    Add laser for duet2 wifi
    Laser Cutters
    5.0k
    • Danalundefined
      Danal
      Looks correct, and the values given will work with a Duet (expansion) at 12V or 24V.
      As with any project, verify as much as possible with a voltmeter or o-scope, every step of the way.
      yamanundefined 1 Reply Last reply Reply Quote 2
      • yamanundefined
        yaman @Danal
        @Danal
        @EasyTarget
        OK so after some work with solder
        the circuit not work exactly but after I make little change the Laser finally work 😇 😇
        youtube for Laser Test
        https://www.youtube.com/watch?v=1KxYv2g96GY
        • EasyTargetundefined
          EasyTarget
          AhHA! a 10V pwm input. Same as mine; when I was looking at this last year I'd noted that 10V pwm/analogue seems to be a bit of a standard in the laser world. It's common in many CO2 lasers.
          Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
          PrintPy2024 to the rescue!
          MicroPython based; with simple wiring and and no custom PCB.
          • hectorundefined
            hector
            Something like this would work?
            https://www.amazon.com/Voltage-0-100-Linear-Conversion-Transmitter/dp/B00U7GJDVO
            connected to a fan or heater, take the pwm at 24v and transform it to 0-5V DC
            yamanundefined 1 Reply Last reply Reply Quote 0
            • yamanundefined
              yaman @hector
              @hector
              thanks for you replay
              but this circuit will not work in my case because I don't have Fan 2
              fan 2 I use it for tool 2
              I have heater 6 -7 with 5v PWM
              https://forum.duet3d.com/assets/uploads/files/1570300649740-laser_cable_2.jpg
              • Danalundefined
                Danal
                @yaman said in Add laser for duet2 wifi:
                Sounds like that laser wants 10V in.
                Some want 5V (TTL), some want 10V. The two versions of the circuit above will work for the respective cases.
                yamanundefined 1 Reply Last reply Reply Quote 1
                • yamanundefined
                  yaman @Danal
                  @Danal
                  @EasyTarget
                  @T3P3Tony
                  Thanks for your replay
                  that what I find maybe the real test will be in G code file and let the machine work for hours
                  but first I have to do some work at Firmware
                  Right now I'm at Version 2.0.0-RC2
                  so any Suggestions for good version work fine with 3dprinter and Laser ?
                  EasyTargetundefined 1 Reply Last reply Reply Quote 0
                  • Danalundefined
                    Danal
                    I haven't personally tried laser, so can't comment on releases.
                    I can say I've had very good results using the "latest", including release candidates.
                      EasyTarget @yaman
                      The latest release, always the latest.
                      https://github.com/dc42/RepRapFirmware/releases/latest
                      Duet makes upgrading super easy, there is no real excuse for not upgrading asap and when new releases come out. Currently it is 2.03.
                      This is especially true if doing CNC machine control, Duet3D are pushing heavily in this direction at present and related features are appearing in each new release.
                      If you want to throw caution to the wind, try the latest 2.0x Release candidate, but I would avoid the 3.0 series betas at this time for general users. Though the 3.x series will eventually bring even more CNC related feature goodness.
                      • yamanundefined
                        yaman
                        Laser Engraving picture
                        EasyTargetundefined 1 Reply Last reply Reply Quote 2
                          EasyTarget @yaman
                          @yaman COOL!, it's great when it gets working.
                          Now you have all the tuning fun you could wish for; carving and engraving is much more of a 'craft' than 3d printing, the sheer range of materials and techniques ensures that every job is a one-off. With my printers I strive for reproducibility, but for laser art I want everything to be slightly 'individual', it's part of the charm.
                          • yamanundefined
                            yaman
                            video for the Test
                            • yamanundefined
                              yaman @EasyTarget
                              @EasyTarget
                              thanks for your support ☺
                              otaku521undefined 1 Reply Last reply Reply Quote 0
                              • otaku521undefined
                                otaku521 @yaman
                                @yaman
                                mind sharing your laser part of your config.g? are u running on the expansion board? I am trying to mine to work... but my laser have 2 pin 12v and 2 pin ttl... dont know how to plug this up (heater 7 pwn and gnd?)
                                • gabbieundefined gabbie referenced this topic
