    Dual color direct drive switching extruder.
    Example setups and prints
    1.2k
    • JLink33undefined
      JLink33
      I have been experimenting lately using a bowden extruder to push filament into a BMG which then extrudes the filament (see pics). It worked the first time without fuss. I have worked with the prusa MMU and various "switching" nozzles with little success. Other than the MMU, TPU was not viable and I had lots of jams and lack of tolerance. The MMU was a little over-engineered for me which in concept works well, but the inaccuracies of real-life made it unreliable.
      Anyways, to start, I am running a Duet 2 wifi with a Duex 5 add-on board. My loading extruders are 1:1 geared 3D printed bondtech bowden extruders and my printing extruder is the 3:1 geared bondtech BMG extruder direct drive. My hotend is an e3d v6 with copper heatblock, 50W heater, and nozzle X nozzle. The build volume is 300 x 300 x 400 mm^3. Right now I am running two feeding hotends, but in the future I will run up to 6 because I can.
      How it works. The feeder extruders each have a filament loaded partially into the first length of bowden. Each tool has two drivers running simutaneously in mixing mode with a 1:1 mix ratio. When tool 0 is selected, E drivers 0 and 1 are running. When tool 1 is selected, E drivers 0 and 2 are running... etc. When a tool is selected, both motors push the filament through the bowden splitter and into the BMG, out the nozzle. The benefits of this is that I maintain the direct drive setup and no longer have to maintain tight tolerances in the bowden tubes or the splitter wich is where most clogs come from.
      In the future, I plan to add limit switches for clog detection and peace of mind.
      Let me know what you guys think.
      Thanks
      1 Reply Last reply Reply Quote 4
        Looks good!
        • oliofundefined
          oliof
          Interesting! Any issues tuning the extruders with the different steps / mm?
          JLink33undefined 1 Reply Last reply Reply Quote 0
          • Danalundefined
            Danal
            Very nifty. Keep us posted.
            Let's see some prints!!
            • JLink33undefined
              JLink33 @oliof
              @oliof Theoretically the extruder motor moves 1/3 of a step faster, but because it is geared, I do not think it is a problem. Other than that, the extruder calibration is the same.
              • oliofundefined
                oliof
                Raise, thread! @JLink33 would you be sharing your configuration for this setup? I'm looking into replicating it ...
                • fmaundefined
                  fma
                  How do you manage the tip when removing filament? I always have troubles... I'm working on such system but with 6 filaments.
                  Frédéric
                  • Gordon Linundefined Gordon Lin referenced this topic
