    Duet 2 Wifi with SE300
    462
    • PixelGl1tchundefined
      PixelGl1tch
      Hey gang, so I just upgraded my Rostock Max to a Duet2 Wifi + SE300 hot end. I have most everything working correctly it seems minus my extruder, which I'm not overly concerned about yet, and the hot end. When I fire up the hot end it immediately skyrockets in temperature until my it auto-shuts down. Even if I put it at 100C it will do the same. I just went through the auto-tune, which also errors out. Anyone have any ideas or can share the settings I should use for the SE300 hot end through configurator? Any help is MUCH appreciated!
      Results of Auto-Tune:
      11/18/2019, 8:01:55 PM Warning: Auto tune of heater 1 failed due to bad curve fit (A=3742.7, C=144.7, D=4.7)
      11/18/2019, 7:59:40 PM Auto tune phase 3, peak temperature was 329.5
      11/18/2019, 7:59:29 PM Auto tune phase 2, heater off
      11/18/2019, 7:59:12 PM Auto tune phase 1, heater on
      11/18/2019, 7:59:06 PM M303 H1 S240
      Auto tuning heater 1 using target temperature 240.0°C and PWM 1.00 - do not leave printer unattended
        PixelGl1tch
        I have since changed the PID to 25% and located and selected the e3d thermistor in the configurator, still no change to the outcome and cant find any info on recommended se300 settings.
          dc42 administrators @PixelGl1tch
          Is your printer still running from 12V, or have you upgraded it to 24V? It looks like the heater is way overpowered.
            PixelGl1tch
            It is a 24v power supply, which I thought was fine per the wiring diagram sheet (12-25v input). Please excuse my ignorance, your help is greatly appreciated. Does this mean that I would need to replace it with a 12v power supply?
              PixelGl1tch
              I should also point out that the heated bed heats up normally, and seems to be just fine. It is only the hot end that is having a problem.
                jay_s_uk
                Well you would either have to change to a 12v PSU or upgrade whatever 12v parts you have to 24v.
                This would typically be the heater cartridge and fans
                  PixelGl1tch
                  Exactly what I needed to know, thanks a bunch. I have purchased two genuine e3dv6's throughout my time and they both accepted 12v or 24v. When I saw that e3d designed the hot end for the se300 I just assumed it too would be the same. It does indeed look like the heater cartridge that comes with the se300 is 12v only, which would explain my problem here.
                  I THINK that my bed is 12v or 24v, but I will verify when I get home. Other than the duet wifi + SE300 (which includes fans) & whip, everything else on my printer is the same, and has been running off of the 24v supply.
                  If my bed can pull enough power to heat to sufficient temps, I would think I shouldn't have to worry about replacing any additional components to power off of 12v instead. Does this sound right?
                  • A Former User?
                    A Former User
                    Uhm, are you sure the same heater can accept 12v and 24v; and not that its just possible to order them with 12v or 24v? Such a heater cartridge would have to have three terminals somehow.
                    Some beds are dual voltage, but would need to be rewired to change from 12v to 24v, typically a solder bridge or jumper wire.
                    Any 12v fans would have to be replaced or powered off a 12v source or they'll be short lived.
                      PixelGl1tch
                      Regarding the hotends - It is quite possible I got that incorrect, and just got lucky when I ordered them in the past. Thanks for the tip about switching the wiring around on the bed if it is indeed dual voltage. I will check it out when I get home and see what I am working with, but I think it may be this one, which is designed for 12v, but says you can just limit the PWM signal at 24v to keep things in check.
                      https://www.seemecnc.com/products/rev8-onyx-heated-bed-revision-8-discontinued-eol?_pos=4&_sid=43a9540af&_ss=r
                      I would suspect that if it is not safe practice, that they wouldn't mention it on the product page, but if it's not for whatever reason I would appreciate a heads up. You guys rock, thanks for the help!
                      • A Former User?
                        A Former User
                        You can limit the PWM duty cycle to use a 12v heater with a 24v supply; however its only the firmware keeping them in check, a thermal fuse is highly recommended.
                        Review the P parameter for M303
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M303_Run_heater_tuning
                          PixelGl1tch
                          So it turns out my bed is indeed a 24v - I went ahead and converted an old xbox PSU to a 12v supply and hooked it up. Everything is now functioning properly with the inconvenience of my bed heating rather slowly. It still reaches and maintains 60-70C which is plenty considering I almost exclusively print with PETG. The trade-off of the noise from my 24v to the complete silence of my 12v is worth it alone IMHO. I may look at replacing my bed later on down the line, but foresee this being suitable for the near future. Thanks to everyone for your help, greatly appreciated.
