordinates...
                        M83                                       ; ...but relative extruder moves
                        M550 P"Pauls Duet"                        ; set printer name
                        M552 S1                                   ; enable network
                        M586 P0 S1                                ; enable HTTP
                        M586 P1 S0                                ; disable FTP
                        M586 P2 S1                                ; enable Telnet
                        M569 P0 S0                                ; physical drive 0 goes backwards
                        M569 P1 S0                                ; physical drive 1 goes backwards
                        M569 P2 S1                                ; physical drive 2 goes forwards
                        M569 P3 S1                                ; physical drive 3 goes forwards
                        M569 P4 S1				  ; Z- physical drive 4 goes forwards
                        M350 X16 Y16 Z16 U16 E16 I1                   ; configure microstepping with interpolation
                        M92 X80.00 Y80.00 Z400.00 U400.00 E92.60          ; set steps per mm
                        M566 X900.00 Y900.00 Z12.00 Z12.00  E120.00       ; set maximum instantaneous speed changes (mm/min)
                        M203 X30000.00 Y30000.00 Z360.00 U360.00 E1200.00 ; set maximum speeds (mm/min)
                        M201 X8000.00 Y8000.00 Z50.00 U50.00 E250.00     ; set accelerations (mm/s^2)
                        M906 X1200 Y1200 Z1200 U1200 E1200 I30          ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30                                   ; Set idle timeout
                        M558 P0 H40 F120 T3000                    ; disable Z probe but set dive height, probe speed and travel speed
                        M557 X15:210 Y15:195 S20                  ; define mesh grid
                        M305 P0 T100000 B4725 C7.060000e-8 R4700  ; set thermistor + ADC parameters for heater 0
                        M143 H0 S90                               ; set temperature limit for heater 0 to 90C
                        M305 P1 T100000 B4725 C7.060000e-8 R4700  ; set thermistor + ADC parameters for heater 1
                        M143 H1 S245                              ; set temperature limit for heater 1 to 245C
                        M106 P0 S0 I0 F500 H-1                    ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M106 P1 S1 I0 F500 H1 T45                 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                        M563 P0 D0 H1 F0                          ; define tool 0
                        G10 P0 X0 Y0 Z0                           ; set tool 0 axis offsets
                        G10 P0 R0 S0                              ; set initial tool 0 active and standby temperatures to 0C
                        ; Custom settings
                        M552 S1
                        My homeall.g
                        G1 Z30 F3000 H2     	; lift Z relative to current position
                        G1 X-215 Y-215 F1800 H1 ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 X5 Y5 F3000          ; go back a few mm
                        G1 X-215 Y-215 F360 H1  ; move slowly to X and Y axis endstops once more (second pass)
                        M98 homez.g
                        My homez.g
                        ; split Z motor control to Z and U
                        ; for it to work we have to show U (param P4) in the UI
                        M584 Z2 U4 P4
                        ; Move Z and U  down until the switches triggers
                        G1 Z-205 U-205 F1000 H1
                        ; back to combined axes and hidden U
                        M584 Z2:4 P3
                        ; Back to absolute positioning
                        G90
                        ; Tell the firmware where we are
                        G92 Z0
                        ; lift Z after probing
                        G91
                        G1 Z10 F1000
                        G90
                          grizewald
                          If you have axes X, Y and Z and then you create a fourth axis, the end stop for that fourth axis will be the first unused end stop in order. So, if you don't have your second Z end stop connected to the E0 end stop input, then you should connect it there.
                          That's why it's showing you an E0 end stop.
                          • pauleddundefined
                            pauledd
                            @grizewald thanks 👍
                            Works now!
