    Mesh Compensation
    1.5k
    • Corexyundefined
      Corexy
      I have the mini IR probe.
      My bed is 195x195 square build area (the actual plate is 240x240 but it can't all be reached).
      Mate I don't even know what S40 means, so if you don't mind telling me what you'd put in your bed.g, config.g and start script, I'll take your word for it and appreciate your help.
      Cheers again,
      Neil.
      • Vetiundefined
        Veti
        @Corexy said in Mesh Compensation:
        G31 P500 X0 Y0
        ok you need to configure the probe position.
        X and Y is the offset of the probe from the nozzle. X postive is to the your Y positive is behing. Without this your mesh will be inaccurate.
        M557 X20:180 Y20:180 S40
        change S40 to S15 or S10
        M574 Z0 S0 ; Define active low and unused microswitches
        change to
        M574 Z1 S2 ; set endstops controlled by probe
        post your homing scripts. they will prob be wrong.
        • Corexyundefined
          Corexy
          I should point out that x and y have homing switches...the probe only does the bed level.
          Does that change anything?
          Thanks for helping with this. What's crazy is that despite me using this thing for years with little tuning/adjustment, I knock out some pretty good prints.
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @Corexy
            no
            • Corexyundefined
              Corexy
              OK,
              So my nozzle/probe offsets are:
              X 4mm
              Y 28mm
              So my M557 becomes:
              M557 X4:195 Y28:195 S10 (?)
              Just a bit worried that the fans might bang into some hardware with these offsets. It's a tight fit in there.
              My slicer start script:
              G28 (home all?)
              G29 (mesh probe?)
              Nothing else at all? I should really tack the purge/wipe I was asking about in my other thread on here while I'm at it?
              Any changes to bed.g?
              Homing files...
              homeall.g:
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v2.1.2 on Thu Nov 21 2019 10:53:58 GMT+1100 (Australian Eastern Daylight Time)
              G91 ; relative positioning
              G1 H1 X-200 Y-200 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H2 X5 Y5 F6000 ; go back a few mm
              G1 H1 X-200 Y-200 F360 ; move slowly to X and Y axis endstops once more (second pass)
              G90 ; absolute positioning
              G1 H2 X97.5 Y97.5 F6000 ; go to first bed probe point and home Z
              G1 S2 Z5 F100 ; lift Z relative to current position
              homex.g:
              ; homex.g
              ; called to home the X axis
              ; generated by RepRapFirmware Configuration Tool v2.1.2 on Thu Nov 21 2019 10:53:59 GMT+1100 (Australian Eastern Daylight Time)
              G1 H1 X-200 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 H2 X5 F6000 ; go back a few mm
              G1 H1 X-200 F360 ; move slowly to X axis endstop once more (second pass)
              G1 H2 Z-5 F6000 ; lower Z again
              homey.g:
              ; homey.g
              ; called to home the Y axis
              G1 H1 Y-200 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 H2 Y5 F6000 ; go back a few mm
              G1 H1 Y-200 F360 ; move slowly to Y axis endstop once more (second pass)
              homez.g:
              ; homez.g
              ; called to home the Z axis
              G1 H2 X15 Y15 F6000 ; go to first probe point
              ;G91 ; relative positioning
              ;G1 H2 Z5 F100 ; lift Z relative to current position
              ;G90 ; absolute positioning
              I do suspect my files are messy. I come on here asking things and get a line to add here and there. Would really love to have an expert here with me in front of the thing for a day...
              • Vetiundefined
                Veti @Corexy
                no you change the probe offset in the G31 command like i posted.
                lets get your mesh working first.
                bed.g is for G32 command which you are not using.
                your homing files look fine
                Corexyundefined 1 Reply Last reply Reply Quote 0
                • Corexyundefined
                  Corexy @Veti
                  Ok, sorry my mistake
                  X and Y is the offset of the probe from the nozzle. X postive is to the your Y positive is behind. Without this your mesh will be inaccurate.
                  Not quite sure what you mean here...you mean that I enter a positive value offset if the probe is further "along" the axis than the nozzle tip, and negative if it is "behind"?
                  Thank you for your patience by the way.
                  • Vetiundefined
                    Veti
                    that was posted regarding your
                    G31 P500 X0 Y0
                    command.
                    that command means the probe is at the same place as the nozzle is, which it is not as you are using a ir probe.
                    so you need to tell the duet where the ir senssor actualy is while assuming that the nozzle is at 0,0.
                    post a picture of your carriage.
                    • Corexyundefined
                      Corexy @Veti
                      @Veti said in Mesh Compensation:
                      G31 P500 X0 Y0
                      command.
                      OK, so I just went out there and moved the nozzle around the absolute outside of the build area via the touchscreen, and the nozzle travels the absolute limits of the build area and obstacles as it is. If I add these offsets is there any chance I'll bump into things, or should I do something to avoid that.
