RepRapFirmware 3.0RC2 now available
I've just published this release at https://github.com/dc42/RepRapFirmware/releases/tag/3.0RC2. The change list and upgrade notes are at https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
Trying to update from :
Board: Duet WiFi 1.02 or later
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0RC1 (2019-12-16b8)
Duet WiFi Server Version: 1.23
Duet Web Control 2.0.4to this release, but I get:
"Error: In-application programming binary "Duet2CombinedIAP.bin" not found".I can see the thread https://forum.duet3d.com/topic/13401/cant-change-from-v3-0-to-v2-05-missing-file
So I added "Duet2CombinedIAP.bin" from 3.0RC1 is this OK? is this normal? If so, could you please add the "compatible IAP" to the release notes? Or is this a one time thing and we don't have to worry about it anymore?Thanks!
Hi, thanks for your work,
I seem to have an issue with this RC that I didn't have with beta12 (I skipped RC1).
The issue is that the homing of Y is blocking :
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool on Wed Nov 15 2017 23:36:04 GMT-0700 (MST) ; Lift Z relative to current position G91 G1 Z2 F6000 G90 M117 Z hop ; M98 P"outdanger.g" M117 after outdanger ; Move quickly to Y axis endstop and stop there (first pass) G53 G1 Y-415 F10000 H1 ; <---@@@@@@@@@@@@@@@ BLOCKS HERE M117 coarse endstop ; Go back a few mm G91 G1 Y3 F6000 G90 ; Move slowly to Y axis endstop once more (second pass) G53 G1 Y-415 F360 H1 G53 G1 Y2 F10000 ; Lower Z again G91 G1 Z-2 F6000 G90
the web interface shows 'Idle' but subsequent commands don't seem to execute, upon editing, homey.g fails to save because it's locked.
Clicking the endstop manually doesn't unlock the situation.
I would like to activate some logs to help with diagnostics, could you guide me on using M111 please?
here is my endstop configuration (had to change it to satisfy the disparition of
S0
inM574
) :M584 X0 Y1 Z3:4 E9:8 W5 M208 S1 X0 Y0 Z0 W0 ; Set axis minima M208 S0 X415 Y340 Z295 W1000 ; Set axis maxima ; Endstops M574 S1 X1 P"!^xstop" M574 S1 Y1 P"!^ystop" M574 S1 Z1 P"!^zstop+!^e0stop" M574 S1 W1 P"!duex.e2stop" ; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S0 ; Drive 3 goes backwards M569 P4 S1 ; Drive 4 goes forwards M569 P5 S1 ; Drive 5 direction M569 P6 S1 ; Drive 5 direction M350 X16 Y16 Z16:16 E16:16 I1 S3; Configure microstepping with interpolation M350 W16 I1 S3; micro-stepping M92 X320 Y320 Z1600:1600 S64 ; Set steps per mm M92 E100:100 S4; M92 W10 S1; M906 X1000 Y1000 Z800 E800:800 I50 ; Set motor currents (mA) and motor idle factor in per cent M906 W1000 I50; current M84 S10 ; Set idle timeout M915 XY S10 F1 R2 ; stall detection
- Please run M98 P"config.g" to see if there are any error messages, especially relating to endstop configuration.
- Use M119 to test the endstops.
- Otherwise, the only thing I can see that is unusual is that you are using a G1 H1 move in absolute coordinate mode and with a G53 prefix. G1 H1 moves should normally be done in relative coordinate mode (G91), which makes the G53 prefix redundant. But I would not expect this combination to cause a lock-up.
@denke said in RepRapFirmware 3.0RC2 now available:
It is in the upgrade notes of RC1.
You should also upload the new IAP file for your system. You will need it when upgrading firmware in future. These files are called Duet2CombinedIAP.bin, DuetMaestroIAP.bin, Duet3_SBCiap_MB6HC.bin (for Duet 3+SBC) and Duet3_SDiap.bin (for Duet 3 standalone systems). You can leave the old IAP files on your system, they have different names and you will need them if you downgrade to earlier firmware.
Thanks for your help.
