mesh grid compensation
  • hello to everyone
    could anyone tell me how to fix thismesh comp.PNG here are my config files
    config.g
    ; generated by RepRapFirmware Configuration Tool v2.0.5 on Sun Oct 27 2019 13:47:05 GMT+0200 (Χειμερινή ώρα Ανατολικής Ευρώπης)
    G21 ; Work in millimetres
    G90
    M83 ; ...but relative extruder moves ; send absolute coordinates...
    M667 S1 ; Select CoreXY mode
    M550 P"Hypercube Evo" ; set printer name
    M552 S1 ; enable network
    M587 S"" P"" ; Configure access point. You can delete this line once connec; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S1 ; physical drive 0 goes backwards
    M569 P1 S1 ; physical drive 1 goes backwards
    M569 P2 S1 ; physical drive 2 goes forwards Z
    M350 X256 Y256 Z256 E256 I1 ; configure microstepping with interpolation
    M92 X1280 Y1280 Z6400 E6500 ; set steps per mm
    M566 X900.00 Y900.00 Z50 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X1000 Y1000 Z1500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X480 Y480 Z600 S0 ; set axis maxima
    M574 X1 Y1 S1 ; set active high endstops
    M574 Z1 S2 ; set endstops controlled by probe
    M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
    M558 P9 Z1 H5 A10 F80 T4000 B1 ;S0.004 ;R0.5 ; set Z probe type to bltouch and the dive height + speeds
    G31 P30 X25 Y0 Z2.4 ; set Z probe trigger value, offset and trigger height
    M557 X100:290 Y100:290 S90 ; define mesh grid
    M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    T0 ; select first
    M290 S-0.330
    ;M564 H0
    bed.g
    ; bed.g
    G29 ; probe the bed and enable compensation
    ;M401 ; deploy Z probe if necessary
    G30 P0 X30 Y30 Z-99999 ; define 4 points in a clockwise direction around the bed, starting near (0,0)
    G30 P1 X30 Y190 Z-99999
    G30 P2 X190 Y190 Z-99999
    G30 P3 X190 Y10 Z-99999
    G30 P4 X100 Y100 Z-99999 S0 ; finally probe bed centre, and calculate compensation
    M402 ; retract the Z probe
    G1 X30 Y30 F5000 ; move the head to the corner (optional)
    G29 S1
    homeall.g
    ; homeall.g
    ; called to home all axes
    G91
    M280 P3 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
    ;M402 ; Retract probe just in case it's down
    M564 H0
    G1 S1 X-480 F4000 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 S1 Y-480 f4000
    G1 X5 Y5 F6000 ; go back a few mm
    G1 S1 X-480 F360
    G1 S1 Y-480 F360 ; move slowly to X and Y axis endstops once more (second pass)
    G90 ; absolute positioning
    G1 X220 Y220 F6000 ; go to first bed probe point and home Z
    G29 S1
    height map
    RepRapFirmware height map file v2 generated at 2019-11-23 19:35, min error -0.563, max error 0.240, mean -0.102, deviation 0.259
    xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
    100.00,290.00,100.00,290.00,-1.00,90.00,90.00,3,3
    -0.253, -0.399, -0.563
    -0.071, -0.087, -0.144
    0.129, 0.226, 0.240
    please help
    Thank you in advance
    @akisjon is that an acurate representation of how level your bed/gantry is? maybe the bed is not level?
  • i think the bed is centered correctly, i have measured both sides of x and y and are the same distances, i have put a spirit level on the bed and is aligned...you say can be responsible gantry level? the commands into g files are right?
  • @akisjon said in mesh grid compensation:
    Your bed should be levelled. In 3D printing, this means it must be in level with the XY-plane of the printhead. That plane constitutes of the movement along the X and Y axes. For the moment, I assume that your BLtouch returns reliable data - then, you can imagine the coloured part of your height map to be the plane of your printhead, the grid being the plane of your print bed.
    That’s what has caught @T3P3Tony’s attention: it looks like both planes are not in synch. with each other. With a spirit level, you get the bed in parallel with a flat earth, but never exactly to the same height with your print head at all points it can move to.
    So, the first thing to do is to level your bed as is described here. After that, run your mesh grid compensation, but then, please, use some more probing points: with just nine of them, you won’t come too far.
    Talking ‘bout centering the bed: it looks like the center of the coloured height map does not match with the center of your print bed. This can have two reasons:
    1. The tip of your nozzle can reach positions beyond the printable area. Then, the center is not at X240 Y240. Instead, you must determine the min./max. coordinates of your printable area first and then calculate the center coordinates from these.
    2. The BLtouch has an offset to the nozzle - you must take that into account, too.
  • @infiniteloop said in mesh grid compensation:
    i used and other one bltouch from the second printer and i has similar results...
    i have to look how to straighten the bed and gandry.
    Thanks a lot for your answers
    I don’t know your printer, so maybe you should do that, but the main question remains: Did you level your bed as described here before you generate a mesh grid?
    with this guide, no i don't ,because I thought that is only for manual bed leveling and not for bltouch and I didn't read it
  • @akisjon Give it a try! Manual bed levelling is less "manual" than it sounds, it's quite comfortable. Finally, to probe a mesh, a levelled bed is a fundamental prerequisite.
