    DWC 2.06, Experiencing Connection Interruption Errors
    Duet Web Control
    586
    • ctilley79undefined
      ctilley79
      This is happening on both of my printers. One printer is running RRF 3.01 beta 2, the other is running RRF 2.05. Getting the same error at random intervals, however all UI functions still work as intended. I'm still able to upload successfully to both printers without error.
        jay_s_uk
        Upgrade to DWC 2.0.7 and see if that fixes the issue
        ctilley79undefined 1 Reply Last reply Reply Quote 0
          ctilley79
          Will do. Damn you guy's move fast. must have been released today
            ctilley79 @jay_s_uk
            @jay_s_uk Actually that didn't seem to fix it.
              Do you have a password set on that Duet?
                ctilley79 @dc42
                @dc42 no. I live life dangerously
                • A Former User?
                  A Former User
                  is it a Duet2Wifi? Run M122and post the output.
                  ctilley79undefined 3 Replies Last reply Reply Quote 0
                    ctilley79 @A Former User
                    @bearer yes it is a duet 2 wifi
                    M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
                    Board ID: 08DGM-9T6BU-FG3SJ-6J9DD-3SJ6R-TBYHG
                    Used output buffers: 3 of 24 (12 max)
                    Static ram: 25712
                    Dynamic ram: 93224 of which 12 recycled
                    Exception stack ram used: 456
                    Never used ram: 11668
                    Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,1664) IDLE(ready,160)
                    Owned mutexes:
                    Last reset 03:10:22 ago, cause: software
                    Last software reset at 2020-01-24 14:58, reason: User, spinning module GCodes, available RAM 11644 bytes (slot 3)
                    Error status: 0
                    Free file entries: 10
                    MCU temperature: min 34.2, current 34.7, max 38.9
                    Supply voltage: min 23.7, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: standstill, SG min/max 0/368
                    Driver 1: standstill, SG min/max 0/341
                    Driver 2: standstill, SG min/max 0/158
                    Driver 3: standstill, SG min/max 0/1023
                    Driver 4: standstill, SG min/max 0/128
                    Date/time: 2020-01-24 18:09:01
                    Slowest loop: 114.31ms; fastest: 0.06ms
                    Hiccups: 0, FreeDm: 160, MinFreeDm: 100, MaxWait: 2653530ms
                    === DDARing ===
                    Scheduled moves: 4, completed moves: 4, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                    Heater 0 is on, I-accum = 0.3
                    Heater 1 is on, I-accum = 0.4
                    Segments left: 0
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is idle in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 145.57ms; fastest: 0.00ms
                    HTTP sessions: 1 of 8
                    • WiFi -
                      Network state is running
                      WiFi firmware version 1.23
                      WiFi MAC address 60:01:94:2e:c4:57
                      WiFi Vcc 3.34, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 23224
                      WiFi IP address 192.168.1.236
                      WiFi signal strength -45dBm, reconnections 0, sleep mode modem
                      @bearer and the other machine
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-beta2 running on Duet WiFi 1.02 or later
                      Board ID: 08DGM-956GU-DJMSN-6JKFD-3SD6M-1URHG
                      Used output buffers: 3 of 24 (19 max)
                      Static ram: 27988
                      Dynamic ram: 92560 of which 24 recycled
                      Exception stack ram used: 496
                      Never used ram: 10004
                      Tasks: NETWORK(ready,596) HEAT(blocked,1232) MAIN(running,1596) IDLE(ready,76)
                      Owned mutexes: WiFi(NETWORK)
                      Last reset 18:26:58 ago, cause: software
                      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10236 bytes (slot 0)
                      Error status: 10
                      SD card longest block write time: 10.4ms, max retries 0
                      MCU temperature: min 38.0, current 38.3, max 38.7
                      Supply voltage: min 24.5, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                      Date/time: 2020-01-24 18:12:29
                      Slowest loop: 13.62ms; fastest: 0.09ms
                      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                      === MainDDARing ===
                      Scheduled moves: 9, completed moves: 9, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                      === AuxDDARing ===
                      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                      Segments left: 0
                      === Network ===
                      Slowest loop: 202.25ms; fastest: 0.09ms
                      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                      • WiFi -
                        Failed messages: pending 0, notready 0, noresp 1
                        WiFi MAC address 5c:cf:7f:76:60:cf
                        WiFi Vcc 3.43, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 23240
                        WiFi IP address 192.168.1.85
                        WiFi signal strength -37dBm, reconnections 0, sleep mode modem
                        Socket states: 4 0 0 0 0 0 0 0
                        @bearer
                        This is from my Ubiquiti Access point dashboard. It's showing that neither printer has dropped connection to the network.
                        Screen Shot 2020-01-24 at 6.18.34 PM.png Screen Shot 2020-01-24 at 6.17.07 PM.png
                        • A Former User?
                          A Former User @ctilley79
                          @ctilley79 said in DWC 2.06, Experiencing Connection Interruption Errors:
                          😍 that should rule out connection issues. And it also confirms you're running
                          DuetWiFiServer 1.23 which i believe is the correct version. (Someone will probably be along shortly to correct me if I'm wrong, Icouldn't find the refrence I was looking for with a quick search)
                          • smoki3undefined
                            smoki3
                            I also get alot of these issues with 2.06 and 2.07
                            • mwolterundefined
                              mwolter
                              Same here, with a Duet 2 Ethernet rev 1.04 running RRF 2.05. Constant reconnection messages and approx one hour into a print I lose all access to DWC. I can still ping the board, the print continues fine and PanelDue continues to work fine. Did not have issues with version 2.04.
                              mwolterundefined 1 Reply Last reply Reply Quote 1
                              • mwolterundefined
                                mwolter @mwolter
                                @mwolter Updated to DWC 2.07 and it appears to have helped with the web interface becoming unresponsive. There are still a lot disconnection notifications in the console but at least I’m not locked out of the web GUI. Interesting thing, I don’t notice the disconnection pop ups as often. Prior to 2.07 it was common to see them if DWC was open and in focus. Now I don’t notice them as much but there are still quite a few in the console. Could this be because the Mac doesn’t give priority to safari when it’s minimized? BTW, this is with the lates MacOS and Safari.
                                  ctilley79 @mwolter
                                  @mwolter That's what I'm noticing as well. Seems the disconnect notifications in the log aren't affecting usability. Just annoying