- ouch, that reboots the duet, I probably did something very bad.
here is my log after a few tries:
18:28:44: Connection established! 18:28:43: Disconnected. 18:24:52: Connection established! 18:24:51: Disconnected. 18:24:38: Connection established! 18:24:35: Disconnected.
I don't even get the acknowlegement of the M98 in the logs
here is my config.g:; Configuration file for Duet WiFi (firmware version 1.17 to 1.19) ; executed by the firmware on start-up ; ; customized by hand M80 ; General preferences M111 S0 ; Debugging G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M555 P2 ; Set firmware compatibility to look like Marlin M669 K1 ; switch to CoreXY mode M98 P"configmotors.g" ; PROBE M558 P5 I1 H3 F400 T2000 A5 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds G31 P600 X-35 Y-10 Z0.40 ; Set Z probe trigger value, offset and trigger height M557 X20:380 Y20:380 S20; Define mesh grid ; speed planning M566 X100 Y100 Z100 E300 W300; Set maximum instantaneous speed changes (mm/min) M201 X4000 Y2500 Z1500 E2000 W1000 ; Set per axis accelerations (mm/s^2) M204 P4000 T12000 ; Set global accelerations (mm/s^2) M203 X35000 Y35000 Z10000 W5000 E10000 ; Set maximum speeds (mm/min) ; Heaters ; BED M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure bed thermistor M950 H0 C"bedheat" T0 ; configure bed heater M143 H0 S120 ; Set temperature limit for heater 0 to 120C ; HEATER 1 M308 S1 P"e0temp" Y"thermistor" T100000 B4388 C7.06e-8 ; define tool0 temperature sensor M950 H1 C"e0heat" T1 ; heater 1 uses the e0_heat pin and sensor 1 M143 H1 S280 ; Set temperature limit for tool0 to 280C ; HEATER 2 M308 S2 P"duex.e5temp" Y"thermistor" T100000 B4388 C7.06e-8 ; define tool1 temperature sensor M950 H2 C"duex.e5heat" T2 ; tool1 heater M143 H2 S280 ; Set temperature limit for tool1 to 280C ; Fans M950 F1 C"duex.fan7"; fan1 is tool0 cooling M950 F2 C"fan1"; fan2 is tool1 part cooling M950 F3 C"duex.fan5"; fan3 is tool1 cooling ; Tool 0 M563 P0 D0 H1 S"T0 (0.6mm)"; Define tool1 G10 P0 L1 X0 Y0 Z-1.4 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C M106 P1 S0 T70:120 H1 L120 ; Set fan ; M572 D0 S0.4 ; pressure advance ; M591 D0 P2 C9 S1; filament sensor ; M591 D0 P7 C"e1_stop" S1 L1.76 A1 E34 R70:200 ; encoder sensor ;*** ; Tool 1 M563 P1 D1 H2 F2 S"T1 (0.4mm)"; Define tool1 G10 P1 L1 X-2.5 Y2.5 Z-1.4 ; Set tool 1 offsets G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C M106 P3 S0 T70:120 H2; Set tool cooling fan ; M572 D1 S0.2 ; pressure advance ;*** ; Tool 2 M563 P2 S"T2 (empty)"; Define tool2 ;*** ; Network M550 Panycubic ; Set machine name M552 S0 ; awaken wifi module and set to idle ; <snip> M552 S1 ; connect the wifi module to the network M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Custom settings are not configured M564 H0 ; allow movement of un homed axes M207 S3.0 R0.3 F60 T200 ; Miscellaneous M501 ; read saved config (PID coefficients) G0 F40000 ; set travel speed
here is configmotors.g:
here are a few version strings:
Firmware Name: RepRapFirmware for Duet 2 WiFi/Ethernet Firmware Electronics: Duet WiFi 1.02 or later + DueX5 Firmware Version: 3.0RC2 (2019-12-29b1) WiFi Server Version: 1.23 Web Interface Version: 1.22.6
in the web interface the Y switch status display changes in sync with me pushing on it manually, it looks fine.
My homing is in G53 because my home switch senses the tool holder not the tool tip, and every tool has a different offset ( https://www.thingiverse.com/thing:4010872 some mechanical context here ). I felt like I was skipping steps so I re-home after every tool change, but I see in the RC2 release notes that there was a bug of position after tool changes, so it might be something else.
