Bad Benchy Bottom
  • Thanks for all the help! I have the Duet 2 wifi up and printing! But I have a problem that I can't figure out after searching. The lower half of a Benchy print is bad, the upper half is good considering my machine. I know I have to work on the first layer but this goes half way up the print. I want to print parts for an XY machine so I need to nail this problem down. See the attached picture. I have a couple of ideas but just wanted to run this by the group.
  • hi,
    i would say your printig temperature is to hight and/or your component cooling is to low, which material on which temperatur you try to print?
  • Slam
    Thanks for the quick response. I have found my problem, my Z axis threaded rods have some bad threads. I will replace them and move on!
  • @wannathermal said in Bad Benchy Bottom:
    Slam
    What sort of rods are they?
    That may be an issue, but there's likely some temp and extrusion issues in play here too. I'd really have a close look at your extruder esteps and extrusion multiplier as well.
  • I have this same issue in Cura with benchy...
    this one is more pronounced than others i did, but the top part prints beautifully.
  • here is a less pronounced one - (printing at finer resolution)
  • I've printed test cubes and they look fine.. printing a tall 20x20x400mm tower in vase mode right now to eliminate screw problems
  • Prusa slicer isn't anywhere near as pronounced with defects.
    Trying another with lower temps to see if it is too hot
  • Moderator
    @supernovae Probably fan speed settings differences between prusaslicer and cura. The bow is a very steep angle and needs a lot of cooling. The benchy is so tiny that it's prone to overheating. Try printing two at once in cura and I bet the bow will look much better.
  • I checked cura, its set to be 100% fan on layer 2 - but it doesn't seem to be doing that. I'm going to try another benchy now in cura and see if i hear the fan at 100% or see if it gets louder progressively..
    i guess i could just also read the gcode and see what the fan is set to as well heh. off to try that too
  • Just to update, i swapped out cooling ducts - what a huge difference. I also tossed out this white PLA and used another brand and its now printing perfectly. I had to print the old white much hotter than i thought necessary to avoid jams but in doing so it stressed out a bad cooler. fixed both and happy now 🙂
