    SOLVED Cant connect to Duet 2 with YAT
    745
    • peirofundefined
      peirof
      after the fan issue, i have received a new DUET 2, and i have instaled.... but something estrange with i follow the GETTING CONNECTED TO YOUR DUET+Getting+Connected+to+your+Duet/7) guide.
      When connect with Duet 2 and YAT, without Power suply, i recive in console the message...
      - "wifi reported error:no networks found LF WIFI module its idle...."this message repeats until the end of the line
      I have try with Putty, and the same
      What can i do?
      • T3P3Tonyundefined
        T3P3Tony administrators @peirof
        @peirof please start by setting your EOL settings correctly in YAT so we can see whats going on.
        www.duet3d.com
        peirofundefined 1 Reply Last reply Reply Quote 0
        • peirofundefined
          peirof
          @T3P3Tony said in Cant connect to Duet 2 with YAT:
          I'm not sure what you mean by EOL, I put two screenshots....
          • peirofundefined
            peirof @T3P3Tony
            @T3P3Tony please start by setting your EOL settings correctly in YAT so we can see whats going on.
            I have google a few over these, it's something related to the line endings?
            • A Former User?
              A Former User @peirof
              @peirof said in Cant connect to Duet 2 with YAT:
              yes, set to LF
              • T3P3Tonyundefined
                In the guide you were using:
                https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s6
                Setup YAT to use <LF> as the end of line character. Go to "Terminal" Menu -> "Settings" -> "Text Settings" -> "EOL sequence:" set to <LF>
                www.duet3d.com
                • peirofundefined
                  peirof @T3P3Tony
                  @T3P3Tony Eeee.... Similar, but in lines
                   - "wifi reported error:no networks found" this message repeats ad infinitum.....
                  This message meaning that WiFi module its on... And cnt fin a valid WiFi. No?
                  But if I send "M552 S0", this supposed power off WiFi module, yat returns OK... But the message repeats...
                  • A Former User?
                    @peirof try the suggestions from this post? https://forum.duet3d.com/post/105418
                    And post the output from M122 to check that the firmware versions are compatible.
                    • peirofundefined
                      peirof @A Former User
                      @bearer can update firmware with Yat?
                        Phaedrux Moderator @peirof
                        Yes. If the firmware files are already on the SD card you can use M997. See here: https://duet3d.dozuki.com/Wiki/Gcode#Section_M997_Perform_in_application_firmware_update
                        • peirofundefined
                          peirof
                          Solved....
                          Thanks for help...
                          and... whats the problem... not sure, i have redo all procedures in Getting connected guide.... and works.
                          Only a thing, after connect with YAT, the message follow appearing.... i have sended M552 S0, to stop WiFi module, and the message stops...
