    help set up max and min z endstops
    • tekstyle
      tekstyle last edited by tekstyle
      Hello there,
      I am building a corexy and i currently got the piezo z probe at MIN, and both x and y homing to work at MIN as well. the only thing is i don't know how to get a max limiter endstop to work on the Z axis. i have tested the endstops and they all work so i dont think it is a wiring issue. thank you for all your help!
      currently, i don't have extruders, heater, fan, thermistor, expansion boards connected. i am just testing out the movement right now so the config.g might seem bare.
      below are my home settings:
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Jan 27 2020 00:08:01 GMT-0800 (Pacific Standard Time)
      G91 ; relative positioning
      G90 ; absolute positioning
      G1 X15 Y15 F6000 ; go to first probe point
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Jan 27 2020 00:08:00 GMT-0800 (Pacific Standard Time)
      G1 H1 X-436.8 Y-408.225 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-436.8 ; home X axis
      G1 H1 Y-408.225 ; home Y axis
      G1 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-436.8 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-408.225 ; then move slowly to Y axis endstop
      G1 X15 Y15 F6000 ; go to first bed probe point and home Z
      ***************************config.g:
      M550 P"coreXY" ; set printer name
      M667 S1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z1600.00 E420.00:420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1700 Y1700 Z1700 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X431.8 Y403.225 Z406.4 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P5 I1 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
      G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
      M557 X15:400 Y15:370 S20 ; define mesh grid
      M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M106 P1 S1 H2 T45 ; set fan 1 value. Thermostatic control is turned on
      M563 P1 D1 H2 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 F0 ; define tool 2
      G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
      G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
      M563 P3 F0 ; define tool 3
      G10 P3 X0 Y0 Z0 ; set tool 3 axis offsets
      G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C
      M563 P4 F0 ; define tool 4
      G10 P4 X0 Y0 Z0 ; set tool 4 axis offsets
      G10 P4 R0 S0 ; set initial tool 4 active and standby temperatures to 0C
      T0 ; select first tool
        You will need a seperate macro to home to Z max. Your homez and homeall are using G30 which will call the probe. To use the Z max endstop you need to use a G1 H1 Z+ move instead of G30. That will move the axis until the endstop triggers.
        Here's an example from the Ender 3 Duet Maestro guide that goes through setting up a Z max endstop along side a Z probe.
        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s213
        tekstyle 1 Reply Last reply Reply Quote 0
        • tekstyle
          tekstyle @Phaedrux last edited by
          @Phaedrux I will check out this article tomorrow. Thank you
          • tekstyle
            i read through the link you sent and everything appears to be easy to follow. the only thing is do I need to modify my homez.g file to call for the "0_Set Zmax height.g" macro? if so, i could not find what i needed to do for the machine to look for the "0_Set Zmax height.g"
            Can i also set this up to have zmax calibration run before every print? if I am using Automatic tool changer, do I just have z=0 with the Z probe set according to T0 and rely on the preset z offset for the other T#? I do not think it would be necessary to home every single tool prior to print correct?
              Phaedrux Moderator @tekstyle last edited by
              @tekstyle said in help set up max and min z endstops:
              In that example homez.g is used to home to zmax using the endstop and homeall uses the probe to home to zmin. Depending on what you want to do, you can either homez or homeall. If you'd rather have home to z max as a separate macro that's fine too. you can either execute it from the DWC or PanelDue, or call it with M98.
              Setting the height of z max could be done seperately manually or you could make it a part of every homing routine. It would really depend on how much the printer changes between runs. If the bed/frame is very stable, you may not need to measure it every time.
              That sounds reasonable, but I'm not well versed on tool changers at the moment.
