    Reading negative temperature and N/A temp
    1.8k
      jay_s_uk @blt3dp
      @johny
      Use
      ; Bed Heater
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 C0 R4700				; Set thermistor + ADC parameters for heater 0
      M950 H0 C"bedheat" T0                               		; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00
      M140 H0
      M143 H0 S130                               					; Set temperature limit for heater 0 to 120C
      ; Extruder Heater
      M308 S0 P"eotemp" Y"thermistor" T100000 B4275 C7.060000e-8  R4700							;
      M950 H1 C"e0heat" T1                                		; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S400
      blt3dpundefined 1 Reply Last reply Reply Quote 0
      • blt3dpundefined
        blt3dp @jay_s_uk
        @jay_s_uk said in Reading negative temperature and N/A temp:
        @johny
        Use
        ; Bed Heater
        M307 H0 B0 S1.00
        M140 H0
        ; Extruder Heater
        M143 H1 S400
        Yep, use that. In fact, looks like you're either modifying or creating a new config file based off of a RRF2x one. You might want to run through the web configurator and generate one for RRF3
        My 3D Printing YouTube Channel
        Better Living Through 3D Printing
        Follow me on Instagram and Twitter
        Instagram
        Twitter
        • johnyundefined
          johny
          I used and got a different error!
          fault on thermistor
          • johnyundefined
            johny
            cant detect sensor
            • blt3dpundefined
              blt3dp
              Most likely your tool settings. Update these secttions.
              M308 S0 P"bedtemp" Y"thermistor" T100000 B4267 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
              M143 H0 S130                                            ; set temperature limit for heater 0 to 130C
              M307 H0 B0 S1.00                                        ; disable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                                 ; map heated bed to heater 0
              M308 S1 P"e0temp" Y"thermistor" T100000 B4267 C7.06e-8  ; configure sensor 1 as thermistor on pin e0temp
              M143 H1 S275                                            ; set temperature limit for heater 1 to 275C
              M307 H1 B0 S1.00                                        ; disable bang-bang mode for heater  and set PWM limit
              M563 P0 D0 H1 F0                                        ; define tool 0
              G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
              G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
              Instagram
              Twitter
              • johnyundefined
                johny
                @blt3dp said in Reading negative temperature and N/A temp:
                And magic!!!! i get readings!!!! thank you a lot m8! i was starting to get crazy with it! need to check if it heats up!
                thank you!
                • johnyundefined
                  johny
                  It heats!!!! Thank you, i rly appreciate it!
