    Project: Black'n'Yellow
    My Duet controlled machine
    304
    • Dweezyundefined
      Dweezy
      This is my tribute to this amazing piece of hardware AND software.
      CR-10 clone, Dual X, Dual Z, Dual 3in1 Hotend, 400x400x400.
      Why i build this? Because over one year ago, marlin, mk4duo und some others told me: That isnt possible. And maybe because i'm multicolor addicted ๐Ÿ™‚
      Ready for 1st test-print in dual-mode
      Dual X calibration
      1st Dual Testprint
      video 1
      Middel of Dual Testprint
      video 2
      Finish of Dual Testprint
      video 3
      It was a long journey until now. Now comes 'finishing up' the 2 carriage. And ofc cleaning up the "improper" screws (which are NOT black) AND parts (which are NOT yellow OR black) which step-in as this project evolved.
      Parts used:
      - sweat
      - blood
      - nerves
      - alcohol
      - some sort of Duet Wifi
      - some sort of Duex 5
      - some sort of Paneldue 7"
      - some sort of 11 stepper motors
      - some sort of 2x THC-01 Hotend
      - some sort of CR-10 S4 carriage
      - some sort of SSR
      - some sort of Keenovo 400x400 230V 1000W
      - some tons of "only black" screws
      - some shit load of cables.
      - some sort of ONLY black pulleys, timing pulleys, belts.....you see it on the pictures ;)
      - 24V built.
      @dc42: <3 <3 <3 for this amazing piece of software.
      A Former User? 1 Reply Last reply Reply Quote 2
        Thanks looks an great machine! Which 3-in-1 hot ends are you using?
        I'm looking forward to seeing some amazing multicolour prints from it. And I hope you will show this machine to the naysayers too!
        • Dweezyundefined
          Dweezy
          Its called "NF THC-01"
          • jens55undefined
            jens55
            What do you have to do to prevent the two heads from colliding?
            I assume one head has to be 'parked' at a time but how do you do that ? In the slicer ? In Duet?
            • Dweezyundefined
              Dweezy
              the "magic" happens in Duet ๐Ÿ˜‰
              So its more easier to use with a slicer.
              The Hotends are "parked" when in standby / not used.
              ; tfree0.g
              ; called when tool 0 is freed
              ; generated by RepRapFirmware Configuration Tool on Fri Oct 12 2018 16:15:59 GMT+0200 (CEST)
              M83                            ; relative extruder movement
              G1 E-5 F3600                   ; retract 5mm
              G10 P0 R180                    ; Standby temp = 180 degree
              M106 S0                        ; turn off our print cooling fan
              G91                            ; relative axis movement
              G1 Z1 F500                     ; up 1mm
              G90                            ; absolute axis movement
              G1 S2 X-45 F6000               ; park the X carriage at -45mm
              ; tpost0.g
              ; called after tool 0 has been selected
              ; Wait for set temperatures to be reached
              M106 R2                        ; restore print cooling fan speed
              M116 P0                        ; wait for tool 0 heaters to reach operating temperature
              G1 E5 F3600                    ; extrude 2mm
                dc42 administrators @Dweezy
                @Dweezy said in Project: Black'n'Yellow:
                Why? [maybe it's supposed to be obvious, but if so, I don't get it.]
                  droftarts administrators @dc42
                  @dc42 said in Project: Black'n'Yellow:
                  Thatโ€™s the hot end! TWP 3D Printer accessories 3 in 1 out Multi-color Extruder Hotend Kit NF THC-01 Three Colors Switching Hotend Kit for 0.4/1.75mm https://www.amazon.co.uk/dp/B071V3LH1J/ref=cm_sw_r_cp_api_i_eJofEb0793621
                  • Quattroundefined
                    Quattro
                    This looks awesome! I will keep watching your build.
                    • A Former User?
                      A Former User @Dweezy
                      That isnt possible.
                      Relatable:D Looks awesome!
