    mesh grid compensation
    1.4k
    • akisjonundefined
      akisjon
      @Phaedrux said in mesh grid compensation:
      You should be able to verify that by moving the nozzle around the bed with and without mesh compensation active.
      as you will understand i'm pretty much unrelated to this guy tell me how to do it? will i just click disable bed compension....and then ? as far as screws i'll put them back on, i had them removed to put spacers
        G29 will run a mesh probing routine.
        G29 S1 will load the saved heightmap and enable mesh compensation.
        G29 S2 will disable mesh compensation.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_G29_Mesh_bed_probe
        akisjonundefined 1 Reply Last reply Reply Quote 0
        • akisjonundefined
          akisjon @Phaedrux
          hello and good year everyone i came again with many corrections but that i dont know how to fix it will help me?
          is she still out of bed?
            Phaedrux Moderator @akisjon
            @akisjon That would appear to be sag in the X gantry. No amount of bed leveling will fix that. But mesh compensation should be able to correct for it.
            The question is, does the mesh compensation correct for it correctly or not?
            You can test with an STL like this to verify your first layer across the bed surface quickly.
            bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
            Print it twice, once without mesh compensation, and once with.
            • akisjonundefined
              akisjon @Phaedrux
              @Phaedrux In a strange case it prints in both cases but better print when the bed compensation is disable . is it possible?
                Can you post your current config.g and homing files?
                Did you incorporate the changes mentioned earlier in the thread?
                You may need to do a more detailed mesh with more points.
                • akisjonundefined
                  akisjon
                  config.g
                  ; generated by RepRapFirmware Configuration Tool v2.0.5 on Sun Oct 27 2019 13:47:05 GMT+0200 (Χειμερινή ώρα Ανατολικής Ευρώπης)
                  G21 ; Work in millimetres
                  G90
                  M669 K1 ; Select CoreXY mode
                  M550 P"Hypercube Evo" ; set printer name
                  M552 S1 ; enable network
                  M552 P192.168.1.69 S1 ; Enable network and set IP address
                  M553 P255.255.255.0 ; Set netmask
                  M554 P192.168.1.1 ; Set gateway
                  M587 S"COSMOTE-483A22" P"" ; Configure access point. You can delete this line once connec; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P0 S1 ; physical drive 0 goes backwards
                  M569 P1 S1 ; physical drive 1 goes backwards
                  M569 P2 S1 ; physical drive 2 goes forwards Z
                  M350 X256 Y256 Z256 E256 I1 ; configure microstepping with interpolation
                  M92 X1280 Y1280 Z6400 E6500 ; set steps per mm
                  M566 X900.00 Y900.00 Z290 E120.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z400.00 E250.00 ; set accelerations (mm/s^2)
                  M906 X1000 Y1000 Z1800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M376 H0.591
                  ;M671 X0:0 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                  M208 X440 Y460 Z900 S0 ; set axis maxima
                  M574 X1 Y1 S1 ; set active high endstops
                  M574 Z1 S2 ; set endstops controlled by probe
                  M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                  M558 P9 H4 A6 F120 T4000 R0.2 ;S0.004 ; set Z probe type to bltouch and the dive height + speeds
                  G31 P25 X25 Y35 Z3.930 ; set Z probe trigger value, offset and trigger height
                  M557 X50:430 Y100:420 S80 ; define mesh grid
                  M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
                  M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
                  M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  T0 ; select first
                  ;M290 S-0.330
                  homeall
                  ; homeall.g
                  ; called to home all axes
                  G91
                  M280 P3 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
                  ;M402 ; Retract probe just in case it's down
                  M564 H0
                  G1 S1 X-480 F4000 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 S1 Y-480 F4000
                  G1 X5 Y5 F6000 ; go back a few mm
                  G1 S1 X-480 F360
                  G1 S1 Y-480 F360 ; move slowly to X and Y axis endstops once more (second pass)
                  G90 ; absolute positioning
                  G1 X220 Y220 F6000 ; go to first bed probe point and home Z
                  ;G29 S1
                  homex
                  ; called to home the X axis
                  G91 ; relative positioning
                  G1 S1 X-485 F1800 ; move quickly to X axis endstop and stop there (first pass)
                  G1 X5 F6000 ; go back a few mm
                  G1 S1 X-485 F360 ; move slowly to X axis endstop once more (second pass)
                  G1 Z-5 F6000 S2 ; lower Z again
                  homey
                  ; homey.g
                  ; called to home the Y axis
                  G1 S1 Y-485 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                  G1 Y5 F6000 ; go back a few mm
                  G1 S1 Y-485 F360 ; move slowly to Y axis endstop once more (second pass)
                  homez
                  ; homez.g
                  ; called to home the Z axis
                  G1 X210 Y210 F6000; Move x and Y axis over to bed center so probe is on top of bed
                    @akisjon said in mesh grid compensation:
                    Best to use x16 microstepping interpolated to 256 by the driver. Using x256 on all axis will lead to problems and offers no real benefit.
                    M376 H0.591
                    Your bed taper is set exceedingly low. This could be causing the problems you describe.
                    it is recommended that the taper height be set to at least 20x the maximum error in the height map, so that the maximum amount of the resulting over- or under- extrusion is limited to 5%.
                    Based on your max deviation of 0.6 your taper should be at least 12mm.
                    https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Compensation_Taper
                    Try S40 to increase your mesh resolution.
                    M564 H0
                    This is not needed since your Z moves in your homing files are using the S2 parameter already.
                    The probe points in homeall and homez do not match.
                    akisjonundefined 2 Replies Last reply Reply Quote 0
                    • akisjonundefined
                      akisjon @Phaedrux
                      @Phaedrux thank you very much for your quick answers i will try tomorrow
                      • akisjonundefined
                        akisjon @Phaedrux
                        @Phaedrux So i do all of the changes you suggested and that is the best effect. impresses me is a curve in the back of the bed, do you know what can come from it?
                          The best way to interpret the heightmap visualization is to compare it to an actual print test to see if errors are true to reality and that the correction is being applied successfully.
                          If you print this test twice, once with mesh compensation active, and again with it deactivated, you should be able to tell if things are working properly.
