Extruder 0 reports little movement
I have started to get the error, "Extruder 0 reports little movement" at the beginning of a print. Everything would heat up, It would do a line or two of purge, then it would flash the error and the print head would go to the upper left corner of the bed and stop. It .Just started out of no where. I have the extruder calibrated so I am getting almost exactly 100mm on a 100mm extrusion command. I tried using a new start gcode in Cura, but that didn't change the result either. I have included the M592 D0 results, my config.g file and the starting gcode from the file in question.
Thanks for the help!
PatM591 D0
Duet3D laser filament monitor v1 on input 3, enabled, allow 10% to 300%, check every 3.0mm, no data receivedConfig.g
; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 Pe3 ; Set machine name
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes backwards
M92 X80.00 Y80.00 Z400 E95 ; Set steps per mm
M566 X1000 Y1000 Z100 E30000 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z500 E1500 ; Set maximum speeds (mm/min)M201 X300 Y300 Z100 E5000 ; Set accelerations (mm/s^2) was 500 you changed it to 300 for stall guard
M906 X500 Y500 Z500 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S300 ; Set idle timeout; Axis Limits
M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
M208 X258.5 Y246 Z260 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S1 ; Set active high endstops; Z-Probe
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M307 H4 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M307 H1 A373.9 C115.3 D4.9 V23.8 B0
M307 H0 A126.1 C599.1 D0.4 V23.0 B0
M558 P9 H2.5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
G31 P25 X-31 Y0 Z3.457 ; Set Z probe trigger value, offset and trigger height
M557 X50:185 Y50:185 S65 ; Define mesh grid; Heaters
M143 H1 S345 ; Set temperature limit for heater 1 to 345C; Fans
M106 P0 S0 I0 B0.5 F250 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 B0.5 F500 L255 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Minimum Speed is 1/3 aka 87 Thermostatic control is turned on triggered at nozzle temp 45;
M106 P2 S0 I0 B0.5 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings
M591 D0 P5 C3 R10:300 E3.0 S1 ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 3 (E0), tolerance 10 to 120%, 3mm comparison lengthStarting GCode
; Ender 3 Custom Start G-code
G28 ; Home all axes
G92 E0 ; Reset Extruder
G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
; End of custom start GCode
I guess the issue is with your laser monitor.
Which firmware version are you on?
Interesting thing is I don't have a laser monitor hooked up and not even sure what it is. I would assume it monitors filament run out.
Firmware Version: 2.04RC3 (2019-10-08b3)
WiFi Server Version: 1.23
Web Interface Version: 1.22.6
@BearcatTD Well then I would comment it out and try again
Thanks! What file is this located in?
@BearcatTD M591 in the config file
Duh...LOL. Thanks Jay!
