    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.1k
    • EMRosaundefined
      EMRosa
      Thanks so much for the assist! I’ll try that, but I was using the exact process as listed from
      ps -aux | grep python3
      This lists the process as “python3 location/to/script/script.py”.
      In my case, I was able to put the command line call in another python script and just call it that way. I just wasn’t sure if it would be helpful (or necessary) for execonmcode to be able to send quoted arguments. (Or more likely, if I was doing it wrong. Haha)
      I’ll let you know if adding the path to python helps.
      • wilrikerundefined
        wilriker @EMRosa
        @EMRosa Since you are using pkill you need to use pgrep to find the required command line (it's the same binary that acts different based on which name it is called with but shares common features otherwise). ps is a different tool that uses (and prints) a different format usually dropping the path to the executable. I think there is a flag to ps to add it but I don't know that off-hand.
        Also quotes are not necessary for execonmcode. Quotes are a concept of shells (sh, bash, zsh, fish, etc.) to provide means to human users to provide command arguments containing spaces. If an application runs another application they usually can provide arguments containing spaces without the need for quotes.
        Manuel
        My Tool Collection
        • wilrikerundefined
          wilriker
          Release 5.2.0
          I am pleased to announce release of execonmcode 5.2.0.
          This release uses the latest version of godsfapi and makes use of the filters option in InterceptConnection, i.e. it will only receive those codes the user is interested in. This will significantly lower the the required resources e.g. while running a job.
          As usual the binaries can be found at GitHub Releases page.
          Manuel
          My Tool Collection
          oozeBotundefined 1 Reply Last reply Reply Quote 2
          • oozeBotundefined
            oozeBot @wilriker
            @wilriker at what point in the bootup cycle is execonmcode ready? I created a custom mCode that I'd like to call at the beginning of config.g, but it says it's unsupported. If I call it separately, or at the very end of config.g, it works correctly.
            Any thoughts?
            • wilrikerundefined
              wilriker @oozeBot
              @oozebot I think that primarily this depends on when execonmcode is started relative to startup of DCS. Or maybe DCS will even delay accepting API clients until a certain amount of startup tasks have been processed. @chrishamm should be able to give more insights on that.
              Manuel
              My Tool Collection
              • chrishammundefined
                chrishamm administrators @wilriker
                @wilriker If ExecOnMCode is installed as a DSF plugin (will be officially supported in 3.3), it's started by DuetPluginService which is started by multi-user.target. Note that v3.3 will introduce /sys/dsf-config.g as well which is executed as soon as all the enabled plugins have been started.
                Previously plugins were started by DCS, so by basic.target AFAIR.
                @oozeBot Either move your custom codes to dsf-config.g if you're on pre-3.3 and/or add a delay to the end of your config file to make sure ExecOnMCode has been fully started before they're executed.
                Duet software engineer
                oozeBotundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
                • oozeBotundefined
                  oozeBot @chrishamm
                  @chrishamm @wilriker - thank you both. We are just about to begin testing the 3.3 betas. This may need to be postponed until after it is released.
                  • wilrikerundefined
                    wilriker @chrishamm
                    @chrishamm As of right now ExecOnMCode is a simple API client just connecting to the socket. It is not yet converted to an official plugin. It will be started by a user-provided systemd unit (or arbitrary other means) completely independent of DCS.
                    Manuel
                    My Tool Collection
                    • CrazyCreatorundefined
                      CrazyCreator
                      @wilriker
                      I once wrote you a PM in German. because I don't know if you understand what I am writing via google translator 😉
                      @All
                      I would like to send an http command using the Mxxxx command.
                      Let's assume I've installed everything as shown in the video linked here.
                      What do I have to enter where and how around this line:
                      http://IP.Adrresse.Of.Shelly/relay/0?turn=off
                      to be able to send?
                      P.S or edit or next step
                      i installed the ExecOnMCode with help of the two videos. but the shutdown (poweroff) with M7722 don't work for me.
                      The Service is running:
                      but in DWC i see this message:
                      M7722
                      Warning: M7722: Command is not supported
                      And the Raspi is still working/running.
                      On Terminal (connected with Raspi) i see:
                      pi@CCC:~ $
                      2021/05/18 22:24:53 Connection to DCS closed
                      2021/05/18 22:24:53 EOF
                      pi@CCC:~ $
                      http://www.crazycreatorcube.com
                      wilrikerundefined CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
                      • wilrikerundefined
                        wilriker @CrazyCreator
                        @crazycreator So, if you want to make a simple HTTP/GET call I'd say you need a cURL or wget command:
                        execonmcode -mCode 1234 -command 'wget -O /dev/null "http://IP.Adrresse.Of.Shelly/relay/0?turn=off"'
                        If you want to put that into the ExecStart line of a systemd unit you have to deal with systemd's escaping syntax. That will be a bit ugly but doable. Otherwise you could move the wget call into a simple bash-script and call that - one for on and one for off.
