    Home all not working
    1.9k
    • Corexyundefined
      Corexy
      Before I fire this all up again, I haven't done anything with my bed and homing files, and the configurator definitely changed all of them. Before I had it doing a autolevelling routine at the start of a print, and then I had it putting the tool off the the left/back at the end, but I'm pretty sure most of the commands for that are entered in my slicer (S3D).
      bed.g
      This is what I had before:
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool on Sat Oct 22 2016 18:28:19 GMT+1100 (AUS Eastern Daylight Time)
      ; Clear any bed transform
      G29 S2
      ; Home all
      G28
      ; Probe the bed
      G29
      ; Absolute positioning
      G90
      ; Go to center bed probe point and home the Z axis
      G1 X97.5 Y97.5 F4800
      G30
      ; Uncomment the following line to lift the nozzle after probing
      G1 Z50 F500
      This is what I have now:
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v2.1.2 on Thu Nov 21 2019 10:53:55 GMT+1100 (Australian Eastern Daylight Time)
      G29 ; probe the bed and enable compensation
      homeall.g
      ; homeall.g
      ; called to home all axes
      ; Relative positioning
      G91
      ; Lift Z
      G1 Z1 F1200
      ; Move towards X and Y axis endstops (first pass)
      G1 X-200 Y-200 F4800 S1
      ; Go back a few mm
      G1 X5 Y5 F4800
      ; Move slowly to axis endstops once more (second pass)
      G1 X-200 Y-200 F360 S1
      G90
      G30
      G1 Z50 F1200
      ; homeall.g
      ; generated by RepRapFirmware Configuration Tool v2.1.2 on Thu Nov 21 2019 10:53:58 GMT+1100 (Australian Eastern Daylight Time)
      G91 ; relative positioning
      G1 H1 X-200 Y-200 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-200 Y-200 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 H2 X97.5 Y97.5 F6000 ; go to first bed probe point and home Z
      G1 S2 Z5 F100 ; lift Z relative to current position
      I'm wondering if I should be looking at all these as well?
        The old bed.g file looks like you could continue using it.
        The old homeall.g file lacks the H2 parameter for the initial Z axis lift. This would throw an error in recent firmware for trying to move an axis before it's been homed. But otherwise they are basically the same, so you should probably just keep using the new one.
        • Corexyundefined
          Corexy
          Cheers Phaedrux,
          So I might as well just keep using the new bed and homing files? They're the one's it's running at the moment, so if there's no reason to change I won't. Just looking at what can be tidied up before I save a copy of this.
          I've also got a "homedelta.g" file in there. Can that be deleted?
            Phaedrux Moderator @Corexy
            @Corexy said in Home all not working:
            Yes If you do not have a delta you can delete it.
            • Corexyundefined
              Corexy
              Thanks guys,
              All good and knocking out a reasonably tidy print if I say so myself. Bed leveling ran in the start of the print, can't tell if it set up a map or not.
              One issue I'm having that is after using the e stop to cancel a print, I can't move my Z axis up and down. I have to switch off the machine and star it again to get operation.
              What have I missed here? The Z axis worked before in any order of operation.
                dc42 administrators @Corexy
                Axes cannot be moved until they have been homed, unless you either use G1 H2 movements or you use M584 M564 to allow axis movement before homing. Emergency stop sends M112 to do the stop followed by M999 to reset the controller.
                Corexyundefined 1 Reply Last reply Reply Quote 0
                • Corexyundefined
                  Corexy @dc42
                  @dc42 said in Home all not working:
                  Axes cannot be moved until they have been homed, unless you either use G1 H2 movements or you use M584 to allow axis movement before homing. Emergency stop sends M112 to do the stop followed by M999 to reset the controller.
                  No worries David, thank you.
                  I do recall an M584 back on the old config.g somewhere, and as I'm the only one who uses this machine I'd like to remove the limitation. So where would I put the M584 command?
                  Now I'm retuning the heaters, which I haven't done for years or at all on this board.
                  What I'm worried about is that why the extruder (PT100/H1) and bed (thermistor/H0), both have the same "B0", meaning they are both operating by PWM? Shouldn't the bed be different (B1 or something) due to the thermistor? The M307 H1 settings are from my first hot end heater test, and I'll run it a second time once it's all cooled down. Haven't done the bed yet.
