laser as z probe
Hello
I'm building a selfmade 3d printer.
It's a cartesian printer, with y axis moving the bed and x and dual z the extruder.
Board: Duet ethernet 1.21 (currently working on implementing 2.03)My question is, if it'd be possible to use a laser as the z probe instead of a normal z probe.
I'm using the il-300 with the il-1500 by keyence. it's already showing me the distance between the laser and the bed, but i don't know how to wire the laser to the board and how to change the firmware.
Any help would be much appreciated.
Thanks!
@chilli I can't imagine that these sensors output any kind of data which the Duet's firmware would understand.
Without support for these devices being implemented in the firmware, it would seem unlikely that you could use them. Most of the sensors which are supported tend to output either a voltage based signal or a digital signal. I'm guessing from the Keyence web site that these actually output measurement data in a text or binary format.
(I can't be 100% sure about this, as Keyence won't let me download any datasheets without creating an account, and I'm not going to do that.)
@chilli said in laser as z probe:
il-300
I would imagine you would need to use a raspberry Pi type device and program it to understand the signal put out by the il-300. Then have the Pi talk to the duet through serial communication in the form of Gcodes.
Anything is possible if you want to put the effort into it....
i will be able to get the datasheet tomorrow, to see what output i can get from the laser.
what type of output would i need to communicate with the duet?
@chilli Have a look at the following two pages:
https://duet3d.dozuki.com/Wiki/Choosing_a_Z_probe
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probeYou'd need to find some way to make the sensor support one of the interfaces which already exist.
Most interfaces are very simple and emulate a switch, so all they tell the Duet firmware is that the sensor has been triggered (i.e. has sensed the surface of the bed.)
It may be possible to do something with a Pi, but if you are emulating a probe and need to convert the data from the sensor into a simple switch, the time taken to do that conversion could introduce delay and inaccuracy.
It's hard to speculate without knowing how the laser sensor talks to things.
A Pi is MASSIVE overkill.
An Arduino micro or an ESP8266 or even ESP32 is still overkill; still, I'd lean toward them simply because they are available at quite low prices in "quick ship" retail channels. Example: They are in the $4 to $6 area, qty 1, from vendors like Amazon.
Get the datasheet for the laser, and in all likelihood, we can put a wiring diagram and a simple sketch (arduino program) in this discussion thread.
@chilli Can you order from US amazon? If not, in what country are you?
I'm based in Germany.
Got an arduino uno flying around here, so could use that if necessaryI changed from the il300 to an il100, cause of the range of the laser
Also uploading the datasheets and the manuals of bothPage 5 of the il1500 manual: As far as I can see, the il1500 can give out an analog output from 0 to 5V. I can also set a low and max point, inbetween its giving out a go signal.
Maybe I could use one of themAS_107023_IL_IM_96M13643_GB_1109-3a.pdf
IL-100_Datasheet.pdfI can upload the datasheets also in german/other languages if that helps
I looked into laser distance sensors several months ago, especially as there are some low cost ones around now. The main problem is that you need extremely high resolution, repeatability and temperature stability.
Let's start from first principles. The speed of light in vacuum or air is very close to 1 foot per nanosecond. So each nanosecond of measured time is 300mm of distance there and back, or 150mm one-way. Therefore each picosecond represents 150 microns of distance. If we take 30 microns as the required repeatability of Z probing (and some types of Z probe are better than this), this means that your measurement system needs a resolution and stability of about 200 femtoseconds. Even if you can achieve this resolution, it's most unlikely that you will achieve this stability.
@dc42 said in laser as z probe:
but i'm using the il1500 to read the measurement of the laser (il100). i can give out an analog high signal if a preset distance is reached. Wouldn't it be possible to to read the analog signal with the duet?
should workk like a switch then or not?
@chilli The analogue output would indeed work like a switch and the Duet could read that. (You may need to scale the voltage down to 3.3V for the Duet, depending on which input it is connected to and the version of your Duet.)
It's interesting to see how they've used a triangulation technique to get around the problem that David raised regarding simple reflection measurements and the difficulty of measuring femtosecond time differences. That the sensor you have has a repeatability of 4 microns is very impressive and certainly makes it a candidate for a good bed probe. (The printing surface may be important though.)
To get an idea about how fast an Arduino can deal the different measurements from a laser sensor, you can see this video: Measure Distance with VL53L0X 6 pin Laser module with Arduino
Although the VL53L0X sensor is very accurate and
(in my opinion the best laser sensor for a 3d printer due to its extremely tiny size) Arduino can't manipulate the measurements fast enough. (you can see the rate that the measurements appeared on the screen). However, I think that the VL53L0X sensor definitely could be used for that purpose maybe with another microcontroller ...
should workk like a switch then or not?Yes you can feed an analog voltage in the rang 0 to 3.3V into the Duet Z probe input. But you've totally ignored the point I was making.
