    Where to find the motor side connectors used on Nema17s?
    connectors motors
    792
    • elliott.griffithsundefined
      elliott.griffiths
      I need some for a project, but I can only find the female pin side housing and crimps (JST-PH6 I believe). Any advice would be appreciated.
      • A Former User?
        A Former User
        I have not seen male connectors for 2.0mm JST PH, only PCB headers which you could solder wires to but its not optimal.
        • Danalundefined
          Danal
          I have found cable assemblies on amazon.
          https://www.amazon.com/s?k=stepper+motor+cables&ref=nb_sb_noss_1
          • bricorundefined
            bricor
            https://www.amazon.com/gp/aw/d/B0791DJMW9?psc=1&ref=ppx_pop_mob_b_asin_image
            • A Former User?
              A Former User @bricor
              @bricor said in Where to find the motor side connectors used on Nema17s?:
              wrong size. thats 2.54mm JST XH, not 2.0mm JST PH
              Maybe OP could ask this seller if he could supply 6-pin version, some are quite happy to help, if they understand the question.. https://www.ebay.com/itm/100-SET-JST-PH-2-0mm-2-Pin-Li-PO-Male-Housing-Connector-with-Crimp-Pin-terminal-/113549526440
              Beyond that I only see pre-crimped:
              https://www.ebay.com/itm/10-Pair-Micro-JST-PH-2-0-2P-3P-4P-5P-6PIN-Male-Female-Plug-Connector-With-Wire/163874785758?hash=item2627b2c9deⓂmVXoJ3A_3lfxcsmUrP2LSOg
              (hadn't found similar before)
              bricorundefined 1 Reply Last reply Reply Quote 0
              • zaptaundefined
                zapta
                Search AliExpress for PH2.0 and I believe that you will find what you are looking for. The Nema17 use the 6 pins connectors.
                • bricorundefined
                  bricor @A Former User
                  @bearer You are correct. Thank you for pointing that out.
                  • A Former User?
                    A Former User
                    @zapta said in Where to find the motor side connectors used on Nema17s?:
                    Search AliExpress
                    Male crimp connectors? I've searched for 3 and 4 pins before without luck, only the preassembled cable like i linked to. I was shocked to find 2pin male on eBay. If you stumble onto a link please share, I'm still hunting for 3 and 4 pins for other projects:)
                    zaptaundefined 1 Reply Last reply Reply Quote 0
                    • zaptaundefined
                      zapta @A Former User
                      Not crimps but PCB TH (can also be soldered with a shrink tube), straight and right angle. E.g.
                      https://www.aliexpress.com/item/32965581442.html
                      Edit: looking at JST's website for the PH series, the male side doesn't seem to come with a crimp version, just TH PCB (their website is built such that it's difficult to share links).
                      • A Former User?
                        A Former User
                        There are non-JST branded (or rather unbranded maybe), but I've never seen them offered uncrimped with the exception of the 2 pin on eBay a few posts up. I send the guy a message asking for 3 and 4 pins, but don't expect an answer until after new year over there.
                        edit: he actually offered 2,3, and 4 pin so I ordered some. Could still be worth asking for 6 pin
                        • A Former User?
                          A Former User @elliott.griffiths
                          @elliott-griffiths mahbe this can work? https://www.aliexpress.com/item/32879665640.html
                          (unrelated that guy is offering 3.96 VH connectors as well)
                            elliott.griffiths
                            Hi all,
                            Thank you very much for all your responses! This is why this community is awesome 👍
                            Decided to go with @bearer latest suggestion, thanks! Will make a circuit board to adapt I guess, many thanks!
                            • A Former User?
                              @elliott-griffiths said in Where to find the motor side connectors used on Nema17s?:
                              why do you need a board? whats the use case?
                              elliott.griffithsundefined 1 Reply Last reply Reply Quote 0
                                elliott.griffiths @A Former User
                                @bearer Essentially we have a piece of equipment that doesn't support reversing the extruder at the moment (it's actually made for something else). So I want to reverse the direction of the NEMA - but there are a couple of different extruders we use, some geared, some not - so an adaptor to reverse the motor would be ideal for quick switching.
                                A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
                                • A Former User?
                                  @elliott-griffiths so you'll do a relay hooked to the direction pin or something? interesting!
                                  (but can you not use a through hole or surface mount 6-pin PH connector if you need a board anyway?)
                                    dc42 administrators @elliott.griffiths
                                    What's wrong with M569 ? Are you looking to use exactly the same config.g file with different extruders?
