    feedrate confusions
    1.3k
    • georgepaulundefined
      georgepaul
      I had done a test that i have raised a query about... link bellow
      https://forum.duet3d.com/topic/12130/random-test-trying-to-understand-feedrate
      This is more like a continuation or followup
      I moved 1 motor for 100mm at a feedrate of 100mm/min, it took 1 minute.
      now i connected another motor with the exact same settings in steps/mm, current, direction, acceleration, speed, instantaneous speed changes etc in the second extruder,
      Then ran a command G1 E100:100 F100
      This means both the motors should move have ideally moved 100mm in 1 min.
      but this was a shocker. it took 1:25min.
      This got me worked up and curious ath the sam time, so i connected a duex5 and two more motors.
      G1 E100: 100: 100:0 F100
      ran the above code and it took 1:44 min
      G1 E100: 100: 100:100 F100
      this took 2min...😨 😱
      so now i am confused how this works and what happens in the background... can anyone shed some light on why this happens.
        droftarts administrators
        Can you post your config.g so we can see how your motors and tools are set up? This might have a bearing on what each extruder does, ie if you have the tool set up as a mixing extruder, or different motor configurations for different motors limiting speed.
        Regarding minimum speed, you can set this with the 'I' parameter in M203. Default is 30mm/min (0.5mm/s).
          georgepaul
          M584 X0 Y1 Z2 E3:4:5:6 ; drive remapping
          M569 P0 S1 ; Physical drive 0 goes forwards
          M569 P1 S0 ; Physical drive 1 goes forwards
          M569 P2 S0 ; Physical drive 2 goes backwards
          M569 P3 S1 ; Physical drive 3 goes forwards
          M569 P4 S0 ; Physical drive 4 goes forwards
          M350 X128 Y128 Z128 E128:128:128:128 I1 ; Configure microstepping without interpolation
          M92 X640.00 Y640.00 Z3200.00 E3200:3200:3200:3200 ; Set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)(E120)
          M203 X12000.00 Y12000.00 Z500.00 E3000.00 ; Set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; Set accelerations (mm/s^2)
          M906 X855.00 Y855.00 Z1000.00 E855.00:855.00:855.00:855.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          • wilrikerundefined
            wilriker @georgepaul
            @georgepaul said in feedrate confusions:
            You need to repeat the values for each extruder as you did in the other commands as well with these ones. Otherwise they will most likely get a default value.
            EDIT: My fault. They will auto-repeat.
            Manuel
            My Tool Collection
              georgepaul
              M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)(E120)
              M203 X12000.00 Y12000.00 Z500.00 E3000:3000:3000:3000 ; Set maximum speeds (mm/min)
              M201 X1000.00 Y1000.00 Z100.00 E5000.00:5000.00:5000.00:5000.00 ; Set accelerations (mm/s^2)
              I tried this also
                georgepaul
                M563 P0 D0:1:2:3 H1 ; Define tool 0
                • wilrikerundefined
                  @georgepaul Did you also just try
                  G1 E100 F100
                  Since your tool is configured to have 4 extruders and probably no mixing ratio (M567 ) this should already be sufficient to move all extruder steppers. What happens then in regards to duration?
                  Manuel
                  My Tool Collection
                  georgepaulundefined 1 Reply Last reply Reply Quote 0
                    georgepaul @wilriker
                    @wilriker when i send G1 E100 F100, the first extruder(E0) moves and it rotates for 1 minute.
                    • wilrikerundefined
                      @georgepaul OK, then next question: does it work correctly if you define an equal mixing ratio like
                      M567 P0 E1:1:1:1
                      and then just use
                      G1 E100 F100
                      Manuel
                      My Tool Collection
                        georgepaul
                        @wilriker said in feedrate confusions:
                        M567 P0 E1:1:1:1
                        i tried this.. it still took 2 minutes
                        • wilrikerundefined
                          @georgepaul OK, we need more information. Can you please run the following commands on your machine and post the output:
                          M115
                          M201
                          M203
                          M566
                          M92
                          M350
                          M906
                          This will print what the machine currently takes as configured values plus the current firmware version.
                          Manuel
                          My Tool Collection
                            georgepaul
                            100
                            M115
                            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2018-06-05b3
                            M201
                            Accelerations: X: 1000.0, Y: 1000.0, Z: 100.0, E: 5000.0:5000.0:5000.0:5000.0
                            M203
                            Maximum feedrates: X: 12000.0, Y: 12000.0, Z: 500.0, E: 3000.0:3000.0:3000.0:3000.0
                            M566
                            Maximum jerk rates: X: 900.0, Y: 900.0, Z: 12.0, E: 120.0:120.0:120.0:120.0
                            M92
                            Steps/mm: X: 640.000, Y: 640.000, Z: 3200.000, E: 3200.000:3200.000:3200.000:3200.000
                            M350
                            Microstepping - X:128(on), Y:128(on), Z:128(on), E:128(on):128(on):128(on):128(on)
                            M906
                            Motor current (mA) - X:855, Y:855, Z:1000, E:855:855:855:855, idle factor 30%
                              As a first step perhaps try upgrading the firmware to latest and see if there has been a bug fix or change that makes a difference. Check the Whats New change log as well.
                              And does it occur the same with x16 microstepping?
                              georgepaulundefined 2 Replies Last reply Reply Quote 0
                                georgepaul @Phaedrux
                                @Phaedrux
                                I haven't tried with varying micro-stepping yet.. I don't think it should make a difference because for one motor E100 F100 is perfect.
                                  @Phaedrux i just tried with 1/16 microstepping... still 2 minutes😲
                                    georgepaul
                                    I just updated my firmware from 2.00 to 2.03 and ran the same tests.
                                    M115
                                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2019-06-13b2
                                    Now with M567 P0 E1:1:1:1
                                    • G1 E100 F100 / G1 E100:0:0:0 F100 all four motors turn in 1 minute.
                                    • G1 E100: 100:0:0 F100 two motors turn in 2 minute.
                                    • G1 E100: 100: 100:0 F100 three motors turn in 3 minute.
                                    • G1 E100: 100: 100: 100 F100 four motors turn in 4 minute.
                                    And without M567 P0 E1:1:1:1
                                    • G1 E100 F100 / G1 E100:0:0:0 F100 first motors turn in 1 minute.
                                    • G1 E100:100 F100 two motors turn in 2 minute.
                                    • G1 E100: 100:100 F100 three motors turn in 3 minute.
                                    • G1 E100: 100: 100:100 F100 four motors turn in 4 minute.
                                      georgepaul
                                      now that the timing has changed by itself(after updates), i am sure its nothing to do with my config.g file
                                      • wilrikerundefined
                                        wilriker
                                        Thinking about it that makes even sense because: with the G1 E100:100:100:100 F100 you command to extrude a total of 400mm of filament (distributed over for extruders) with a feedrate of 100mm/min. That takes four minutes.
                                        Manuel
                                        My Tool Collection
                                          @wilriker
                                          That's what I thought too.. so i tried with X and Y axis also,
                                          G1 X100 E100 F100 ;the move took 1minute
                                          G1 Y100 E100 F100 ;the move took 1minute
                                          G1 X100 Y100 E100 F100 ;the move took 1minute 25 seconds
                                            georgepaul
                                            i am just curious to know what the printer is doing behind my back😛
                                            there must be some formulae running in the background. What are the variables and constants that define these movements and feedrates?
