    Bench Testing Mixing Extruder with Pronterface
    407
    • ractorIII
      ractorIII last edited by
      I'm new to Duet Wifi but have experience with TinyG and Mega/Ramps: I'm setting up a machine with a mixing extruder - communicating successfully with Printrun via USB and attempting to bench test my mixing extruder - I only have one tool - I believe it is T0; after setting the tool with T0 command and issuing G0E10 printrun issues pack 'no tool sellected'.
      I thought that the T0 command would sellect that tool and then I would be ready to test my extruder motors... My machine is a paste extruder so it does not utilize any heaters and I believe that is disabled... Is a there a duet wizard out there that can help this newb kick of his training wheels?
      {"board":"duetwifi10","expansion_boards":["Duex 5"],"firmware":2.03,"standalone":true,"nvram":false,"auto_save":{"enabled":false,"save_threshold":10,"resume_threshold":11,"gcodes_to_run":"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"},"display":{"type":0,"encoder_steps":4,"spi_frequency":2000000,"menus":[{"name":"main","value":""}],"images":[]},"geometry":{"type":"cartesian","mins":[-315,-650,-50],"maxes":[315,650,300],"delta_radius":105.6,"homed_height":250,"low_dive_height":false,"max_carriage_travel":260,"print_radius":85,"rod_length":215,"z_min":0},"drives":[{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":87.58,"instant_dv":15,"max_speed":50,"acceleration":250,"current":800,"driver":0,"driver_v3":"0.0","endstop_pin":"xstop","endstop_type":0,"endstop_location":1},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":87.58,"instant_dv":15,"max_speed":50,"acceleration":250,"current":800,"driver":2,"driver_v3":"0.1","endstop_pin":"ystop","endstop_type":0,"endstop_location":1},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":1511.5729,"instant_dv":0.2,"max_speed":3,"acceleration":20,"current":800,"driver":1,"driver_v3":"0.2","endstop_pin":null,"endstop":null,"endstop_type":0,"endstop_location":1},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":3200,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":3,"driver_v3":"0.3"},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":3200,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":4,"driver_v3":"0.3"},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":3200,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":5,"driver_v3":"0.3"},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":3200,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":6,"driver_v3":"0.3"},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":3200,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":7,"driver_v3":"0.3"},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":3200,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":8,"driver_v3":"0.3"},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":3200,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":9,"driver_v3":"0.3"}],"idle":{"used":true,"factor":30,"timeout":30},"homing_speed_fast":30,"homing_speed_slow":6,"travel_speed":100,"z_dive_height":5,"slow_homing":false,"probe":{"type":"noprobe","recovery_time":0.4,"trigger_height":2.5,"trigger_value":500,"x_offset":0,"y_offset":0,"speed":2,"deploy":false,"points":[],"pwm_channel":3,"pwm_inverted":true,"pwm_pin":null,"input_pin":"zprobe.in","modulation_pin":"zprobe.mod"},"bed_is_nozzle":false,"bed":{"present":false,"use_pid":false,"heater":0},"chamber":{"present":false,"use_pid":false,"heater":2},"heaters":[null],"num_nozzles":0,"toolchange_wait_for_temperatures":false,"generate_t_code":false,"tools":[{"mix_ratio":[0.2,0.2,0.2,0.2,0.2],"number":0,"name":"V","extruders":[0,1,2,3,4],"heaters":[],"fans":[],"x_offset":0,"y_offset":0,"z_offset":0}],"compensation_x_offset":15,"compensation_y_offset":15,"peripheral_points":3,"halfway_points":3,"calibration_factors":6,"probe_radius":85,"mesh":{"x_min":-300,"x_max":215,"y_min":-635,"y_max":195,"radius":85,"spacing":20},"home_first":false,"orthogonal":{"compensation":false,"height":50,"deviations":[0,0,0]},"network":{"enabled":true,"mac_address":"","name":"Ractor V","password":"","ssid":"","ssid_password":"","dhcp":true,"ip":"192.168.1.20","netmask":"255.255.255.0","gateway":"192.168.1.254","protocols":{"http":true,"ftp":false,"telnet":false}},"fans":[{"name":"FAN3","value":100,"inverted":false,"frequency":500,"thermostatic":false,"heaters":[],"trigger_temperature":45,"output_pin":"fan0"},{"name":"FAN4","value":100,"inverted":false,"frequency":500,"thermostatic":false,"heaters":[],"trigger_temperature":45,"output_pin":"fan1"}],"custom_settings":""}
      clay/ceramic slurry printing - experimental multi-material mixing for ceramics - shapeoko based carteisian - kossel based inverted delta -instagram @earlyamericanrobotpottery
        It looks like you've posted the contents of config.json, can you post the human readable/editable config.g instead?