@nraynaud said in RepRapFirmware 3.0RC2 now available:
Please post the result of running M122 after it has rebooted due to running that command.
Shouldn't this be 2.0.4?
@dc42 said in RepRapFirmware 3.0RC2 now available:
M122
I see the software got afraid of the boss, here is my log now (I don't think I changed anything, probably a race condition):
19:24:18M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0RC2 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DDM-9FAM2-LW4SD-6JKD4-3S46L-92X3W Used output buffers: 3 of 24 (16 max) === RTOS === Static ram: 30516 Dynamic ram: 93164 of which 44 recycled Exception stack ram used: 256 Never used ram: 7092 Tasks: NETWORK(ready,640) HEAT(blocked,1240) DUEX(suspended,160) MAIN(running,3668) IDLE(ready,156) Owned mutexes: === Platform === Last reset 00:08:29 ago, cause: software Last software reset at 2019-12-29 19:15, reason: User, spinning module GCodes, available RAM 7100 bytes (slot 1) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 35.1, current 35.4, max 36.0 Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Driver 5: standstill, SG min/max not available Driver 6: standstill, SG min/max not available Driver 7: standstill, SG min/max not available Driver 8: standstill, SG min/max not available Driver 9: standstill, SG min/max not available Date/time: 2019-12-29 19:24:16 Cache data hit count 1397321660 Slowest loop: 128.51ms; fastest: 0.10ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 200.23ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 1 WiFi firmware version 1.23 WiFi MAC address 60:01:94:34:3b:19 WiFi Vcc 3.37, reset reason Turned on by main processor WiFi flash size 4194304, free heap 24312 WiFi IP address 192.168.0.28 WiFi signal strength -59dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 19:22:24Connection established! 19:22:23Disconnected. 19:22:15M98 P"config.g" Error: M558: Missing Z probe pin name(s) Error: G31: Invalid Z probe index
all of a sudden it spits the error message. I'll look at the documentation, the error was probably here before.
Thanks.
@Phaedrux I am using the old page at
/reprap.htm#
it's more confortable and shows more things for diagnostics.@dc42 actually after commenting M558 and G31 I still get the reboot:
19:32:11M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0RC2 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DDM-9FAM2-LW4SD-6JKD4-3S46L-92X3W Used output buffers: 1 of 24 (17 max) === RTOS === Static ram: 30516 Dynamic ram: 93164 of which 44 recycled Exception stack ram used: 256 Never used ram: 7092 Tasks: NETWORK(ready,640) HEAT(blocked,1240) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156) Owned mutexes: === Platform === Last reset 00:00:46 ago, cause: software Last software reset at 2019-12-29 19:31, reason: User, spinning module GCodes, available RAM 7432 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 34.3, current 35.7, max 36.2 Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Driver 5: standstill, SG min/max not available Driver 6: standstill, SG min/max not available Driver 7: standstill, SG min/max not available Driver 8: standstill, SG min/max not available Driver 9: standstill, SG min/max not available Date/time: 2019-12-29 19:32:09 Cache data hit count 105424755 Slowest loop: 128.25ms; fastest: 0.09ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 116.61ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 60:01:94:34:3b:19 WiFi Vcc 3.37, reset reason Turned on by main processor WiFi flash size 4194304, free heap 24608 WiFi IP address 192.168.0.28 WiFi signal strength -60dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 19:32:06Connection established! 19:32:05Disconnected. 19:31:41Connection established! 19:31:41Page Load complete!
I deny that this reboot was directly asked by me, I don't see any reboot command in my files, and it is the result of the M98 P"config.g"
It's not requested by you, the diagnostics make that clear. Can you pin down which line causes the reboot? For example, take a copy of config.g, and delete about 50% of the lines at the end of the copy. Then use M98 to run that copy. If it still crashes, delete 50% of the lines remaining at the end; otherwise reinstate some lines that you deleted. Then try again, and so on.
thanks for your help, I'll start right now.
