Bed Temperature ERROR
My bed temp reads ERROR on the WebControl page and -273.1 on the display. I checked thermistor resistance values of both sensors at the board both read about 117k. The bed and hotend are chinese junk for now. Here is my config file:
; Configuration file for Duet WiFi (firmware version 1.17)
; generated by RepRapFirmware Configuration Tool on Wed May 03 2017 10:36:50 GMT-0400 (Eastern Daylight Time); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
M208 X0 Y34 Z0 S1 ; Set axis minima
M208 X200 Y200 Z180 S0 ; Set axis maxima; Endstops
M574 Z0 S0 ; Define active low and unused microswitches
M574 X1 Y1 S1 ; Define active high microswitches
M558 P1 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
G31 P443 X0 Y0 Z1.5 ; Set Z probe trigger value, offset and trigger height
M557 X30:185 Y15:185 S20 ; Define mesh grid; Drives
M569 P0 S0 ; Drive 0 goes backwards
M350 X32 Y32 Z32 E32 I1 ; Configure microstepping with interpolation
M92 X320 Y320 Z10240 E420 ; Set steps per mm
M566 X900 Y900 Z50 E120 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z100 E1200 ; Set maximum speeds (mm/min)
M201 X500 Y500 Z25 E250 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 S260 ; Set maximum heater temperature to 260C
M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 *********** ; Set machine name
M551 ********** ; Set password
M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP; Fans
M106 P1 S1 I0 F500 H0:1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured
Does the hotend read temperature correctly?
yes
That's good, and indicates the VSSA fuse is OK. Could you try moving the hotend thermistor to the bed port?
Did that same issue that is I swapped them same readings
Could you post a photo of the Duet with both thermistors connected, please?
Just to confirm: with the bed thermistor plugged into the E0 thermistor connector and the hot end thermistor plugged into the bed thermistor connector, you still get -273 in the current bed temperature box?
Please run M305 P0 and verify that the values it reports are as in your M305 P0 command in config.g.
T:100000.0 B:3950.0 C:0.00e+00 R:4700.0 L:0 H:0 X:0 from command sent
M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0 from configso what is the next step?
Anyone???
Please can you answer this question.
Bed temperature stays the same regardless of what thermistor is plugged in. The only way I was able to effect a change to the reading was to use T value 1 in that case it reads 2000 degrees.
Also the -273 is on the display, the web app reads ERROR
Looks like there is an issue with the bed temp channel. Please contact your supplier.