        Also, what firmware version are you using?
        Have you tried interacting with the board through the web interface rather than printrun?
        ractorIII 1 Reply Last reply Reply Quote 0
        • ractorIII
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Jan 18 2020 12:32:42 GMT-0500 (Eastern Standard Time)
          M550 P"Ractor V" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P4 S1 ; physical drive 4 goes forwards
          M569 P5 S1 ; physical drive 5 goes forwards
          M569 P6 S1 ; physical drive 6 goes forwards
          M569 P7 S1 ; physical drive 7 goes forwards
          M569 P8 S1 ; physical drive 8 goes forwards
          M584 X0 Y2 Z1 E3:4:5:6:7:8 ; set drive mapping
          M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation
          M92 X87.58 Y87.58 Z1511.57 E3200.00:3200.00:3200.00:3200.00:3200.00:3200.00 ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X3000.00 Y3000.00 Z180.00 E1200.00:1200.00:1200.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
          M201 X250.00 Y250.00 Z10.00 E250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E800:800:800:800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X-315 Y-650 Z-50 S1 ; set axis minima
          M208 X315 Y650 Z300 S0 ; set axis maxima
          M574 X0 Y0 Z0 S0 ; set active low and disabled endstops
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M557 X-300:215 Y-635:195 S20 ; define mesh grid
          M140 H-1 ; disable heated bed
          M106 P0 C"FAN3" S1 I0 F500 H-1 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 C"FAN4" S1 I0 F500 H-1 ; set fan 1 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
          • ractorIII
            ractorIII @Phaedrux last edited by
            @Phaedrux running 3.0 and I have also tried the web interface - more comfortable with printrun at the moment
              It would appear that you don't have any tools defined at all.
              • deckingman
                deckingman @ractorIII last edited by
                @ractorIII
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M563_Define_or_remove_a_tool
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M567_Set_tool_mix_ratios
                • ractorIII
                  @Phaedrux - it does seem there are not tools. Hmm - I used the Web RRF Config Tool - I guess I'll go back and run that again. Thanks - just finding the config.g file was super helpful. I was confused why my config file was so hard to decipher.
                  • ractorIII
                    ractorIII @deckingman last edited by
                    @deckingman Thanks for pointing me in the right dirrection - much appreciated.
                    • deckingman
                      @ractorIII No worries. Come back if you need more help.
                      • ractorIII
                        @deckingman - with that note - trouble - I was expecting to be able to designate a tool that utilized 5 extruders with a simple text command M563 P0 D0:1:2:3:4 with printrun it bounces back that there is an error with the drive numbers. Also - I have not been able to issue simple gcode commands via Duet Web Control - though I am able to connect...
                          What does the error say?
                          What happens when you try to send commands in the DWC console?
                          • ractorIII
                            @Phaedrux Nothing happens when I attempt to send gcode through the Duet Web Interface - though the log state that I am connected, the log does not indicate that any code was sent. Another issue that I am having with DWC is that if I attempt to upload the zipped reprap config file I get an AJAX error and it disconnects. If I remember right - I was having this issue before and had to disconnect my power supply from the board and run it strictly of usb to get the upload to work - very inconvenient. I guess I'll open my housing and pull the micro SD out to update reprap config files.
                            To the issue at hand, which is getting a tool designated for bench testing my extruder setup. The following is how print run responds when issued:
                            SENDING:M563 P0 D0:1:2:3:4
                            Error: Tool creation: bad drive number
                            [ERROR] Error: Tool creation: bad drive number
                            I'm using a duet wifi with x5 expansion - I have a total of 7 extruder steppers and for this tool I am trying to use the 2 that are on the Duet Wifi and the first 3 that are on the x5 expansion.
                              Sounds like you might have a mismatched DWC version? What versions are you running?
                              • ractorIII
                                @Phaedrux - you may be right - this is what is listed on DWC. Should the Web Interface Version be HTML: 3.0? I'm starting to get very confused...
