    Error: Failed to create directory 0:/filaments/PLA
    My Duet controlled machine
    1.2k
    • PaulHewundefined
      PaulHew
      I am trying to create a filament but I keep getting this error and I am unsure on how to fix it.
      Assistance would be appreciated.
      TIA.
      Paul
      Screenshot
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        Does the filaments directory exist on the SD card? If not, what happens if you manually create it? Does the error still occur?
        • PaulHewundefined
          PaulHew
          AH!
          Had to pull the SD card as I first created it in the 'System Folder' which did not work using DWC.
          Works now, thanks @Phaedrux
          What is the filament section for as I do not understand its function.
          Paul.
          Phaedruxundefined 1 Reply Last reply Reply Quote 1
            Phaedrux Moderator @PaulHew
            @PaulHew said in Error: Failed to create directory 0:/filaments/PLA:
            It's for setting up different config sets for different filaments.
            https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_Filaments
            For example, you could have different firmware retraction and speed settings or heater profiles or fan profiles for different filaments. Printing carbon fiber ASA is going to require some different settings compared to basic PLA.
            Many things can be set in the slicer or in the slicer start gcode, or in a macro, etc etc. This is just another firmware centric way of managing it.
            • yngndrwundefined
              yngndrw
              In case anybody else is having this issue and their Duet is buried inside their printer where the SD card isn't accessible, you can create the directory from the Web UI by navigating to this URL: (Replace <DuetIP> with the IP address of your duet)
              http://<DuetIP>/rr_mkdir?dir=0%3A%2Ffilaments
              TETRIXGEARundefined dc42undefined 2 Replies Last reply Reply Quote 5
              • TETRIXGEARundefined
                TETRIXGEAR @yngndrw
                @yngndrw It worked 😉 thanks
                  dc42 administrators @yngndrw
                  RRF 3.01beta1 will create the filaments folder automatically, to avoid this issue.