@dc42 I didn't quite get what you meant, sorry
what would happen if you feed a negative voltage (-3,3V) into the Duet Z probe input?
What David tried to make clear to you:
While it may be perfectly possible (from a wiring and software point of view) to use this laser sensor as a z probe, it may actually be quite unusable because your setup needs a timing resolution of at least 200 femtoseconds (read: 0,000 000 000 000 200 seconds) - and must be reliably reach this resolution for every measurement taken. On this scale small variations in timing imply huge differences in the measured distance.You can clearly see the effect in a demo
https://www.youtube.com/watch?v=S2jaAQEv3Yo&feature=youtu.be&t=510
where the measured distance deviates in millimeters.
@themelle I think the sensor @chilli wants to use does not work by the Time-of-Flight principle like the VL53L0X.
It probably uses triangulation / measureing the reflection angle by distance via a CMOS image sensor.
I saw a video about a similar sensor a while ago: https://youtu.be/0D9nJIzNVTY?t=130
@hurzhurz yes that one looks kinda similar. And that principle would work?
@themelle @dc42 Do you know what would happen if I feed negative voltage (-3.3V) into the Z probe input?
Probably nothing, because the ESD protection diode in the MCU will protect the input. But for safety, you could use a series resistor and a Schottky diode to ground.
Yes I was assuming that it is a time of flight sensor.
@chilli Yes, I think so. Though, the needed resolution of the image sensor probably needs to be very high to achieve this crazy measurement resolution of 2-4µm... maybe they also use some clever algorithms to interpolate.
I just found this video with an illustration: https://youtu.be/g-EJ4FDB4qQ?t=34
I've been trying out a bit and it seemed to kinda work. I'm getting a signal in.
Can't work on it till probably next week, cause the z-axis clutch broke.Another thing is, that the laser is giving 0V if the distance is 0. if it's more than 0 the voltage rises till 5V and stays there and same with negative, falling to -5V.
As the z probe input works with 3.3V i was thinking about using a resistor to ground and also in series a schottky diode for the negative voltage (thanks for that info @dc42).
I'm just not sure about what resistor and what diode to use. Any suggestions?What current does the input draw at 3.3V?
maybe this schottky diode:
https://www.conrad.de/de/p/panjit-schottky-diode-gleichrichter-1n5817-do-41-20-v-einzeln-1304858.html
Do you really need to deal with negative output voltage?
Pages 5&6 in the il1500 manual it look like you can set different output voltage range modes:
- 0V to 5V
- -5V to +5V
- 1V to 5V
So I think you can simply use the first one together with a voltage divider?
Well, any maybe you could simply use the digital output "LOW/HIGH judgment output".
Here you could use a optocoupler for isolation between it and the duet.
@hurzhurz yes these modes are possible to set, but the problem is that the voltage stays after the set point is reached.
For example 0-5V: above 0 the voltage is 0V, the closer it gets to 0 the voltage rises (the point from which is the voltage rises can be set too) : 10mm 0V; 5mm 2,5V 0mm 5V.
If the distance gets negative the voltage stays 5V
So I thought it would be better that the voltage above and below 0 would change, so that it doesn't get too deep and still thinks it's at 0 distanceNot sure if I was able to explain it understandably...
The idea with the digital output and the octocoupler sounds possible, will try that!
@chilli I hope I understood it correctly, but I would do it like this for the analog output way:
For your example values: 10mm=0V / 5mm=2,5V / 0mm=5V
I would define the middle (5mm) as my target trigger point and later set my probe height offset accordingly (G31 Zxxx).
Therefor I would adjust the probe trigger value (G31 Pxxx) so it matches the value that the duet measures at 2,5V (or 1,65V in case of an ideal voltage divider).
This way, you can see if you are below or above the trigger point.Btw, we could also have a conversation in German if that helps...
I checked the optoNCDT sensor, they start used at 400$ (older models than the one mentioned in the video). Does someone have cheaper solutions with the same high resolution?
@hurzhurz yeah i think you got me right. that could actually work too.
In what unit would i put the trigger point value (behind the P of G32 Pxxx)?
Or is it just 0?
I think german would be easier, but english would be better for the others here@JoergS5 Sorry, don't have any solutions for that
@dc42 What current does the duet draw at the 3.3V Z probe input?
