    shorted hot end cooling fan.
    402
    • jaurandundefined
      jaurand
      accidentally shorted the hot end cooling fan. Always on fans work fine, but fan 0, 1 and 2 I cannot get the fan to move.
      I tested continuity per the image below from this thread https://forum.duet3d.com/topic/3652/shorted-hotend-fan-no-fan-work-anymore/3
      https://ucb6541dab2748873cd185bef290.dl.dropboxusercontent.com/cd/0/inline/AuSvlZ2Bn82YF9JvKcHjI6qiCNUJ6AXtNtb0E1qOaa7g6XNP-gpSX_-9wcVDPhrQABVyIByS84R8cI0YAIHNOuj22GD05febTh-ZF7wwLTJ9YQ/file#
      and I have 0 ohms.
      anything else I should look for?
      • jaurandundefined
        jaurand
        forgot to add using 24 V fans. Also I measure across fan 0 V-fan and fan0- my multimeter reads 20V
        • jens55undefined
          jens55
          Did you check the fuses? Last time I did an oooops, it just took out the fuse ....
          jaurandundefined 1 Reply Last reply Reply Quote 0
          • jaurandundefined
            jaurand @jens55
            @jens55 checked and replaced even just to be sure
              dc42 administrators @jaurand
              @jaurand said in shorted hot end cooling fan.:
              and I have 0 ohms.
              That test only applies to older Duets, before we added the fan fuse,
              Test for continuity between the centre pin of the V_FAN jumper block and the V_FAN pins of the 3 non-working fan outputs.
              If the hot end fan shorted out, it will probably have fan mosfet that was driving that fan. But I would not expect the other 2 fan mosfets to be affected.
              • jaurandundefined
                jaurand @dc42
                @dc42 tested continuity between the 3 non working fan outputs from the pins as well as from the back of the board and I come up with 0.2 Ohms.
                I tried moving the jumper pin to 5V and putting a new 5v fan on but no luck there either.
                  It sounds like failed fan mosfets then.
                  • jaurandundefined
                    jaurand
                    where are they at on the board. happy to replace them as long as i know what i am looking at
                      https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
