G1 H1 X-355 F3000 does not work as expected
  • G1 H1 X-355 F3000 stops movement before reaching endstop when y < ~100. this makes homing unreliable.
    what can i do to get this fixed? (except homing y first and move to y > ~200)
    y does not suffer from this.
    when properly homed x can be moved anywhere without any issues.
    hw: duet 3 6hc rev 1.0
    sw: FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0beta12 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2019-11-02b1
    conf: corexy printer
    regards, gsp
  • @spllg how big is your printer?
    Try increasing the -350 to a larger number. I use -999 in mine which is larger than my print size.
    Please upgrade your firmware to 3.0RC2.
  • @dc42 upgrading to 3.0RC2 made things worse:
    • after an initial failed x-home (from x=100,y=0, g1 h1 premature stopped at invisible endswitch) a subsequent x-home attempt (null-effect) did not terminate
    • after a successful x-home from (x=100,y=120) a z-home caused one spindle to move upwards while the other spindle did not move (dual z-steppers) resulting in a very ugly noise.
    reverted to 3.0beta12
  • @jay_s_uk already have tried this - could not observe any change
  • @dc42 i feel, the problem might be related to micro step configuration as the y-threshold changes when i change micro step configuration (using m350 xnn ynn)
  • @spllg said in G1 H1 X-355 F3000 does not work as expected:
    don't recall the specifics, but changes to microstepper or steps/mm after the other will affect the former. I.e. the order matters. show your config and I'm sure someone will spot any issues there.
  • Yes, please post your entire config.g
  • @Danal here it is
    M550 P"3dd" ; set printer name
    M667 S1 ; select CoreXY mode
    M569 P0.0 S1 ; physical drive 0.0 goes forwards ; XY - right
    M569 P0.1 S1 ; physical drive 0.1 goes forwards ; XY - left
    M569 P0.2 S1 ; physical drive 0.2 goes forwards ; Zr
    M569 P0.3 S1 ; physical drive 0.3 goes forwards ; Zl
    M569 P0.4 S0 ; physical drive 0.3 goes forwards ; E0
    ;M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
    ;M584 X0.0 Y0.1 Z0.3 E0.3 ; set drive mapping
    M584 X0.0 Y0.1 Z0.2:3 E0.4 ; set drive mapping
    M92 X200.00 Y200.00 Z400.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X12000.00 Y12000.00 Z3000.00 E3600.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z25.00 E250.00 ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-26 Y0 Z0 S1 ; set axis minima
    M208 X280 Y300 Z340 S0 ; set axis maxima
    M574 X1 S1 P"io3.in" ; configure active-low endstop for low end on X via pin io3.in
    M574 Y1 S1 P"io4.in" ; configure active-low endstop for low end on Y via pin io4.in
    M574 Z1 S1 P"io5.in" ; configure active-low endstop for low end on Z via pin io5.in
    ; bed leveling
    ;M671 X50:150 Y150:150 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
    ;M558 P1 C"io5.in" H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
    ; Z-Probe ( https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type )
    ;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
    ;M557 X15:215 Y15:195 S20 ; define mesh grid
    M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
    M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
    ; 2DO: fix and all below
    M143 H0 S110 ; set temperature limit for heater 0 to 120C
    M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
    M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
    M950 F0 C"out4" Q500 ; create fan 0 on pin out3 and set its frequency
    M106 P0 H-1 ; set fan 0 value. Thermostatic control is turned off
    ;M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"out5" Q500 ; create fan 1 on pin out4 and set its frequency
    M106 P1 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
    ;M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
  • @spllg The Z movement issue might be caused by this M584 X0.0 Y0.1 Z0.2:3 E0.4 which ought to be M584 X0.0 Y0.1 Z0.2:0.3 E0.4. Also, strictly speaking M667 is deprecated so M667 S1 ought to be M669 K1.
    It might be an idea if you post your homing files too.
  • @deckingman changing the 2 suggested lines solved both issues - x-homing now works fine using 3.0RC2
    thanks a lot
