SOLVED I was excited that all my hiccups were easily resolved until....
I test fired the build and saw an erratic bed warm up issue. After looking over everything, I noticed that the heaterbed connector felt a little “weird,” as in slightly wiggly on one side of the connector. I pulled the board and as I wiggled the connector I could see the pin on the other side move :/. This maybe was a contributor to some of the signal noise I may have seen with the endstop? I don’t know. The solder on the pin looks good and it may be the pad is not attached. Is this something I can have covered? All other connectors and their pins are solid. The heater wires were connected to an SSR, so it was acting as a control signal, not actually supplying power for the bed (which is on line voltage.)
I have a small video if that helps.
So bummed, as I was pretty much done with the printer build and was excited to start commissioning and printing.
hi @Nuramori can you please contact you reseller for a replacement.
Are you saying the connector on the board is loose?
Can you please post your video and perhaps some close up photos?
May be a good idea to contact your vendor for a warranty replacement.
Thanks for that. Link worked. @T3P3Tony will definitely want to see that.
@T3P3Tony, will do. I already sent Tim an email. I live within 10 miles of Filastruder. And thanks for the help. Much appreciated.
