    Dual extrusion with E3D chimera - experience
    676
    • felt342undefined
      felt342
      Can somebody share please working dual extrusion tool change files, especially if someone achieved it working with E3D chimera setup?
      I have couple of complications with it, and I only managed to work it better-leaving temperature always constant even then the tool is free. I just use retraction in tool-change files, so filament goes out of melting zone and then undo retraction by a bit less amount, like that:
      retract 8mm
      undo retract 7.5
      But even then I have filament coming out before its start printing. So print becomes a bit messy with filament around from leaking nozzle.
      Can somebody shine a light on it, what is the best approach, or just share your experience? Thank you in advance!
      Industrial 3D printing service in the Netherlands - gagatstudio.com
      • jens55undefined
        jens55
        I use the same setup and I too have a bit of a messy print with tiny bits of the non-active extruder in the print.
        One thing I found essential is to use standby temperatures where the non-active extruder cools down in order to not 'drool' but also to not cook the filament in the non-active extruder.
        I only retract about a mm as I get clogs if I retract more. This is in a bowden setup.
        My tool-change files are in a state of transition and not tested yet with RRF3 which I just updated to. There is nothing magic in there but in my case I extrude 10 mm of filament. I do of course have to use a tower with that configuration.
        I use volcano hot blocks and if I left the temperatures constant I believe I would have a lot more drooling.
        • felt342undefined
          felt342
          I do have a bowden as well in my setup. Can you please tell me how did you set to use a tower? Thanks!
          jens55undefined 1 Reply Last reply Reply Quote 0
          • jens55undefined
            jens55 @felt342
            @felt342 the tower is a feature of the slicer. I use Cura. The tower is part of the dual extrusion configuration "enable prime tower"
            • felt342undefined
              felt342
              Oh... I expected that what its something with slicer. Then it looks like Simplify3D doesn`t have it, or I am blind? Do you know that? 🙂
              • jens55undefined
                jens55
                Sorry, don't know anything about Simplyfy3d ... but I would be surprised if it didn't support a prime tower (assuming it supports dual extrusions)
                felt342undefined 1 Reply Last reply Reply Quote 1
                • felt342undefined
                  felt342 @jens55
                  @jens55
                  Will check it tonight! Thanks!
                  • Dr_Ju_Juundefined
                    Dr_Ju_Ju
                    You just need to add another extruder in the FFF settings\Extruder & configure accordingly....
                    Julian,
                    Old goat, learning new things….
                    felt342undefined 2 Replies Last reply Reply Quote 0
                    • felt342undefined
                      felt342 @Dr_Ju_Ju
                      @Dr_Ju_Ju
                      Yeah, indeed it's pretty god damn easy....!
                      Then I assume there is no point to figure out something in tool change files - the only retraction in/out probably.
                      Thanks!
                      • felt342undefined
                        felt342 @Dr_Ju_Ju
                        @Dr_Ju_Ju
                        I was trying to print infill with different extruder just for a test. Is there a way to set up what each layer will be primed with left and right extruder? Image explains what is happening now -
                        Thanks!