                      [img]https://i.imgur.com/kCMHC1Q.jpg[/img]
                      [img]https://i.imgur.com/bC9SaMB.jpg[/img]
                      • Vetiundefined
                        Veti @Corexy
                        @Corexy
                        try it with the hand on the power switch.
                        but if i remember correctly the offset does not change the mesh coordinates, as they are absolute nozzle parameter.
                        • Vetiundefined
                          Veti @Veti
                          @Veti
                          also
                          M208 X195 Y195 Z175 S0 ; Set axis maxima
                          this is a hard limit for your axis. if at X195 Y195 there is no problem. then you can not cause a problem with the mesh leveling.
                          • Corexyundefined
                            Corexy
                            Yes, I'll keep the switch handy ha ha. But It still must home the axis' against the limit switches, so yes no offset was probably only messing up my mesh.
                            G31 P500 X2 Y28 Z2.465
                            I measured it a bit more accurately. So I run G29 and see what happens??
                            • Vetiundefined
                              Veti @Corexy
                              @Corexy
                              yes
                              • Corexyundefined
                                Corexy
                                M557 X20:180 Y20:180 S10
                                Ok, it's ticking over happily with the mesh (cold build plate), but it's going to take a lot longer with these 10mm intervals. Which is fine if it will give me a better first layer.
                                To probe the entire (195x195) bed, should I take it out to the edges?
                                M557 X5:190 Y5:190 S10
                                And I'm also thinking should I:
                                1. Warm build plate
                                2. Home all
                                3. Mesh probe (each time, as different bed temps will make different mesh)
                                4. Purge/wipe
                                5. Start print
                                It would be really good to do the mesh probe with a cold nozzle as the ooze is a pain and I'm using an IR probe anyway. I don't mind at all the mesh taking a long time if I'm not picking ooze off the nozzle with tweezers the whole time.
                                • Vetiundefined
                                  Veti @Corexy
                                  post the picture of the mesh grid.
                                  going to a higher spacing depends on the quality of your build plate. the wider the spacing the less details it has to correct with.
                                  so if there are no irregulaties, you can get away with a wider spacing.
                                  with the bigger mesh: if your Y offset is 28 to probe at 5 it would need to move to Y-23, which is not allowed. for X it would work
                                  • Corexyundefined
                                    Corexy
                                    Yes, I can't "reclaim" the Y offset...mechanical obstacles. Makes a case for ally extrusion chassis in my next printer, built well oversize to the build plate.
                                    Running this now regardless, and it seems to be just doing what it can reach.
                                    Mate I really appreciate this help so much, but it's late now and the other half wants me to give it a rest for tonight.
                                    I'll have another look in the morning, but this has been a win so far.
                                    Cheers and thanks!
                                    [img]https://i.imgur.com/3hQysIH.png[/img]
                                    • Vetiundefined
                                      Veti
                                      that picture suggests that the surface is not suited very well for ir probing.
                                      see
                                      https://miscsolutions.wordpress.com/mini-height-sensor-board/
                                      • Corexyundefined
                                        Corexy
                                        OK, really?
                                        It's the original Printbite, supposedly OK. It does give very consistent readings when calibrating the Z height.
                                        I have wondered about those BL touch probes, are they better?
                                        I would really like to keep the Printbite, just because I don't have to replace it. That surface is 3 years old and going strong.
                                        Are there any other surfaces that are similar out there that do work well with IR? I have really liked this probe to be honest, but the Printbite has been tricky with ABS.
                                        I'll see how it performs with this new mesh tomorrow.
                                        @dc42 @deckingman
                                        • Corexyundefined
                                          Corexy
                                          So how would one of these be as a bed sensor?:
                                          https://www.ebay.com.au/itm/5mm-Noncontact-Inductive-Proximity-Sensor-Switch-Detect-DC-6-36V-NPN-TL-W5MC1/253114333447
                                          I've thrown straight edges on this build plate, and while i's not perfect I don't think it runs out as much as this mesh suggests.
                                          With the build plate under the printbite being cast ally, would this type of sensor work better? Is it a straight up fit, or would I need a daughter board of some sort?
                                          I saw another thread where a guy was reporting good results with one of these (due to having trouble with the IR sensor on Printbite), but the thread seemed to die out.
                                          Unless there's a comparable (long lasting/self releasing) surface out there with good IR sensor compatibility, would this be an option?
                                          • Corexyundefined
                                            Corexy
                                            [img]https://i.imgur.com/1Zczdwt.png[/img]
                                            Here a mesh I ran with a plain sheet of white paper on the bed. It was certainly not flat, but I don't see the "spikyness" in the map that I get with Printbite.
                                            Can someone tell me if I need to use a different sensor, and if so, what do I use?
                                            I'm wondering if I've been printing for a few years now with a setup that was not capable of reading the bed properly....
                                            Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
