CR-10 V2 & BL Touch
Is anyone using their Duet 2 wifi with a Creality CR-10 V2 with a BL Touch? I have a spare D2W sitting around and it can't be any worse than the stock board. As you probably know, the CR0-10 V@ has two Z motors.
Thanks!
What exactly are you asking?
@Phaedrux I want to know if I can use the D2w with my CR-10 v2. Not theoretically able to use it, but I’m looking for someone who is actually using it.
Thanks!
@BearcatTD bump
That Q like symbol at the top there is a wonderful tool for searching.. There are plenty of users of CR10 in various edittions, and it seems the only relevant change to the V2 is the 24v supply and the TMC2208 stepper drivers neither affect the compatability or configuration of the Duet2Wif.
Thanks Bearer!
As an aficionado of subtle sarcasm, kudos on the first line. Everything else was quite helpful!
Pat
