    Help with new config.g
    821
    • kmhudginsundefined
      kmhudgins
      I am slowly trying to figure this new config.g inputs but im not sure im grasping this at the moment I was hoping someone might be able to look over my code and verify if im on the right track. I did not change the fans yet because I am not really sure how to modify them correctly any help would be much appreciated. Hardware is duet 2 maestro on a ender 3 with a bltouch sensor.
      Thank you
      M569 P0 S0 ; Physical drive 0 goes backwards
      M569 P1 S0 ; Physical drive 1 goes backwards
      M569 P2 S1 ; Physical drive 2 goes forwards
      M569 P3 S0 ; Physical drive 3 goes backwards
      M350 X16 Y16 Z16 E128 I1 ; Configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E828.9 ; Set steps per mm
      M566 X600.00 Y600.00 Z60.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z600.00 E6000.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z120.00 E5000.00 ; Set accelerations (mm/s^2)
      M906 X800.00 Y800.00 Z800.00 E900.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X235 Y235 Z260 S0 ; Set axis maxima
      M574 X1 S1 P"xstop" ; X min active high endstop switch
      M574 Y1 S1 P"ystop" ; Y min active high endstop switch
      M574 U2 S1 P"e0stop" ; U max active high endstop switch
      M558 P9 C"^zprobe.in" H5 F120 T3000 ; BLTouch connected to Z probe IN pin, free up MOD pin
      M950 S0 C"zprobe.mod" ; servo/gpio 0 is Z probe MOD pin
      M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0
      G31 P500 X36.7 Y6 Z.772 ; Set Z probe trigger value, offset and trigger height
      M557 X5:200 Y10:215 S39 ; Define mesh grid
      M308 S0 P"bed_temp" Y"thermistor" T100000 B4138 R4700 ; define bed temperature sensor
      M308 S1 P"e0_temp" Y"thermistor" T98801 B4185 R2200 C7.06e-8 ; define E0 temperature
      ;sensor
      M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
      M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
      M106 P0 S0 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 I0 F500 h1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 S"Hotend" D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      • Vetiundefined
        Veti
        the configurator can help you as it support v3
        https://configtool.reprapfirmware.org/Start
        transfer the settings over as it will be easier. for example e0_temp is not called that but e0temp.
        you have no u axis defined
        • DIY-O-Sphereundefined
          DIY-O-Sphere
          @kmhudgins
          Should be
          M558 P9 C"zprobe.in" H5 F120 T3000
          The challenge in configuration tool maybe is to set up the probe.
          https://forum.duet3d.com/topic/13924/maestro-rrf3-and-bltouch-issues/19
          That is the wrong resistor value for the Maestro
          Standard fan setup:
          As @Veti mentioned, try to generate a clean setup with the RRFCT
          (UTC+1)
            kmhudgins
            I forgot to mention the bed heater is the 3dfused bed the values i have in there are the values the gave me
              kmhudgins
              Well i ran config tool and y end stop does not work hot end sencor is reading 2000 c and z probe does not work im honestly thinking about going back to old firmware
                kmhudgins
                M569 P0 S0 ; physical drive 0 goes backwards
                M350 E256 I0 ; configure microstepping without interpolation
                M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
                M92 X80.00 Y80.00 Z4000.00 E6984.63 ; set steps per mm
                M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                M208 X230 Y230 Z260 S0 ; set axis maxima
                M558 P2 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to modulated and the dive height + speeds
                G31 P500 X36.7 Y6 Z2.5 ; set Z probe trigger value, offset and trigger height
                M557 X15:215 Y15:195 S20 ; define mesh grid
                M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
                M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
                ; homeall.g
                ; called to home all axes
                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 07 2020 16:04:16 GMT-0600 (Central Standard Time)
                G91 ; relative positioning
                G1 H1 X-235 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 H2 X5 Y5 F6000 ; go back a few mm
                G1 H1 X-235 Y-235 F360 ; move slowly to X and Y axis endstops once more (second pass)
                G1 H1 Z-265 F360 ; move Z down stopping at the endstop
                G90 ; absolute positioning
                G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                ;G91 ; relative positioning
                ;G1 Z5 F100 ; lift Z relative to current position
                ;G90 ; absolute positioning
                ; homex.g
                ; called to home the X axis
                G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
                G1 H2 X5 F6000 ; go back a few mm
                G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
                G1 H2 Z-5 F6000 ; lower Z again
                ; homey.g
                ; called to home the Y axis
                G1 H1 Y-235 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                G1 H2 Y5 F6000 ; go back a few mm
                G1 H1 Y-235 F360 ; move slowly to Y axis endstop once more (second pass)
                ; homez.g
                ; called to home the Z axis
                G1 H1 Z-265 F1800 ; move Z down until the endstop is triggered
                this is the code i got from the config tool
                  dc42 administrators @DIY-O-Sphere
                  @DIY-O-Sphere said in Help with new config.g:
                  @kmhudgins
                  Should be
                  No, on Duet WiFi, Ethernet and Maestro with recent versions of BLTouch, the ^ before zprobe.in is essential.
