    1.18 Z height offset question
    1605
    • mhackney
      mhackney last edited by
      David and all, I upgraded to 1.18 release this morning from 1.17 on one of my deltas. This printer has FSR/JohnSL probing and calibrates to a deviation of 0.01 and I always got a perfect first layer. I saw in the release notes the comment about Z offset:
      You may find that your Z probe trigger height is slightly higher than before, so you should re-measure it
      With the new baby stepping feature I thought it made sense to proceed and print a single layer object that I use to tune settings and use baby stepping to adjust Z. I did this and had to lower Z by 0.20mm. This seems like a a pretty big difference, what are folks experience with Z probe trigger height in 1.18?
      Now the odd thing and question. I subtracted the extra offset from my G31 Z to get "G31 Z-0.35" in config.g. I deleted config-override.g and restarted and then ran delta auto calibration and committed with M500 (again with a 0.01 deviation). I then attempted to print the single layer object and was surprised to find I needed to baby step down 0.20mm again! I verified that my G31 Z-.35 is in config.g and now in config-override,g. Any idea what's going on?
      cheers,
      Michael
      My 3D Printing blog: http://www.sublimelayers.com
      Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
        Was your G31 Z offset previously -0.15 or -0.55 ?
        0.2mm is a larger change than I would expect.
        • mhackney
          It was previously -.15 mm
            I think that reduction in trigger height was spurious, nothing to do with the firmware upgrade. If anything, the trigger height should be higher using 1.18, not lower.
            • mhackney
              I've gone through the printer mechanics and configs and it is still behaving as described. Multiple deletes of config-override and resets. It's almost as if G31 Z offset is not being applied.
              • mhackney
                David, I downgraded to 1.17 and my original Z offset is working perfectly. I'll re-convert to 1.18 when I get time early this week and try again.
                  Michael, have you tried printing using 1.18 and your old height offset?
                    @mhackney:
                    That can happen if you put the G31 command earlier in config.g than the M558 command. This is because RRF stores different G31 parameters for different types of Z probe, to allow you to use more than one probe.
                    • mhackney
                      @dc42:
                      David, yes that is actually what I was trying to articulate above. With the same height offset I had to baby step down an additional 0.20mm. If I then change my height offset to -.35mm I STILL have to baby step down .20mm. That's what's strange. I see your second post about order so let me verify that, although once committed to config-override.g the correct order is captured, correct?
                      • mhackney
                        @dc42:
                        @mhackney:
                        Understood and I do have them in the correct order. I actually take advantage of the ability to support different probes on one of my test machines that has the IR probe, FSRs and an accelerometer probe on it so I can do comparisons. On this machine I have:
                        [[language]]
                        ; Z probe and compensation definition
                        M558 P4 X0 Y0 Z0 F250 H3 I1 T3500
                        ; grid compensation
                        M557 R110 S15
                        G31 T4 X0 Y0 Z-.20			; Set the z probe offset and threshold
                          As long as you had the correct probe type selected when you sent the G31 command, then M500 will save it correctly in config-override.g. The G31 commands in that file use the T parameter to say what probe type they refer to. As far as I know, that parameter works correctly. If you suspect it doesn't, run G31 Tn where n is your probe type (as in M558 P parameter) and it will tell you the trigger height that it is using.
                          • mhackney
                            Today I built a new CF card from a backup set of config files I had. I turned off the printer, installed the new card and restarted. Verified that there was no config-override.g, checked my offsets, Z height and other calibration settings. All looked good. Calibrated, looked good (0.01 deviation) then I verified height and it seemed spot on. Started a print and the first layer looks fine. I'm waiting for it (1 layer) to complete so I can verify thickness.
                            But it does seem like I must have displeased the 3D Printing Deities this weekend and now I'm back in good standing.
                            • sLpFhaWK
                              sLpFhaWK last edited by
                              hopefully my red head sacrifice takes hold and the gods will be pleased with me. we'll find out tomorrow, I don't wish to pursue any 3d printing tonight.
                              -sLpFhaWK
                              Ultibots K250v
                              Rostock Max v2 Soon to be Full MetalMax
                              Mini Kossel
