Firmware 2.05RC2 released
    This release fixes an incompatibility between 2.05RC1 and Duet Web Control 2, and a bug with using M3 and M5 commands to control a laser cutter or engraver. Get it from https://github.com/dc42/RepRapFirmware/releases/tag/2.05RC2.
  • Seems to work ok now.
    Thanks DC.
  • @dc42 working fine for me too so far. Excellent work - thank you very much.
  • I'm testing this version 2.05RC2
    Now uptime 47:00:29 ago
    I finished 2 long time prints and Used output buffers: 9 of 24 (24 max)
    IMHO after 4 long time prints, buffers come closer to max and printer freeze... again =(
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05RC2 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-956GU-DJMSJ-6JTDA-3SS6L-TARHD
    Static ram: 25688
    Dynamic ram: 93200 of which 356 recycled
    Exception stack ram used: 544
    Never used ram: 11284
    Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3816) IDLE(ready,200)
    Owned mutexes:
    Last reset 47:00:29 ago, cause: software
  • Moin,
    I am having problems with the G30 command.
    BLTouch ... no extension of the measuring pin ... no lowering of the X-axis.
    Displays error of the axis.
    I forgot the exact error message because I have the version 2.04 installed again.
  • @avaradus 4 days have now passed, 5 long time (16 hour) prints finished, and printer stil work! I will continue to testing...
    M122
    Used output buffers: 8 of 24 (24 max)
    Static ram: 25688
    Owned mutexes:
    Last reset 103:50:19 ago, cause: software
  • There seems to be an issue with changing (increasing) the hot end temperature during print. Doing so causes a heater fault and a stopped print.
    I have not experienced this in previous versions.
    Board: Duet 0.85
    Firmware: RepRapFirmware for Duet 1.26 (2019-12-13b1)