                                Firmware Version: 3.0 (2020-01-03b3)
                                Web Interface Version: HTML: 1.11
                                  https://github.com/chrishamm/DuetWebControl/releases
                                  Try uploading this zip file https://github.com/chrishamm/DuetWebControl/releases/download/2.0.7/DuetWebControl-SD.zip
                                  ractorIII 2 Replies Last reply Reply Quote 0
                                  • ractorIII
                                    @Phaedrux - not able to upload file with DWC - followed instructions here:
                                    https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmware_or_DuetWebControl_files
                                    to unzip DuetWebControl-SD.zip onto SD card after deleting old file contents
                                    issue remains - AJAX error when uploading files via DWC
                                      Just to confirm, you've wiped out the /www folder and replaced it with the contents of the zip file and the DWC version now shows as 2.0.7?
                                      What browser are you using?
                                      • ractorIII
                                        @Phaedrux -scratch that - installed and seems to be in sync now.
                                        still trouble defining tool head - same bounce back from DWC on issuing M563 P0 D0:1:2:3:4
                                        'tool creation:bad drive number
                                          @ractorIII said in Bench Testing Mixing Extruder with Pronterface:
                                          How do you have your motors connected? The drive mappings don't match what you're trying to use for tool drives.
                                          https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
                                          • ractorIII
                                            @Phaedrux
                                            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Feb 01 2020 21:20:25 GMT-0500 (Eastern Standard Time)
                                            M550 P"My Printer" ; set printer name
                                            M569 P0 S0 ; physical drive 0 goes backwards
                                            M569 P9 S1 ; physical drive 9 goes forwards
                                            M584 X0 Y2 Z1 E3:4:5:6:7:8:9 ; set drive mapping
                                            M350 X16 Y16 Z16 E16:16:16:16:16:16:16 I1 ; configure microstepping with interpolation
                                            M92 X87.58 Y87.58 Z1511.57 E3200.00:3200.00:3200.00:3200.00:3200.00:3200.00:3200.00 ; set steps per mm
                                            M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                                            M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:1200.00:1200.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
                                            M201 X500.00 Y500.00 Z20.00 E250.00:250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
                                            M906 X800 Y800 Z800 E800:800:800:800:800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                            M106 P2 C"FAN5" S1 I0 F500 H-1 ; set fan 2 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
                                            M563 P0 S"V" D0:1:2:3:4 F-1 ; define tool 0
                                            M568 P0 S1 ; enable mixing for tool 0
                                            M567 P0 E0.2:0.2:0.2:0.2:0.2 ; set mixing ratios for tool 0
                                            T0 ; select first tool
                                            • ractorIII
                                              @Phaedrux - yeah - I wasn't sure if the drive should match the extruder number or the drive number, so I tried both M563 P0 D0:1:2:3:4 and M563 P0 D3:4:5:6:7 am getting the same 'tool creation: bad drive number. I read the sections on drive mapping and tool defining and everything seems to be in order. Unless I missed something. Dumbfounded at the moment.
                                              • deckingman
                                                deckingman @ractorIII last edited by deckingman
                                                @ractorIII The drive numbers used when you define a tool refer to the extruder drives in the order that they are created. So if you have physical drives assigned to extruders 3 to 7 in M584 then the extruder drive numbers when you define a tool are 0 to 4. Which looks like that's how you have done it.
                                                  dc42 administrators @ractorIII last edited by dc42
                                                  Perhaps the M584 command to set up the extruder drives failed. If you send M584 without parameters, what does it report?
                                                  EDIT: maximum number of extruders supported by RRF3 on Duet 2 is 6. So your command:
                                                  is failing because you are trying to create 7 extruders. If you really need 7 then I can increase the limit.
                                                  • ractorIII
                                                    ractorIII @dc42 last edited by
                                                    thanks @dc42 - I need 5 extruder steppers at the moment - if that is the case I'll remap my motors so my dual Y steppers are not doubled up on one driver. Maybe that will fix my issue - I'll look into your other suggestions later today.
                                                    I would be interested in having more extruder steppers available in the future - or even the ability of mapping all of the drivers as extruders - the goal would be precise stationary liquid slurry mixing machine.
                                                    • ractorIII
                                                      @deckingman - thanks for your help. Eliminating the E6 driver mapping resolved the issue. All steppers are tested to be operating as expected.
                                                      I would like to use that final stepper on the Duex5 as an extruder eventually but will not need it anytime soon.
