    RepRapFirmware 3.0 first official beta is out
    Beta Firmware
    15
    132
    9.0k
    • Marco Bonaundefined
      Marco Bona @T3P3Tony
      @t3p3tony
      Sorry but the second P value was a bonding problem.
      For DSF I realized that it was only for Duet3, I'm using Duet2. If it is to be installed where can I find the file?
      • T3P3Tonyundefined
        T3P3Tony administrators
        @Marco-Bona No you are right DSF is only Duet 3
        www.duet3d.com
        • kraegarundefined
          kraegar @T3P3Tony
          @T3P3Tony Thanks - I wasn't pointing to the unstable repo. Also, easy fix, but might trip up someone not linux savvy, you're missing a sudo on the apt-get install line of the instructions.
          Co-Creator of the RailcoreII CoreXY printer
          https://www.thingiverse.com/thing:2407174
          • kraegarundefined
            kraegar
            Failed again, at 14.50mm of an 80mm print. Reports it's 100% but definitely is not.
            • kraegarundefined
              kraegar
              I'd only used systemctl to restart all the duet processes. Trying a print from a known reliable slice from my duet2, with a fresh boot on the latest software on the unstable branch.
              • T3P3Tonyundefined
                @kraegar Please can you check the firmware viserion uning M115 and the versions on DSF you have through this command on the Rpi:
                apt list 2>/dev/null | grep duet | awk -F'[/ ]' '{print $1" "$3 }'
                (thanks @wilriker for the awk foo)
                www.duet3d.com
                • kraegarundefined
                  kraegar
                  @T3P3Tony said in RepRapFirmware 3.0 first official beta is out:
                  FIRMWARE_NAME: RepRapFirmware for Duet 3 v0.5 FIRMWARE_VERSION: 3.0beta10 ELECTRONICS: Duet 3 prototype v0.5 FIRMWARE_DATE: 2019-09-12b1
                  duetcontrolserver 1.0.3.3
                  duetruntime 1.0.3.3
                  duetsd 1.0.2
                  duetsoftwareframework 1.0.3.3
                  duettools 1.0.3.3
                  duetwebcontrol 2.0.0-4
                  duetwebserver 1.1.0.0
                  • wilrikerundefined
                    wilriker @T3P3Tony
                    @bearer is the one to deserve credits for the awk-foo. I try to avoid awk where I can. 😁
                    Manuel
                    My Tool Collection
                    A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
                    • A Former User?
                      A Former User @wilriker
                      @wilriker said in RepRapFirmware 3.0 first official beta is out:
                      you mean you don't want the blame? ... awkward! 😂
                      • kraegarundefined
                        kraegar
                        awk is great. Learn to love it 🙂
                        I meant to kick off a ~4 hour print. Grabbed the slice and didn't check it, closer to a ~14 hour print. I'm a bit over 2 hours into it. So, this should be a good test of the duet3 after a fresh startup, so far so good.
                        • T3P3Tonyundefined
                          T3P3Tony administrators @wilriker
                          @wilriker , cheers sorry @bearer 😄
                          www.duet3d.com
                          • kraegarundefined
                            kraegar
                            Guess it's good I used the 14 hour slice, it froze about 12 hours in. It started to occasionally pause (could hear the stepper go still for a second or two), then it totally stopped moving and shut off the heaters. Wish I hadn't used my good filament, though!
                            https://i.imgur.com/IuEyyvB.jpg?1
                            • Dougal1957undefined
                              Dougal1957
                              OK Managed to get the Duet3 powered up and connected to the PI4 using the supplied image DWC came up on the Pi Monitor. so far so good. But how do I connect to it from elsewhere on my network I have tried to SSH in but don't have the Password for it and VNC doesn't want to connect either. I am guessing I need to set this up on the PI but being a total newby with Linux I could do with some pointers if someone could be so kind.
                              Doug
                              T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
                              • A Former User?
                                A Former User
                                @Dougal1957 said in RepRapFirmware 3.0 first official beta is out:
                                Not sure how this image is prepared, but the default raspbian user/password is pi/raspberry could try that while waiting. (Are you getting a login prompt at all when trying SSH? Default is not having SSH enabled)
                                Edit: although you should be able to configure the Duet3 part through the file editor in DWC just like on Duet2, however to update DSF/DWC i think you'll need SSH access for now.
                                Dougal1957undefined 1 Reply Last reply Reply Quote 1
                                  Dougal1957 @A Former User
                                  @bearer I am getting a response from SSH but it throw's me out after 3 PW attempts also bring to connect to the IP Address thru a browse doesn't seem to work either I am starting to wonder if I have the right IP Address for it
                                  • A Former User?
                                    A Former User
                                    Hmm, if you're running an OS that can mount Linux filesystems you should be able to mount the SD card in your computer and simply add your ssh key to /home/pi/.ssh/authorized_keys and log in regardless of passwords.
                                    If you're on windows you could try resolving the hostname of the IP, might give you a clue if its the right address.
                                    C:\Users\bearer>ping -a 10.10.193
                                    Pinging duet3.lan [10.10.0.193] with 32 bytes of data:
                                    Reply from 10.10.0.193: bytes=32 time=2ms TTL=64
                                    Linux equivalent would be
                                    bearer@rama:~$ nslookup 10.10.0.193
                                    193.0.10.10.in-addr.arpa        name = duet3.lan.
                                    • T3P3Tonyundefined
                                      T3P3Tony administrators @Dougal1957
                                      @Dougal1957 its the default pi / raspberry
                                      www.duet3d.com
                                      • T3P3Tonyundefined
                                        T3P3Tony administrators @T3P3Tony
                                        @bearer AFAIK the way the image is setup has SSH enabled, using passwords. so no need to so that.
                                        www.duet3d.com
                                        • T3P3Tonyundefined
                                          T3P3Tony administrators @kraegar
                                          @kraegar did you manage to get an M122 captured?
                                          www.duet3d.com
                                          kraegarundefined 1 Reply Last reply Reply Quote 0
                                          • A Former User?
                                            A Former User @T3P3Tony
                                            i'd assume that but, the answer would still help determine if he has got the correct IP.
                                            Dougal1957undefined 1 Reply Last reply Reply Quote 0