                        Manuel
                        My Tool Collection
                          CrazyCreator
                          Ok .. sounds good.
                          But actually the script is not running correct ... the error popup on web-gui is the only reaction when I send M7722. The Raspi don't shut down or restart after this M7722 command.
                          the terminal show what you see on my terminal screen in my last posting
                          pi@CCC:/usr/local/bin $ sudo ./execonmcode -mCode 7722 -command "poweroff"
                          2021/05/19 20:47:59 Connection to DCS closed
                          2021/05/19 20:47:59 EOF
                          I think that's the problem. But i have no idea how to fix this.
                          I did the installation exactly as shown in the video.
                            CrazyCreator
                            nobody answer me? 😞
                            when i try the command in terminal, connected with the Pi, with additional parameter
                            i see this output
                            pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command poweroff -debug -trace
                            2021/05/20 15:54:21 7722: poweroff
                            2021/05/20 15:54:21 [DEBUG] <Recv> {"version":11,"id":20}
                            2021/05/20 15:54:21 [DEBUG] <Send> {"Mode":"Intercept","Version":7,"InterceptionMode":"Pre"}
                            2021/05/20 15:54:21 [DEBUG] <Recv> {"success":true}
                            2021/05/20 15:54:21 [DEBUG] <Connect> Connection established
                            but the Pi don't reboot or shut down ... no reaction
                            on dwc the same ... no reaction
                            • wilrikerundefined
                              @crazycreator Can you check if the command poweroff does work on your system in the first place?
                              Also please check execonmcode version (parameter -version). It looks to me as if you are using an older version.
                              Manuel
                              My Tool Collection
                              CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                                CrazyCreator @wilriker
                                @wilriker said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                                How can i do this?
                                pi@CCC:~ $ sudo /usr/local/bin/execonmcode -version
                                2021/05/20 16:20:43 0x24142bc
                                pi@CCC:~ $
                                • wilrikerundefined
                                  @crazycreator said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                                  How can i do this?
                                  Run sudo poweroff and check what that does.
                                  pi@CCC:~ $
                                  That looks like a bug in previous version and it may be that DCS is rejecting this client. Please get the version 5.2.0 of execonmcode from GitHub and try again.
                                  Manuel
                                  My Tool Collection
                                    @wilriker I used 5.1 so that I could imitate the tutorial 100%. now I'm back on 5.2
                                    sudo poweroff
                                    pi@CCC:~ $ sudo poweroff
                                    Connection to ccc.local closed by remote host.
                                    Connection to ccc.local closed.
                                    Versionscheck
                                    pi@CCC:~ $ sudo /usr/local/bin/execonmcode --version
                                    5.2.0
                                    Debug and Trace
                                    pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command -poweroff -debug -trace
                                    2021/05/20 16:35:27 7722: -poweroff
                                    2021/05/20 16:35:27 [DEBUG] <Recv> {"version":11,"id":21}
                                    2021/05/20 16:35:27 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                                    2021/05/20 16:35:27 [DEBUG] <Recv> {"success":true}
                                    2021/05/20 16:35:27 [DEBUG] <Connect> Connection established
                                    put the M7722 command in DWC Console ... show me this in terminal
                                    2021/05/20 16:35:58 Connection to DCS closed
                                    2021/05/20 16:35:58 [DEBUG] <Close> Closing connection
                                    2021/05/20 16:35:58 EOF
                                    • wilrikerundefined
                                      At least this time you used -poweroff which most likely is not a valid command. 😉
                                      Manuel
                                      My Tool Collection
                                        @wilriker
                                        but in shutdownsbc.service is used and in the video tutorial too.
                                        What should I write / use that instead?
                                        What else can I try to get the script to work?
                                        • wilrikerundefined
                                          @crazycreator Just remove the dash from the start of poweroff then it should work.
                                          Manuel
                                          My Tool Collection
                                            @wilriker
                                            you mean so:
                                            2021/05/20 18:47:03 7722: poweroff
                                            2021/05/20 18:47:03 [DEBUG] <Recv> {"version":11,"id":80}
                                            2021/05/20 18:47:03 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                                            2021/05/20 18:47:03 [DEBUG] <Recv> {"success":true}
                                            2021/05/20 18:47:03 [DEBUG] <Connect> Connection established