I may have been chasing a red herring:
M552 S0 ; awaken wifi module and set to idle M587 S"NUMERICABLE-B290" P"PASS" ; send this line to be saved in wifi module M552 S1 ; connect the wifi module to the network
of course, those lines looks like a reboot.
Not a reboot, just turning the network off and on again. The only one of those lines you need is M552 S1.
yes.
I don't have a reboot in my configuration, but I still have a weird hang during homing.
is there a way to dump the state of the machine? I feel like it's waiting for something.
here is a log during homing:
21:59:09M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0RC2 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DDM-9FAM2-LW4SD-6JKD4-3S46L-92X3W Used output buffers: 10 of 24 (16 max) === RTOS === Static ram: 30516 Dynamic ram: 93164 of which 12 recycled Exception stack ram used: 488 Never used ram: 6892 Tasks: NETWORK(ready,640) HEAT(blocked,1184) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156) Owned mutexes: === Platform === Last reset 00:27:43 ago, cause: software Last software reset at 2019-12-29 21:31, reason: User, spinning module GCodes, available RAM 6788 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 33.9, current 35.2, max 35.7 Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max 359/1023 Driver 1: standstill, SG min/max 344/1023 Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max 56/1023 Driver 4: standstill, SG min/max 0/196 Driver 5: standstill, SG min/max not available Driver 6: standstill, SG min/max not available Driver 7: standstill, SG min/max not available Driver 8: standstill, SG min/max not available Driver 9: standstill, SG min/max not available Date/time: 2019-12-29 21:59:08 Cache data hit count 4294967295 Slowest loop: 8.01ms; fastest: 0.09ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 165, MaxWait: 1652015ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 8, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 1 Stack records: 2 allocated, 1 in use Movement lock held by http http is doing "G53 G1 Y-415 F360 H1" in state(s) 0 8, running macro telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 15.86ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 60:01:94:34:3b:19 WiFi Vcc 3.37, reset reason Turned on by main processor WiFi flash size 4194304, free heap 19376 WiFi IP address 192.168.0.28 WiFi signal strength -57dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 21:58:58G28 Y
Looks like it thinks it is executing the Y homing move and waiting for the endstop to trigger. Maybe the Y motor current or motor current percentage is set to zero? Or the Y motor mapped to the wrong driver?
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool on Wed Nov 15 2017 23:36:04 GMT-0700 (MST) ; Lift Z relative to current position G91 G1 Z2 F6000 G90 ; M98 P"outdanger.g" ; Move quickly to Y axis endstop and stop there (first pass) G53 G1 Y-415 F10000 H1 ; Go back a few mm G53 G1 Y3 F40000 ; Move slowly to Y axis endstop once more (second pass) G53 G1 Y-415 F360 H1 G53 G1 Y2 F10000 ; Lower Z again G91 G1 Z-2 F6000 G90
it has moved and done the coarse homing right before that.
executing it line by line seems to work ok:
22:48:41G90 22:48:35G1 Z-2 F6000 22:48:28G91 22:48:22G53 G1 Y2 F10000 22:48:16G53 G1 Y-415 F360 H1 22:48:05G53 G1 Y3 F40000 22:47:56G53 G1 Y-415 F10000 H1 22:47:47G90 22:47:40G1 Z2 F6000 22:47:32G91 22:47:31Connection established!
I really don't know. running `M98 P"homey.g"' triggers the issue too.
edit: I get the bug both with and without the pullup, but I don't see any influence of this setting the web interface anyways (the switch works perfectly in my tests in the web interface)
You really ought to be using relative movement commands with G1 H1. Also, i still donm;'t understand why you think you need the G53 prefixes. What happens if you use relative movement and no G53 prefixes?
In my limited testing (the software side of this project feels like being a ball at a rugby game, everything is just hard, I don't know what conclusion actually hold), homing without G53 was placing the tool center at the switch trigger point instead of placing the machine zero there.
I will look into the relative movements, I need to find the original example files, thanks.
I found it! Thanks for your help.
I need more time or more distance to back out of the switches after the coarse homing (what's weird is that I had the same issue in X and Y). That's why I couldn't find the issue line by line.
have you de-bounced the switches or changed the execution order?
