Add encoder to ender 3
HI I want to add an cheep encoder to ender 3 for layer shift and crash dection and recovery
what do i need to do for software for close loop mointoring
@poohzaza hi, please tell us what you want to achieve or what your problem is. Following your question, you seem to have probelms with the Z movement of your print bed, but I speculate. Maybe you have a hardware problem which can be solved easier than by software.
@JoergS5
HI thanks for replying what i want to archive is add feture of prusa mk3 smart feature to ender 3
layer shift dection and recovery
from what i under stand form reading prusa mk3 firmware is if stall condection were found stop print and re home and carry on printing
i try to do this on marlin but i found that you need to re write a lot of firmware
and reprap firmware it is bulid in to firmware but i coud not get stall dection working properly and after reading on the duets forum you need a close loop step motor to do this and i have an idea to use cheep encoder to make feedback system
You don't need a closed loop motor for stall detection. See https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing for an introduction to how to do this on Duet2 Wifi.