                  M143 S280 ; Set maximum extruder temperature to 280C
                  M143 H0 S140 ; Set maximum bed temperature to 140C
                  M305 P0 T100000 B4000 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 0
                  M305 P1 X200 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 200
                  M307 H0 A144.9 C625.3 D1.0 B0
                  M307 H1 A895.8 C393.4 D6.1 V24.3 B0
                    M584
                    It's actually M564 to allow moving an axis before being homed or to allow an axis to move beyond the travel limit.
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M564_Limit_axes
                    You can place M564 H0 in config.g
                    B0 is fine for both bed and extruder. B1 would be bang bang and is not recommended.
                    • Corexyundefined
                      Corexy
                      Thanks very much, appreciated.
                      So just a "M564 H0" in general preferences, just after M83?
                      I'm also getting another odd fault message come up:
                      "attempt to read a gcode unsigned array that is too long M84 P3 E0:1"
                      Any idea what that's all about?
                        Yes M564 H0 can go there.
                        Can you post your config.g as it currently is? It would seem you might have two lines superimposed to cause that M84 P3 error...
                        • Corexyundefined
                          Corexy @Phaedrux
                          @Phaedrux said in Home all not working:
                          Sorry mate, been busy with work and haven't had time to turn the printer on.
                          config.g as it stands right now:
                          ; Configuration file for Duet WiFi
                          M550 P"Zortrax M200" ; Set machine name
                          M552 S1 ; Enable network and acquire dynamic address via DHCP
                          M584 X0 Y1 Z2 E3 ; Set drive mapping
                          M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation
                          M92 X80 Y80 Z800 E122 ; Set steps per mm
                          M566 X1600 Y1600 Z12 E800 ; Set maximum instantaneous speed changes (mm/min)
                          M203 X18000 Y18000 Z1200 E8000 ; Set maximum speeds (mm/min)
                          M201 X1200 Y1200 Z20 E1200 ; Set accelerations (mm/s^2)
                          M906 X1100 Y1100 Z800 E600 I30 ; Set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M574 Z0 S0 ; Define active low and unused microswitches
                          M574 X1 Y1 S1 ; Define active high microswitches
                          M208 X195 Y195 Z175 S0 ; Set axis maxima
                          M558 P1 X0 Y0 Z1 H5 F600 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                          G31 P500 X0 Y0 Z2.82 ; Set Z probe trigger value, offset and trigger height
                          M557 X20:180 Y20:180 S40
                          M307 H1 A892.1 C396.5 D6.4 V24.3 B0
                          M563 P0 D0 H1 ; Define tool 0
                          G10 P0 X0 Y0 ; Set tool 0 axis offsets
                          T0
                          • deckingmanundefined
                            deckingman @Corexy
                            When do you get that message? i.e. what do you do (if anything) that causes it to pop up? What do you get in the console if just send M84?
                              Also, what do you get if you send M98 Pconfig.g in the console?
                              • Corexyundefined
                                Corexy
                                Hi All,
                                Sorry about the delayed response. I'm a farmer, and with Australia's drought at the moment hungry mouths are calling me away from my hobbies.
                                @deckingman
                                "attempt to read a gcode unsigned array that is too long M84 P3 E0:1" was occurring when I used the emergency stop. For some reason it's not doing it today...
                                @Phaedrux
                                M84 seemed to do nothing at all, other than to make all my axis's "unhomed".
                                M98 PCONFIG.G I got the following message:
                                Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 917C.
                                It's all working well enough, but on this last print I just did, the temps of the bed and extruder did not drop to my "layer2" temps, despite them definitely being in my S3D profile and having worked every time before.
                                  That message was generated because E0:1 says you want to work on extruder drives 0 and 1, but in your M584 command in config.g you only define one extruder.
                                  M84 by itself disables all stepper drivers. This has the side effect of marking axes as not homed.
                                  That is a common problem. It means that your heater cartridge is over-powered for your extruder, assuming your printer has an ordinary FDM hot end with an aluminium heater block (which will melt at about 660C).
