    KEEVO Printer (corexy)
    My Duet controlled machine
    • nuverianundefined
      nuverian
      Hello again,
      I just wanted to share with you the last build I made, which of course uses Duet 🙂
      (KEEVO = Cube in Greek)
      (yeah the cables need some management)
      It is also posted on Thingiverse -> https://www.thingiverse.com/thing:4129443
      Any feedback is welcome of course!
      Also, regarding the 3 leadscrews (which are only really mounted on the bottom), do you think that the forces from the Z belt will bend the leadscrews in the long run. I don't really see any bending though. It can be seen more clearly in this video which was the previous version (an hbot without duet and other stuff, but z axis is the same) -> https://www.youtube.com/watch?v=K0pcGKAQ4eA
      Cheers 🙂
      Phaedruxundefined 1 Reply Last reply Reply Quote 1
        Phaedrux Moderator @nuverian
        @nuverian said in KEEVO Printer (corexy):
        Unlikely.
        Nice looking printer.
        nuverianundefined 1 Reply Last reply Reply Quote 1
        • nuverianundefined
          nuverian @Phaedrux
          @Phaedrux Hey thanks!
          Great printer you have as well 🙂 Similar Z concepts. I see you use two bearings (as far as I understood). Was that for the same reason and for peace of mind?
          I also don't think it will be a problem, but what I was thinking is adding a counter bearing on the bottom so that when the belt pulls, the leadscrew won't budge. Something like this mockup:
          Maybe an overkill, maybe not 🙂
            Yes, the double bearing block was mostly to help keep the lead screw stable vertically, but also would help counter and pulling forces from the belt tensioner.
            https://www.thingiverse.com/thing:2401504
            • A Former User?
              A Former User @nuverian
              Double shear is nearly always better than single shear.
              • mrehorstdmdundefined
                mrehorstdmd
                The screw is 8mm diameter and you're pulling on it with the same belt that's pulling on the 5 mm motor shaft. If it's OK to do that at the motor shaft, it's probably OK at the larger diameter lead screw.
                You could easily fabricate a two-bearing mount for the lead screw as a single piece either from rectangular aluminum tubing or by printing a part with a tang that fits in the t-slot. I did this in my sand table (the brown part):
                The two pieces that make up the pulley mount are aligned by bosses. The bearings press-fit tightly into the top and bottom pieces.
                • nuverianundefined
                  nuverian
                  Thanks for your comments.
                  I ended up adding a counter bearing on the bottom to help with the belt forces, as well as a collar on the leadscrew above the pillow bearing to help with vertical/gravity forces.
