Need help with stopend switch.
need help with stopend switch
536
  • undefined
    chris4
    Hi, I am new, have tried to fix endstops for my 3d with duet2wifi RepRapFirmware for Duet 2, 2.02 (RTOS) (2018-12-24b1) has built itself a BLV_mgn12. The problem is that can not understand how would microswitch work, have contacted switch to the outermost contacts on the switch NC and on duet2wifi on signal and ground, but without results. can any of you help me with that.
    Regards Christian
    ? 1 Reply Last reply 16 Feb 2020, 19:50 Reply Quote 0
    • undefined
      SIam
      did you have this switch?
      endstop microswitch
      if yes on the thirt picture you see the cabel red is +3.3V black is gnd(-) and green is signal.
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      • undefined
        chris4
        No I have , connected to 1 and 2 (NC-C)
        https://www.amazon.de/dp/B01LWI1PKU/ref=pd_aw_sbs_60_4/259-6509690-2357526?_encoding=UTF8&pd_rd_i=B01LWI1PKU&pd_rd_r=50502f45-8ead-4d6f-832e-fb2273139315&pd_rd_w=2C8y9&pd_rd_wg=QhfN9&pf_rd_p=ac232abb-3e3c-4b3b-be24-e4d61fe1b75e&pf_rd_r=KAK2373EA44N6TM3PDYN&psc=1&refRID=KAK2373EA44N6TM3PDYN
        • undefined
          SIam
          NC normaly means not conneted you have to use NO & C
          ? 1 Reply Last reply 16 Feb 2020, 19:49 Reply Quote 0
          • undefined
            chris4
            Have followed this, do you know rotation on x y z stepper motor, maybe also my problem with switch.
            https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#3.3V-compatible_optical_endstop
              A Former User @SIam
              @SIam said in Need help with stopend switch.:
              on a switch NC is normally normally closed, and its preferred for limit switches as it would prevent movement if the wire breaks.
                A Former User @chris4
                @chris4 said in Need help with stopend switch.:
                maybe post a picture of switch and duet connection?
                • undefined
                  chris4
                  some pictures , where it appears that the endstop LED is on, but Z Y X is not in the home position, if I press each switch, the endstop LED is off on duet2wifi.
                  Should it be so?
                  home position OFF, not home location ON!
                  • undefined
                    chris4
                    And the config.g
                    code_text
                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 10:46:54 GMT+0100 (centraleuropeisk normaltid)
                    M550 P"Anet A8" ; set printer name
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M92 X100.00 Y100.00 Z400.00 E100.00 ; set steps per mm
                    M566 X600.00 Y600.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
                    M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
                    M906 X500 Y500 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X-33 Y-10 Z0 S1 ; set axis minima
                    M208 X220 Y220 Z240 S0 ; set axis maxima
                    M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
                    M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                    M557 X20:200 Y20:200 S40 ; define mesh grid
                    M305 P0 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 0
                    M143 H0 S130 ; set temperature limit for heater 0 to 130C
                    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                    M143 H1 S275 ; set temperature limit for heater 1 to 275C
                    M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    T0 ; select first tool
                    • undefined
                      chris4
                      Homeall:
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 10:52:04 GMT+0100 (centraleuropeisk normaltid)
                      G91 ; relative positioning
                      G1 H1 X-258 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H2 X5 Y5 F6000 ; go back a few mm
                      G1 H1 X-258 Y-235 F360 ; move slowly to X and Y axis endstops once more (second pass)
                      G1 H1 Z-245 F360 ; move Z down stopping at the endstop
                      G90 ; absolute positioning
                      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                      ;G91 ; relative positioning
                      ;G1 Z5 F100 ; lift Z relative to current position
                      ;G90 ; absolute positioning
                      • undefined
                        chris4
                        ; homex.g
                        ; called to home the X axis
                        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 10:55:31 GMT+0100 (centraleuropeisk normaltid)
                        G1 H1 X-258 F1800 ; move quickly to X axis endstop and stop there (first pass)
                        G1 H2 X5 F6000 ; go back a few mm
                        G1 H1 X-258 F360 ; move slowly to X axis endstop once more (second pass)
                        G1 H2 Z-5 F6000 ; lower Z again
                        • undefined
                          chris4
                          ; homey.g
                          ; called to home the Y axis
                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 10:50:45 GMT+0100 (centraleuropeisk normaltid)
                          G1 H1 Y-235 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                          G1 H2 Y5 F6000 ; go back a few mm
                          G1 H1 Y-235 F360 ; move slowly to Y axis endstop once more (second pass)
                          • undefined
                            chris4
                            ; homez.g
                            ; called to home the Z axis
                            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 11:09:06 GMT+0100 (centraleuropeisk normaltid)
                            G1 H1 Z-245 F1800 ; move Z down until the endstop is triggered
                              I suggest you start by testing the endstop switch and wiring. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches.
                              • undefined
                                chris4
                                Have fixed now, by changing the switch to NO and working now.
                                Thanks for the help.
                                But one more question, how can change the speed of Z axis on the way to endstop (low switch) to a slow speed last cm to endstop. The same speed, as on the x and y axis. I have this config.g
                                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 13:12:07 GMT+0100 (centraleuropeisk normaltid)
                                M550 P"My Printer" ; set printer name
                                M569 P3 S0 ; physical drive 3 goes forwards
                                M92 X160.00 Y160.00 Z2560.00 E873.08 ; set steps per mm
                                M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                                M201 X400.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
                                M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                M208 X230 Y230 Z240 S0 ; set axis maxima
                                M574 X1 Y1 Z1 S0 ; set active high endstops
                                M557 X-18:215 Y5:195 S20 ; define mesh grid
                                M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
                                M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
                                T0
                                and the homez.g
                                homez.g
                                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 21 2020 13:36:08 GMT+0100 (centraleuropeisk normaltid)
                                Thanks Christian
                                Phaedruxundefined 1 Reply Last reply 21 Feb 2020, 20:55 Reply Quote 0
                                  Phaedrux Moderator @chris4
                                  It's not possible to slow down before the endstop, because it doesn't know where the endstop is before being homed. Typically homing would be done in two passes. A fast movement to the endstop, followed by a short movement back, and then a slower movement towards the endstop again for better accuracy.
                                  • undefined
                                    chris4
                                    @Phaedrux said in Need help with stopend switch.:
                                    Thanks.
                                    1 out of 17
