    Extruder stopped working
    1.8k
      The easiest way to add another wifi network is through the gcode console.
      Use M587 to add the new SSID. At boot time, the Duet should choose the SSID with the strongest signal.
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
      Corexyundefined 1 Reply Last reply Reply Quote 1
      • Corexyundefined
        Corexy
        Belay this one, all good now
        It's never ending...
        Now when I try to open the DWC, I get this message:
        Browsing via the MMS proxy is not allowed. Please use the browsing proxy 10.1.1.181
        And that address won't open either. I was only on there a minute ago.
        Any suggestions (and thanks again for all your help)?
        • Corexyundefined
          Corexy @Phaedrux
          @Phaedrux said in Extruder stopped working:
          Mate, you're an absolute champ! (don't mean to gush).
          It's all working, and surprisingly my old Samsung Galaxy S6 with custom ROM absolutely pounds out a strong wifi signal.
          Obviously I've got to re terminate these cables and setup all my homing files etc, but I'm seeing a light at the end of the tunnel.
          I won't say "one last thing", because it's possible it won't be, but is there a way to revert the DWC back to the old format without losing any functionality? I'd really just prefer to see the old school screen, I was pretty familiar with that.
          • Corexyundefined
            Corexy
            OK, so straight back into trouble.
            I'm trying to calibrate the Z probe trigger height, and it's not playing the game at all. I've done this procedure plenty of times in the past.
            I'm raising it until I grip the sheet of paper, then G92 Z0, down 10mm, then G30 S1 and that's where it plays up.
            Instead of just staying in the center of the bed and lowering the nozzle to the bed (or raising the bed to the nozzle), it tries to home X, then Y, then moves to a random position and lowers the nozzle just a little.
            Never seen it do all that from G30 S1 before...can anybody help?
              jay_s_uk
              should be G30 S-1
              Corexyundefined 1 Reply Last reply Reply Quote 0
              • Corexyundefined
                Corexy @jay_s_uk
                @jay_s_uk said in Extruder stopped working:
                should be G30 S-1
                Cheers mate. It actually did exactly the same thing with that command too.
                Wondering what I'm missing here
                • Corexyundefined
                  Corexy
                  I'd call the extruder issue resolved, and I'll start anew with my tuning issues in the tuning and tweaking section.
                  Thanks for the help Phaedrux, appreciated
