Filament Problems
I started a print today and had this popup with the error: "Attempting to extrude with no tool selected"
Looked online and saw that I needed to add filament, so I clicked on: File Management > Filaments > +New Filament. Named it PLA and got these errors:
I'm using 2.04 and have never seen this error until this morning.
Thoughts?!
Thanks,Pat
@BearcatTD said in Filament Problems:
Is there a T0 in your slicer start script? And/or you can just look in the gcode file. It should be on a line by itself.
is there a filaments folder on your sd card? if not create it
Does the filaments folder go root level or inside of another folder?
root level
Thanks! Might be a silly question but is there a way to access the root of the sad card without removing it from the board?
not that i know of.
You may be able to do what you need over telnet using this
https://forum.duet3d.com/topic/10880/rfm-reprapfirmware-filemanager-duetbackup-successor?_=1575796812461
It allows the creation of folder etc
