Temp Bug DWC 2.0.0-RC7
The Temperature Tools in RC7 Dashboard doesn't work. Per below the Heater 1 and 2 Active drop-downs do not display the temperature tables. The Standby table works correctly. Same with the Bed temperature.
@balrags can you try version 2.0.0 please:
https://github.com/chrishamm/DuetWebControl/releases/tag/2.0.0
Below is from DWC 2.0.0. I substituted 99 for 100 in the temp table and that displays just fine. Insufficient allocation for 3 digits of text perhaps ?
@balrags
What browser are you using? I just checked on my phone as well as PC and can't recreate it using chrome
I have it happen on my laptop running chrome. The laptop has a display resolution of 2880 x 1920 with a text scale of 200% which is the recommended windows value. It also happens at 175% but not at 150%.
It doesn't happen on my raspberry pi running at 1920 x 1080.
@jay_s_uk ahh ok so i tested scaling the font up, but not up to 150% or bigger.
@chrishamm can you look at DWC handling font scaling?
@T3P3Tony I get this too but I'm on a slightly earlier version of DWC (2.0.0-RC8-b4) and using Firefox. There are certain window widths where I get 3 digits and others where I only get 1 or 2. Toggling side bars on or off has the same effect.
Edit. To test, just click on the active temperature to bring up the drop down list, then drag the right hand edge of the window to make it smaller. It will "jump" to 3 digits at various window widths.