                    kmhudgins
                    i got the heater corrected and the y stop working i think at the moment the z probe is the only thing not working. The deployprobe.g does not seem to work when i try to home z axis the probe does nothing
                    here is the g code for it
                    ; deployprobe.g
                    ; called to deploy a physical Z probe
                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 07 2020 16:31:53 GMT-0600 (Central Standard Time)
                    M280 P0 S10 ; deploy BLTouch
                      kmhudgins
                      this is what the config.g looks like at moment
                      M550 P"My Printer" ; set printer name
                      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
                      M558 P9 C"^zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                        kmhudgins
                        I have ran the config tool 18 times now trying to figure out what im doing wrong and at this point i have no clue every time something goes wrong. At this point the bltouch will not run it start up test. I followed the link DIY-O-Sphere posted earlier in the post and made sure i matched my config tool settings to the images provided and still nothing is working. I would be VERY happy if ANYONE can shed some light on whats going on. Everything worked befor I updated.
                        I have an ender 3 with a duet meastro, bltouch and a fused3d bed that has a NTC100K thermistor.
                        The most recent config is below.
                        Thanks for the help.
                        M350 X16 Y16 Z16 E128 I1 ; configure microstepping with interpolation
                        M92 X80.00 Y80.00 Z4000.00 E741.00 ; set steps per mm
                        M566 X600.00 Y600.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
                        M201 X500.00 Y500.00 Z20.00 E5000.00 ; set accelerations (mm/s^2)
                        M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                        M558 P9 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                        G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                        M308 S1 P"e0temp" Y"thermistor" T98801 B4138 ; configure sensor 1 as thermistor on pin e0temp
                          DIY-O-Sphere
                          @kmhudgins said in Help with new config.g:
                          M950 S0 C"zprobe.mod" ; create servo pin 0 for BLTouch
                          (UTC+1)
                            Not quite, you need the ^ in front of zprobe.in. Also, in RRF3.0 you need to put the M558 command before the M950 command, because the default Z probe uses pin "zprobe.mod" as well as "zprobe.in". In RRF 3.01 it doesn't matter, because there is no default Z probe.
                            This is all documented at https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3.
                            DIY-O-Sphereundefined kmhudginsundefined 2 Replies Last reply Reply Quote 0
                              DIY-O-Sphere @dc42
                              @dc42 said in Help with new config.g:
                              That's a Maestro!
                              (UTC+1)
                                That's a Maestro!
                                Yes, as @kmhudgins said he is using.
                                You need the ^ in front of zprobe.in for any Duet 2 running RRF3 with a recent version BLTouch. This is because recent versions of BLTouch have open-drain outputs.
                                DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                  DIY-O-Sphere @dc42
                                  Thank you for clarification. Now I am clear about why my BLT 2.0.... works without pullup (^)
                                  Maybe a note in the wiki guide about the different versions of BLT would be helpful.
                                  (UTC+1)
                                    kmhudgins @dc42
                                    Thank you for the help
                                    I made this change to the config.g but it did not change anything. the bltouch shill wont run the start up test and therefor just has a blinking red light.
                                      DIY-O-Sphere
                                      @kmhudgins
                                      Have you replaced all files in sys folder? Or only the config.g?
                                      Have you checked the version of your BLTouch?
                                      You can check the probe by sending:
                                      M280 P0 S120
                                      For RRF3 the deployprobe.g and retractprobe.g have to be modified.
                                      (UTC+1)
                                        kmhudgins
                                        this is the code that seems to work.