                            What I did:
                            • replugged Z(-) stepper into E0 and Z-endstop into E0
                            config.g:
                            • moving the M584 code above M208 code
                            • changed M584 to M584 X0 Y1 Z2:3 U3 E4 P3
                            • corrected M566 to M566 X900.00 Y900.00 Z12.00 U12.00 E120.00
                            homeall.g:
                            • changed M98 to M98 Phomez.g
                            homez.g:
                            G1 Z10 F3000 H2   ; lift Z relative 10mm
                            M584 Z2:3 U3 P4
                            G1 Z-205 U-205 F100 H1
                            M584 Z2:3 U3 P3
                            G90
                            G92 Z0
                            G91
                            G1 Z10 F1000
                            G90
                            Tomorrow I have the fans on my list ☺
                              grizewald
                              Great! You're making good progress.
                              It doesn't matter if you had the second Z motor in E1 or E0, just that you moved the end stop to the next free one in order. It's actually simpler to leave the first extruder in E0 and put the second Z motor in E1 as the firmware expects that you will use E0 for the first extruder.
                              In the end though, it doesn't really matter, as long as you describe everything correctly for the firmware. It certainly beats re-compiling and flashing firmware every time you want to make a configuration change!
                              • pauleddundefined
                                pauledd
                                Fans are workin!
                                Of cause I forgot to put the V_FAN jumper on V_IN as I wondered
                                why nothing moves...
                                Just for those who stew over how to connect the Anycubic (FAN1) connector, that's how I wired it to the Duet:
                                • pauleddundefined
                                  pauledd
                                  Hotbed is working!
                                  I measured the current to the hotbed alone and that gave me about 14.3A while heating up to 55°C. The 15A fuse got hot to about 65°C but once the bed reached 55°C it cooled down to about 50°C.
                                  Should I go for a 20A fuse?
                                    jay_s_uk
                                    It might be worth thinking about an SSR to control the heated bed so you're not putting all the power through the duet.
                                    • pauleddundefined
                                      pauledd
                                      Yes, I consider that if everything else works perfectly.
                                      • pauleddundefined
                                        pauledd
                                        Hotend works too!
                                        But now three steps back to Z-Axis problem 😠
                                        Z+ stepper (left) again crashed onto the endstop while doing a Home Z, the Z+ endstop led was even lit up...
                                        By the way and quite strange, If I trigger both Z endstopps
                                        earlier with my fingers the homing process finishes every time successfully. I'll try to fiddle a bit more, maybe I get behind that mystery. Maybe I twist both endstops to see if one is kind of faulty...
                                        • pauleddundefined
                                          pauledd
                                          Z Axis Problem still not solved but at least the last crash was some time ago... I now monitor the Z endstops IO pins with my oscilloscope to find out if there is something strange if it crashes again.
                                          But I couldnt resist to print my first testcube that came out good, with a LOT room 😁 for optimization.
                                          Thermal situation while printing the cube:
                                          (steppers set to 1.2A)
                                          https://www.youtube.com/watch?v=Dd4siLtXD9I&feature=youtu.be
                                          • pauleddundefined
                                            pauledd
                                            I noticed something weird if I do a "HOME-Z". That might be the reason
                                            for crashing Z-axis into endstops or my understanding of that process is wrong/incomplete. Just as a side note, I changed the endstops with new ones and checked the endstop signals on my oscilloscope but this did not solve the crashing problem...
                                            What I observed:
                                            I move the Z axis up a bit so that I can test both endstops without crashing the axis onto them.
                                            I press HOME-Z.
                                            Z axis moves slowly down. I press the right endstop first, nothing happens, both steppers continue moving until I press the left endstop.
                                            (that would produce a crash if endstops are triggered with delay).
                                            Now I test HOME-Z again but this time I press left endstop first.
                                            As I trigger left endstop the RIGHT stepper stops, the left one keeps moving until I trigger the right endstop.
                                            (that would produce a crash too if there is a delay between both endstop triggering...)
                                            Is my understanding wrong and this is the intended procedure or is there something wrong?
                                            Shouldn't stop the left stepper if I trigger the left endstop and vice versa? Is this maybe a software problem?
                                            I also recorded a video, you might have problems to see the steppers stop because they move quite slowly...
                                            https://youtu.be/qJ-i4Jgc1WA