    Hello
    I need help again because I can not make sense of it, I have rebuilt the z crane I have put a third axle, now the motion is smoother, added glass on bed , I have made the cables of bltouch (ver.3.0) twisted and the results are worse than before with previous board (mega 2560) with Inductive Sensor it worked well, I ask for your help
    bed.g
    G28 ; home
    G30 P0 X30 Y100 Z-99999 ; probe near an adjusting screw
    G30 P1 X30 Y250 Z-99999 ; probe near an adjusting screw
    G30 P2 X30 Y400 Z-99999 ; probe near an adjusting screw
    G30 P3 X200 Y400 Z-99999 ; probe near an adjusting screw
    G30 P4 X400 Y400 Z-99999 ; probe near an adjusting screw
    G30 P5 X400 Y250 Z-99999 ; probe near an adjusting screw
    G30 P6 X400 Y100 Z-99999 ; probe near an adjusting screw
    G30 P7 X250 Y100 Z-99999 ; probe near an adjusting screw
    G30 P8 X225 Y235 Z-99999 S3 ; probe near an adjusting screw and report adjustments needed
    M402 ; retract probe
    config.g
    G90
    M587 S"COSMOTE-483A22" P"" ; Configure access point. You can delete this line once connec; enable network
    M584 X0 Y1 Z2 E4 ; set drive mapping
    M566 X900.00 Y900.00 Z290 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z900.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z400.00 E250.00 ; set accelerations (mm/s^2)
    M208 X450 Y470 Z900 S0 ; set axis maxima
    M558 P9 Z1 H5 A10 F160 T5000 ;S0.004 ;R0.5 ; set Z probe type to bltouch and the dive height + speeds
    G31 P80 X25 Y50 Z0.2 ; set Z probe trigger value, offset and trigger height
    M557 X100:400 Y100:400 S50 ; define mesh grid
    T0 ; select first
    M290 S-0.330
    ;M564 H0
    heightmap.csv
    RepRapFirmware height map file v2 generated at 2019-12-15 11:29, min error -1.839, max error 1.072, mean -0.343, deviation 0.741
    100.00,400.00,100.00,400.00,-1.00,50.00,50.00,7,7
    -1.839, -1.556, -1.394, -1.342, -1.271, -1.342, -1.411
    -1.430, -1.152, -0.927, -0.842, -0.817, -0.813, -0.780
    -1.194, -0.850, -0.579, -0.447, -0.379, -0.319, -0.251
    -0.923, -0.506, -0.215, -0.054, 0.047, 0.127, 0.235
    -0.760, -0.339, -0.004, 0.197, 0.316, 0.443, 0.588
    -0.617, -0.132, 0.224, 0.456, 0.570, 0.699, 0.900
    -0.519, -0.035, 0.311, 0.541, 0.680, 0.831, 1.072
  • Moderator
    M290 S-0.330
    Why are you setting babystepping in your config.g?
  • Moderator
    What type of printer is this?
  • @Phaedrux Think it is a Hypercube Evo, looking at his M550
    P.
  • @Phaedrux M667 CoreXY
  • Moderator
    The Z1 is deprecated, so remove that.
    The recommended P value for the BLTouch is P25.
    Your Z trigger height is very low. When the BLTouch is mounted as described in the Antclabs instructions the base of the probe body should be 8mm above the nozzle tip. This results in a trigger height of ~2mm.
    Not that any of that would solve the tilt in your bed.
    You say you have 3 lead screws now with 3 motors? Are you doing automatic leveling?
    https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
  • @Phaedrux said in mesh grid compensation:
    3 lead screws and 1 motor
  • Moderator
    @akisjon Have you leveled the bed frame on the lead screws before belting them together? Does your bed have it's own leveling adjustments?
    no it does not have its own screws on the bed but i think this effect is not a crooked bed . does it have to do with the settings? ,Before i tying them to the strap, i ll check each one with the fixed points of the printer
  • Moderator
    I think that's exactly what you have. The display exaggerates the amount of tilt. The difference is only 2.5mm from low point to high point. You should be able to verify that by moving the nozzle around the bed with and without mesh compensation active.
    How do you plan to level the bed if you don't have adjustment screws for the bed surface and only 1 motor with 3 lead screws?
    as you will understand i'm pretty much unrelated to this guy tell me how to do it? will i just click disable bed compension....and then ? as far as screws i'll put them back on, i had them removed to put spacers
  • Moderator
    G29 will run a mesh probing routine.
    G29 S1 will load the saved heightmap and enable mesh compensation.
    G29 S2 will disable mesh compensation.
    https://duet3d.dozuki.com/Wiki/Gcode#Section_G29_Mesh_bed_probe
  • hello and good year everyone i came again with many corrections but that i dont know how to fix it will help me?
    is she still out of bed?
  • Moderator
    @akisjon That would appear to be sag in the X gantry. No amount of bed leveling will fix that. But mesh compensation should be able to correct for it.
    The question is, does the mesh compensation correct for it correctly or not?
    You can test with an STL like this to verify your first layer across the bed surface quickly.
    bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
    Print it twice, once without mesh compensation, and once with.
  • @Phaedrux In a strange case it prints in both cases but better print when the bed compensation is disable . is it possible?
  • Moderator
    Can you post your current config.g and homing files?
    Did you incorporate the changes mentioned earlier in the thread?
    You may need to do a more detailed mesh with more points.
