Endstop Issues with RepRap 3.0 upgrade
I seem to be having issues with the endstops after having retrofitted a creality CR10 with a duet wifi.
Everything worked fine until I blew up my original Duet 2 rev 1.04c (long story) and replaced it with a new one of the same revision. during the replacement I upgraded the firmware to 3.0 and now all of the switches seem to be inverted. The Axes wont home because they think the switches are already tripped. I tried changing the output with the M574 command in my config.g without success. Any suggestions? -
Please post your config.g file so I can take a look
https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
Have you tried invert the input by prefixing the pin name with '!'
Here is the config.g file
@DIY-O-Sphere
Thank You So Much! That works perfectly.
I had no Idea that they added all of this functionality to the M574. It will be really helpful when I switch over to dual Z endstops too.
